I have a node into a module like below:
module.exports = function(RED) {
//requires and global vars here
var host = RED.settings.host || "localhost";
var request;
function myNode(config) {
this.request = config.request;
parseJSON(request);
// do more things here
RED.nodes.registerType("my node", myNode);
function parseRequest(request) {
let json = {};
try {
json = JSON.parse(request);
} catch (e) {
node.error(RED._("parsing error occur", {location: "parse"}), request );
return json;
I'm trying to do some unit test for the above node through node-red-node-test-helper and I wonder if there is a way to test the functions needed by the node "myNode" in this case "parseRequest". There could be more complex functions than the one I used on the example so, considering that scenario, if in my test file code I want to do a unit test for that "parseRequest" function, I face some obstacles:
- I have no way of invoke the "parseRequest" function since the test file, when try to do something like the below, does not recognize like a function.
var mynode = require("myNode.js");
mynode.parseRequest({id:1, name:"qwerty"});
- my exported module need an instance of RED object as parameter.
- the only way I can access that function is if I take it out from the node module and exports it separately, but can trigger another error because of the use of RED into the catch.
I hope you understand my point here
Thanks for the help
