Sorry, I was thinking that I just made a simple mistake with the "return" statement or what, and this could be corrected with the same simplicity.
The system is supposed to work as such : Two trackers send their position to an MQTT server, which then publishes to node-red, which then tries to publish their positions on a google maps page. I think the reason I use "context" is evident; data comes from different sources at different times, but should be accessible at the web-page at all times.
Below is the full code. It may not be the "cleanest" code, not knowing much, I wrote it by looking it other written examples:
[{"id":"c9eaca60.7d3868","type":"function","z":"ca6ebd5b.5b082","name":"Decrypt Payload","func":"// msg1 - Unencrypted (vanilla data)\nvar msg1 = { payload: msg.payload.length };\nmsg1.payload = JSON.parse(msg.payload);\nmsg1.payload = msg1.payload.payload_raw;\n\n// msg2 - Decrypt to Text\nvar msg2 = { payload: msg.payload.length };\nmsg2.payload = JSON.parse(msg.payload);\nmsg2.payload = new Buffer(msg2.payload.payload_raw, 'base64').toString('ascii');\n\n// msg3 - Decrypt as Binary value (MSB,LSB)\nvar msg3 = { payload: msg.payload.length };\nmsg3.payload = JSON.parse(msg.payload);\nmsg3.payload = new Buffer(msg3.payload.payload_raw, 'base64').toString('hex');\nmsg3.payload = parseInt(msg3.payload, 16);\n\nreturn [ msg1, msg2, msg3 ];","outputs":"3","noerr":0,"x":642,"y":316.5,"wires":[[],["5e13be1e.7bff8","83015f42.a58e6"],[]]},{"id":"5e13be1e.7bff8","type":"debug","z":"ca6ebd5b.5b082","name":"msg.payload.payload_raw - DATA (decrypted to text)","active":false,"console":"false","complete":"payload","x":656.25,"y":581.2499961853027,"wires":[]},{"id":"605805e8.7aa81c","type":"debug","z":"ca6ebd5b.5b082","name":"message (as is)","active":false,"console":"false","complete":"payload","x":905.0000076293945,"y":260.74999809265137,"wires":[]},{"id":"dfc25552.be6be8","type":"json","z":"ca6ebd5b.5b082","name":"","pretty":false,"x":621.75,"y":261.24999618530273,"wires":[["605805e8.7aa81c","ead5469b.e367b8"]]},{"id":"cd533c.a4cefcc8","type":"comment","z":"ca6ebd5b.5b082","name":"For MQTT \"user\"/\"password\", use \"Application ID\"/\"default key\" ","info":"\n1) Sign in to TTN and go to your application page where \"app_1\" is your \"Application ID\" e.g.\nhttps://console.thethingsnetwork.org/applications/app_1\n\n2) For MQTT User, use \"Application ID\" \n\n3) For MQTT password, scroll to bottom and use \"default key\" (you need to press the \"eye\" to see the long text)","x":282.25,"y":88,"wires":[]},{"id":"83015f42.a58e6","type":"function","z":"ca6ebd5b.5b082","name":"","func":"flow.set('data',msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":901.4166870117188,"y":331.24999618530273,"wires":[["39c33a87.de57b6"]]},{"id":"39c33a87.de57b6","type":"debug","z":"ca6ebd5b.5b082","name":"","active":false,"console":"false","complete":"payload","x":1083.4166870117188,"y":299.24999618530273,"wires":[]},{"id":"217a20c4.1cc5c","type":"http response","z":"ca6ebd5b.5b082","name":"http out","statusCode":"","headers":{},"x":1196.25,"y":481.24999618530273,"wires":[]},{"id":"2156b606.87874a","type":"http in","z":"ca6ebd5b.5b082","name":"http in","url":"/test3","method":"get","upload":false,"swaggerDoc":"","x":626.25,"y":441.24999618530273,"wires":[["ba9a95d7.2a6e98"]]},{"id":"ead5469b.e367b8","type":"function","z":"ca6ebd5b.5b082","name":"","func":"flow.set(\"devid\",msg.payload.dev_id); \nreturn msg;\n","outputs":1,"noerr":0,"x":905,"y":171.24999618530273,"wires":[["ee0d17b3.b7f7b8"]]},{"id":"ba9a95d7.2a6e98","type":"function","z":"ca6ebd5b.5b082","name":"","func":"\n//msg.payload = flow.get('data')||0;\n//msg.payload.dev_id = flow.get('aygit2')||0;\n//msg.dev_id = flow.get('aygit2')||0;\n\n//var moo = global.get(\"foo\");\n//msg.moo = global.get(\"foo\");\n//msg.payload.moo = global.get(\"foo\");\nmsg.payload = flow.get('data');\nvar moo = flow.get(\"devid\");\n//var msg2 = { payload: moo };\n//msg.payload.moo = moo;\n//msg.moo = moo;\n\n\n if (moo == \"dragino_test\") {\n context.value1 = msg.payload;\n } else if (moo == \"dragino_test2\") { \n context.value2 = msg.payload;\n } else { \n context.value3 = msg.payload;\n }\n\n msg.pay1 = context.value1\n msg.pay2 = context.value2\n msg.pay3 = context.value3\n\n return msg;\n","outputs":1,"noerr":0,"x":827,"y":476.24999618530273,"wires":[["10e11238.3142fe","be465fd0.d3be","9e1553bd.e0f5b"]]},{"id":"ee0d17b3.b7f7b8","type":"debug","z":"ca6ebd5b.5b082","name":"","active":true,"console":"false","complete":"payload","x":1080.75,"y":176.24999618530273,"wires":[]},{"id":"10e11238.3142fe","type":"template","z":"ca6ebd5b.5b082","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"msg.pay1: {{pay1}}<br>\nmsg.pay2: {{pay2}}<br>\nmsg.pay3: {{pay3}}<br>\n<script></script>\n\n<!DOCTYPE html>\n<html>\n <head>\n <meta name=\"viewport\" content=\"initial-scale=1.0, user-scalable=no\">\n <meta charset=\"utf-8\">\n <title>Marker Clustering</title>\n <style>\n /* Always set the map height explicitly to define the size of the div\n * element that contains the map. */\n #map {\n height: 100%;\n }\n /* Optional: Makes the sample page fill the window. */\n html, body {\n height: 100%;\n margin: 0;\n padding: 0;\n }\n </style>\n </head>\n <body>\n <div id=\"map\"></div>\n <script>\n \n var loc1 = \"{{pay1}}\";\n var pos1 = loc1.indexOf(\",\");\n //var posit1 = loc1.indexOf(\"-\");\n var en1 = loc1.slice(0, pos1);\n en1 = Number(en1)\n var boy1 = loc1.slice(pos1+1,19)\n boy1 = Number(boy1)\n \n //var loc1 = \"3333\";\n \n \n var loc2 = \"{{pay2}}\";\n var pos2 = loc2.indexOf(\",\");\n //var posit2 = loc2.indexOf(\"-\");\n var en2 = loc2.slice(0, pos2);\n en2 = Number(en2)\n var boy2 = loc2.slice(pos2+1,19)\n boy2 = Number(boy2)\n \n \n document.write(boy2);\n \n \n var loc3 = \"{{pay3}}\";\n var pos3 = loc3.indexOf(\",\");\n var en3 = loc3.slice(0, pos3);\n en3 = Number(en3)\n var boy3 = loc3.slice(pos3+1,19)\n boy3 = Number(boy3)\n \n //en1: {en1}<br>\n \n //document.getElementById(\"demo\").innerHTML = \"text\";\n //document.getElementById(\"demo4\").innerHTML = text;\n //document.getElementById(\"demo2\").innerHTML = loc;\n //document.getElementById(\"demo3\").innerHTML = pos;\n //document.getElementById(\"demo5\").innerHTML = moo;\n //document.getElementById(\"demo3\").innerHTML = en;\n\n function initMap() {\n\n var map = new google.maps.Map(document.getElementById('map'), {\n zoom: 16,\n center: {lat: boy1, lng: en1}\n });\n\n // Create an array of alphabetical characters used to label the markers.\n var labels = 'ABCDEFGHIJKLMNOPQRSTUVWXYZ';\n\n // Add some markers to the map.\n // Note: The code uses the JavaScript Array.prototype.map() method to\n // create an array of markers based on a given \"locations\" array.\n // The map() method here has nothing to do with the Google Maps API.\n var markers = locations.map(function(location, i) {\n return new google.maps.Marker({\n position: location,\n label: labels[i % labels.length]\n });\n });\n\n // Add a marker clusterer to manage the markers.\n var markerCluster = new MarkerClusterer(map, markers,\n {imagePath: 'https://developers.google.com/maps/documentation/javascript/examples/markerclusterer/m'});\n }\n var locations = [\n {lat: boy1, lng: en1},\n {lat: boy2, lng: en2}\n ]\n </script>\n <script src=\"https://developers.google.com/maps/documentation/javascript/examples/markerclusterer/markerclusterer.js\">\n </script>\n <script async defer\n src=\"https://maps.googleapis.com/maps/api/js?key=AIzaSyBMIEpESoY2V1loeaGAjHeYPxZ-guLod8c&callback=initMap\">\n </script>\n </body>\n</html>","output":"str","x":1006.25,"y":601.2499961853027,"wires":[["217a20c4.1cc5c"]]},{"id":"37707509.1f6e5a","type":"debug","z":"ca6ebd5b.5b082","name":"","active":false,"console":"false","complete":"payload","x":629.75,"y":141.24999618530273,"wires":[]},{"id":"c9ebe8b7.e92e78","type":"inject","z":"ca6ebd5b.5b082","name":"","topic":"","payload":"{\"app_id\":\"lorawan-lmic-test\",\"dev_id\":\"dragino_test2\",\"hardware_serial\":\"9876543210123456\",\"port\":1,\"counter\":0,\"is_retry\":true,\"payload_raw\":\"MjguOTUyOTA4LDQxLjAyODUyNg==\",\"metadata\":{\"time\":\"2018-01-03T20:30:24.876104392Z\",\"frequency\":868.3,\"modulation\":\"LORA\",\"data_rate\":\"SF7BW125\",\"airtime\":71936000,\"coding_rate\":\"4/5\",\"gateways\":[{\"gtw_id\":\"eui-b827ebfffee9e43a\",\"timestamp\":975497379,\"time\":\"2018-01-03T20:30:24.628736Z\",\"channel\":1,\"rssi\":-30,\"snr\":8.8,\"rf_chain\":1,\"latitude\":41.02859,\"longitude\":28.95312}]}}","payloadType":"str","repeat":"","crontab":"","once":false,"x":302.50000762939453,"y":290.00000190734863,"wires":[["37707509.1f6e5a","dfc25552.be6be8","c9eaca60.7d3868"]]},{"id":"be465fd0.d3be","type":"debug","z":"ca6ebd5b.5b082","name":"","active":true,"console":"false","complete":"payload","x":1020.75,"y":430.24999618530273,"wires":[]},{"id":"77ad9d11.ba6fc4","type":"mqtt in","z":"ca6ebd5b.5b082","name":"MQTT Node - TheThingsNetwork","topic":"#","qos":"2","broker":"56d9cd69.f93e64","x":267.00000762939453,"y":176.24999904632568,"wires":[["37707509.1f6e5a","dfc25552.be6be8","c9eaca60.7d3868"]]},{"id":"9e1553bd.e0f5b","type":"debug","z":"ca6ebd5b.5b082","name":"","active":true,"console":"false","complete":"true","x":974.5278472900391,"y":790.7049026489258,"wires":[]},{"id":"56d9cd69.f93e64","type":"mqtt-broker","z":"ca6ebd5b.5b082","broker":"eu.thethings.network","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willRetain":"false","willPayload":"","birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":""}]
