bmsjk.txt (3.6 KB)
hallo,
I am very new in node ...and I don't now how ?
I wont to inject this file in influxdb via node red.
any suggestion we apreciate.
Rgd Nicu
bmsjk.txt (3.6 KB)
hallo,
Rgd Nicu
Welcome to the forum @NicuBioc
Where is the data coming from? Usually there are better ways then going through files.
If you haven't done so then I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot in about 1 hour. A small investment for a lot of gain.
thx Colin, data come from BMS (battery management system ).
Now is working,(i extract in json format data and I separated).
I have more one problem... One data is string when I discharge bateryy and is necessary to by number.Flow stop.
Now is madatary to transform this data in number.
rgd,Nicu
msg.topic=123
tmp=JSON.parse(msg.payload);
msg.payload = [
V01 :tmp.voltage_cell01,
V02 :tmp.voltage_cell02,
V03 :tmp.voltage_cell03,
V04 :tmp.voltage_cell04,
V05 :tmp.voltage_cell05,
V06 :tmp.voltage_cell06,
V07 :tmp.voltage_cell07,
V08 :tmp.voltage_cell08,
V09 :tmp.voltage_cell09,
V10 :tmp.voltage_cell10,
V11 :tmp.voltage_cell11,
V12 :tmp.voltage_cell12,
V13 :tmp.voltage_cell13,
V14 :tmp.voltage_cell14,
avr_V :tmp.average_cell_voltage,
delta_v :tmp.delta_cell_voltage,
bat_v :tmp.battery_voltage,
bat_pwr :tmp.battery_power,
bat_t1 :tmp.battery_t1,
bat_t2 :tmp.battery_t2,
mos_t :tmp.mos_temp,
p_rmn :tmp.percent_remain,
cap_rem :tmp.capacity_remain,
i_inc :tmp.current_charge,
i_des :tmp.current_discharge,
