The best way to implement device database
I've been using this approach, below, for managing the attributes of my various sensors from within a function block. It has associated nodes to read from and write to disk. Each device definition can be converted to MQTT topics. I have a variety of devices including old X-10s and xbee radios.
Whenever I create a new device, I update this list (in a function block) and push the write-to-disk node. Then when node-red restarts, it reads from that disk file.
var devices = {
payload : [
      "building": "home",
      "room": "bedroom",
      "device": "light",
      "tech": "X10",
      "id": "M5",
      "type": "actuator",
      "adc": "",
      "feed": "",
      "desc": "x10 device and lamp"
      "building": "home",
      "room": "stairwell",
      "device": "light",
      "tech": "LIFX",
      "id": "lifx1",
      "type": "actuator",
      "adc": "",
      "feed": "",
      "desc": "Wifi LED light bulb"
      "building": "home",
      "room": "livingroom",
      "device": "shelf-light",
      "tech": "LIFX",
      "id": "lifx2",
      "adc": "",
      "feed": "",
      "type": "actuator",
      "building": "home",
      "device": "cieling-light",
      "tech": "LIFX",
      "id": "lifx3",
      "adc": "",
      "feed": "",
      "type": "actuator",
      "building": "home",
      "room": "office",
      "device": "light",
      "tech": "X10",
      "id": "M8",
      "adc": "",
      "feed": "",
      "type": "actuator",
      "building": "home",
      "room": "guestroom",
      "device": "light",
      "tech": "X10",
      "id": "M7",
      "adc": "",
      "feed": "",
      "type": "actuator",
      "building": "home",
      "device": "light",
      "tech": "X10",
      "id": "M1",
      "adc": "",
      "feed": "",
      "type": "actuator",
      "building": "home",
      "room": "kitchen",
      "device": "light",
      "tech": "X10",
      "id": "C4",
      "adc": "",
      "feed": "",
      "type": "actuator",
      "building": "home",
      "room": "garage",
      "device": "light",
      "tech": "wemo",
      "id": "we4",
      "adc": "",
      "feed": "",
      "type": "actuator",
      "desc": "wemo wifi switch and lamp"
      "building": "home",
      "room": "garage",
      "device": "relay",
      "tech": "ESP",
      "id": "E43",
      "adc": "",
      "feed": "",
      "type": "actuator",
      "desc": "Wemos ESP device and 120VAC relay"
      "building": "home",
      "room": "kitchen",
      "device": "switch",
      "tech": "HZ",
      "id": "H1",
      "adc": "",
      "feed": "",
      "type": "sensor",
      "desc": "Capacitive switch on ESP Huzzah"
      "building": "home",
      "room": "backporch",
      "device": "tl-ms-0",
      "tech": "XB",
      "id": "2",
      "adc": "0,1,4,R",
      "feed": "",
      "adjust": "1,1,1,1",
      "type": "sensor",
      "desc": "xbee based sensor board"
      "building": "home",
      "room": "kitchen",
      "device": "tl-ms-1",
      "tech": "XB",
      "id": "13",
      "adc": "0,1,2,3,R",
      "feed": "",
      "type": "sensor",
      "building": "home",
      "room": "garage",
      "tech": "XB",
      "id": "29",
      "adc": "0,1,2,3,R",
      "feed": "",
      "type": "sensor",
      "building": "home",
      "room": "bedroom",
      "tech": "XB",
      "id": "12",
      "adc": "0,1,2,3,R",
      "feed": "",
      "type": "sensor",
      "building": "home",
      "room": "bathroom",
      "tech": "XB",
      "id": "15",
      "adc": "0,1,2,3,R",
      "feed": "",
      "type": "sensor",
      "building": "home",
      "room": "office",
      "tech": "XB",
      "id": "23",
      "adc": "0,1,2,3,R",
      "feed": "",
      "type": "sensor",
      "building": "home",
      "tech": "XB",
      "id": "9",
      "adc": "0,1,2,3,R",
      "feed": "25133",
      "type": "sensor",
      "building": "home",
      "room": "bedroom",
      "tech": "XB",
      "id": "8",
      "adc": "0,1,2,3,R",
      "feed": "25131",
      "type": "sensor",
      "building": "home",
      "room": "office",
      "tech": "XB",
      "id": "7",
      "adc": "0,1,2,3,R",
      "feed": "24660",
      "type": "sensor",
      "building": "home",
      "room": "dining",
      "device": "tl-gas",
      "tech": "XB",
      "id": "5",
      "adc": "0,1,2,3,R",
      "feed": "10267",
      "type": "sensor",
      "building": "home",
      "room": "diningroom",
      "device": "light",
      "tech": "X10",
      "id": "M14",
      "adc": "",
      "feed": "",
      "type": "actuator",
      "desc": "x10 wall switch"
      "building": "home",
      "room": "porch",
      "device": "tl-temp",
      "tech": "XB",
      "id": "2",
      "adc": "0,1,R",
      "feed": "9709",
      "type": "sensor",
      "building": "home",
      "room": "laundry",
      "device": "switch",
      "tech": "ESP",
      "id": "E42",
      "adc": "",
      "feed": "",
      "type": "actuator",
// set a global context to retrieve later
global.set("devices",devices.payload)
var s = JSON.stringify(devices.payload);
msg.payload=s;
