This code works differently when I test it than when it gets a real message
I am confused with what is happening here.
Depending in the CPU temperature and a bit of other stuff, I want a RGB LED to blink depending on the message received.
[{"id":"ca5e1e7f2227fa14","type":"subflow","name":"Blinker","info":"2021 12 7  \nA subflow to send pulsing messages at a given interval to make something *flash*.\n\nConfigurable by setting `environment` variables in the node's settings.\n\n\n# **Output toggle node to send alternating messages at a specified frequency.**\n# \n\n## 3 things need to be set to configure this subflow\n1 - `delay`:  milliseconds between toggles (override with msg.delay)\n\n2 - `msg1`:   text message for state 1  \n\n3 - `msg2`:   text message for state 2 \n\n`msg.topic` is output and alternates between `msg1` and `msg2` to indicate which message is being sent.\n\n## Optional:\n`offmsg` - sent when it is reset.\n\nMay be handy to make sure things are *off*.\n\n## Input message\nTo start send `msg` (anything)\n\nTo stop, send `msg.reset`","category":"","in":[{"x":50,"y":80,"wires":[{"id":"3a95f6976aee6fd0"}]}],"out":[{"x":920,"y":70,"wires":[{"id":"f3b2b2634e2662cd","port":1},{"id":"a655faf0bc379507","port":0}]}],"env":[{"name":"delay","type":"num","value":""},{"name":"msg1","type":"str","value":""},{"name":"msg2","type":"str","value":""},{"name":"offmsg","type":"str","value":""}],"meta":{"module":"Toggler","version":"0.1.1","desc":"Toggles output between `msg1` and `msg2` set in node config"},"color":"#A6BBCF","icon":"node-red-contrib-bool-gate/switch.png","status":{"x":920,"y":170,"wires":[{"id":"502c279ae9a6f385","port":0}]}},{"id":"c53ebcc9e62a7552","type":"trigger","z":"ca5e1e7f2227fa14","name":"resend every x","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"-1","extend":false,"overrideDelay":true,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":430,"y":80,"wires":[["f3b2b2634e2662cd"]]},{"id":"f3b2b2634e2662cd","type":"function","z":"ca5e1e7f2227fa14","name":"toggle","func":"delete msg.delay;\nconst msg1 = {};\nlet c = context.get(\"counter\") ||0;\n\nif (c == 0) {\n    //  0\n    msg.payload = env.get(\"msg1\");\n    msg.topic = \"msg1\";\n} else if (c == 1) {\n    //  1\n    msg.payload = env.get(\"msg2\");\n    msg.topic = \"msg2\";\n};\n\nmsg1.payload = c;\nc = (c + 1) % 2;\ncontext.set(\"counter\",c);\nreturn [msg1,msg];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":80,"wires":[["502c279ae9a6f385"],[]]},{"id":"c183245c1a6a7fac","type":"switch","z":"ca5e1e7f2227fa14","name":"is reset?","property":"reset","propertyType":"msg","rules":[{"t":"nnull"}],"checkall":"true","repair":false,"outputs":1,"x":410,"y":170,"wires":[["a9be61803cd67654","6e3a0cdb44f6a994"]]},{"id":"a9be61803cd67654","type":"switch","z":"ca5e1e7f2227fa14","name":"off msg?","property":"offmsg","propertyType":"env","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":610,"y":130,"wires":[["a655faf0bc379507"]]},{"id":"a655faf0bc379507","type":"change","z":"ca5e1e7f2227fa14","name":"set off message","rules":[{"t":"set","p":"payload","pt":"msg","to":"offmsg","tot":"env"},{"t":"delete","p":"reset","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":790,"y":130,"wires":[[]]},{"id":"502c279ae9a6f385","type":"function","z":"ca5e1e7f2227fa14","name":"status","func":"const c = msg.payload;\n\nif (c == 0) {\n    msg.payload = ({text: \"msg1\"});\n} else if (c == 1) {\n    msg.payload = ({text: \"msg2\"});\n} else {\n    msg.payload = ({text:\"\"});\n};\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":760,"y":170,"wires":[[]]},{"id":"6e3a0cdb44f6a994","type":"change","z":"ca5e1e7f2227fa14","name":"reset","rules":[{"t":"set","p":"payload","pt":"msg","to":"2","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":600,"y":170,"wires":[["502c279ae9a6f385"]]},{"id":"3a95f6976aee6fd0","type":"function","z":"ca5e1e7f2227fa14","name":"set msg.delay","func":"msg.delay = msg.delay || env.get(\"delay\") || 1000;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":230,"y":80,"wires":[["c53ebcc9e62a7552","c183245c1a6a7fac"]]},{"id":"9126c47905fb62d6","type":"switch","z":"a1911aa3.c45be8","name":"`0`, `1` or `2` or `3`?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"num"},{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"}],"checkall":"true","repair":false,"outputs":4,"x":4080,"y":3510,"wires":[["01d195b3bb026ad5","5a9373335f02567c"],["bffe8e032a5daccc","334c2f69d774311f"],["8bb0e3cfc93dbcff","01834d6e867462bb"],["a1eb96fc0265fbad","8889342d532bc722"]]},{"id":"c636d91bf15c92bc","type":"change","z":"a1911aa3.c45be8","name":"LED number to use","rules":[{"t":"set","p":"led","pt":"msg","to":"HEALTH_LED","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":3945,"y":3510,"wires":[["9126c47905fb62d6"]],"l":false},{"id":"01d195b3bb026ad5","type":"subflow:ca5e1e7f2227fa14","z":"a1911aa3.c45be8","name":"Clear","env":[{"name":"delay","value":"800","type":"num"},{"name":"msg1","value":"10,0,10","type":"str"},{"name":"msg2","value":"0,0,6","type":"str"},{"name":"offmsg","value":"0,0,0","type":"str"}],"x":4350,"y":3460,"wires":[["7dd57846c3c570ce"]]},{"id":"5a9373335f02567c","type":"change","z":"a1911aa3.c45be8","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":4245,"y":3460,"wires":[["bffe8e032a5daccc","8bb0e3cfc93dbcff","a1eb96fc0265fbad"]],"l":false},{"id":"bffe8e032a5daccc","type":"subflow:ca5e1e7f2227fa14","z":"a1911aa3.c45be8","name":"Warn","env":[{"name":"delay","value":"1500","type":"num"},{"name":"msg1","value":"10,0,10","type":"str"},{"name":"msg2","value":"15,2,0","type":"str"},{"name":"offmsg","value":"0,0,0","type":"str"}],"x":4350,"y":3500,"wires":[["7dd57846c3c570ce"]]},{"id":"334c2f69d774311f","type":"change","z":"a1911aa3.c45be8","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":4245,"y":3500,"wires":[["8bb0e3cfc93dbcff","01d195b3bb026ad5","a1eb96fc0265fbad"]],"l":false},{"id":"8bb0e3cfc93dbcff","type":"subflow:ca5e1e7f2227fa14","z":"a1911aa3.c45be8","name":"Overheat","env":[{"name":"delay","value":"800","type":"num"},{"name":"msg1","value":"15,0,10","type":"str"},{"name":"msg2","value":"15,0,0","type":"str"},{"name":"offmsg","value":"0,0,0","type":"str"}],"x":4360,"y":3540,"wires":[["7dd57846c3c570ce"]]},{"id":"01834d6e867462bb","type":"change","z":"a1911aa3.c45be8","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":4245,"y":3540,"wires":[["bffe8e032a5daccc","01d195b3bb026ad5","a1eb96fc0265fbad"]],"l":false},{"id":"a1eb96fc0265fbad","type":"subflow:ca5e1e7f2227fa14","z":"a1911aa3.c45be8","name":"Fan Fail","env":[{"name":"delay","value":"1000","type":"num"},{"name":"msg1","value":"6,0,6","type":"str"},{"name":"msg2","value":"6,6,0","type":"str"},{"name":"offmsg","value":"0,0,0","type":"str"}],"x":4360,"y":3580,"wires":[["7dd57846c3c570ce"]]},{"id":"8889342d532bc722","type":"change","z":"a1911aa3.c45be8","name":"","rules":[{"t":"set","p":"reset","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":4245,"y":3580,"wires":[["01d195b3bb026ad5","bffe8e032a5daccc","8bb0e3cfc93dbcff"]],"l":false},{"id":"6094a497e4d8ebaa","type":"switch","z":"a1911aa3.c45be8","name":"Reset?","property":"reset","propertyType":"msg","rules":[{"t":"eq","v":"reset","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":3875,"y":3510,"wires":[["bffe8e032a5daccc","8bb0e3cfc93dbcff","01d195b3bb026ad5","a1eb96fc0265fbad"],["c636d91bf15c92bc"]],"l":false},{"id":"7dd57846c3c570ce","type":"change","z":"a1911aa3.c45be8","name":"","rules":[{"t":"set","p":"wipe","pt":"msg","to":"OVERWRITE","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":4525,"y":3500,"wires":[["416b3856d85d0540"]],"l":false},{"id":"99d39868512bbb84","type":"inject","z":"a1911aa3.c45be8","name":"Reset","props":[{"p":"reset","v":"reset","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":3740,"y":3660,"wires":[["6094a497e4d8ebaa"]]},{"id":"f906d60e4d4b549b","type":"inject","z":"a1911aa3.c45be8","name":"0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0","payloadType":"num","x":3740,"y":3700,"wires":[["6094a497e4d8ebaa"]]},{"id":"c77cc5998ba66449","type":"inject","z":"a1911aa3.c45be8","name":"1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":3740,"y":3740,"wires":[["6094a497e4d8ebaa"]]},{"id":"8505b3f82b02dd86","type":"inject","z":"a1911aa3.c45be8","name":"2","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"2","payloadType":"num","x":3740,"y":3780,"wires":[["6094a497e4d8ebaa"]]},{"id":"3f87036ffe169531","type":"inject","z":"a1911aa3.c45be8","name":"3","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"3","payloadType":"num","x":3740,"y":3820,"wires":[["6094a497e4d8ebaa"]]},{"id":"416b3856d85d0540","type":"function","z":"a1911aa3.c45be8","name":"","func":"var a = flow.get(\"HEALTH_LED\");\nmsg.payload = \"rgb,\"+a+\",\"+msg.payload;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":4630,"y":3500,"wires":[["7251b8fadcd5a291"]]},{"id":"7251b8fadcd5a291","type":"debug","z":"a1911aa3.c45be8","name":"RGB to LED","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":4740,"y":3670,"wires":[]}]
There are 4 input messages:
0
1
2
3
and RESET
reset is used to turn off any/all indications.
0 means all is clear and is an indication a high temperature was detected but since then all is good.
1 the temperature is approaching shutdown temperature.
2 the temperature has remained high for a time and so isn't about to go down and so the machine will be shutting down.
3 is an indicator that the fan hasn't started. Ideally the fan comes on below this temperature and so it wouldn't get here. This is a prewarning that things may be about to get worse.
The blink times are about 2 seconds on all of them.
But when the fan stalls (and when it it started and gets the temperature back down to where it should be, the blink rate is like 10 seconds.
But if I press the inject nodes and simulate the inputs: things work fine.
This bit of code does the conditions 0 and 3.
[{"id":"be31bc3135a585f5","type":"switch","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"47 / 40","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"47","vt":"num"},{"t":"lt","v":"40","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":2410,"y":240,"wires":[["b7798f7274bdbc6b"],["0d25769f6d5a0465","fa338c35c48fa03c"]]},{"id":"b7798f7274bdbc6b","type":"gate","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"","controlTopic":"control","defaultState":"open","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"memory","x":2565,"y":230,"wires":[["f732d8609971a705"]],"l":false},{"id":"f732d8609971a705","type":"change","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"close","rules":[{"t":"set","p":"payload","pt":"msg","to":"close","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":2625,"y":230,"wires":[["b7798f7274bdbc6b","84262946c1391dc1","60e4a1fff9b5f459","fa338c35c48fa03c"]],"l":false},{"id":"60e4a1fff9b5f459","type":"change","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"3","tot":"num"},{"t":"delete","p":"topic","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":2705,"y":230,"wires":[["2413e5b597dd5888","57d1d918035e5ebb","7cd5cc4e21ddb40f"]],"l":false},{"id":"0d25769f6d5a0465","type":"delay","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":2445,"y":290,"wires":[["46028b210df8f537"]],"l":false},{"id":"46028b210df8f537","type":"change","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"open","rules":[{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":2565,"y":290,"wires":[["b7798f7274bdbc6b","fa338c35c48fa03c"]],"l":false},{"id":"fa338c35c48fa03c","type":"gate","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"NOTE commands","controlTopic":"control","defaultState":"closed","openCmd":"close","closeCmd":"open","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"memory","x":2625,"y":290,"wires":[["4b0bbbd0ea330f4e","fa1fa4d1c61dd7f4"]],"l":false},{"id":"4b0bbbd0ea330f4e","type":"change","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"},{"t":"delete","p":"topic","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":2705,"y":290,"wires":[["2413e5b597dd5888","7cd5cc4e21ddb40f","57d1d918035e5ebb"]],"l":false},{"id":"57d1d918035e5ebb","type":"debug","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"message","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":2850,"y":290,"wires":[]},{"id":"923bf6b12abe8bfc","type":"inject","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"Fan fail","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":2400,"y":360,"wires":[["b7798f7274bdbc6b"]]},{"id":"f883787e2cb1ae29","type":"inject","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"Fan ok","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":2400,"y":410,"wires":[["0d25769f6d5a0465","fa338c35c48fa03c"]]},{"id":"48bc62ec79fd7732","type":"inject","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"Rest","props":[{"p":"reset","v":"reset","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":2400,"y":460,"wires":[["2413e5b597dd5888"]]},{"id":"2413e5b597dd5888","type":"link out","z":"9b7e7466.a4b698","g":"16280080c89be404","name":"Overheat message to LED","mode":"link","links":["64e96bee6cfc04ae","d8bb3a2db5b434ad"],"x":2910,"y":230,"wires":[],"l":true}]
The link out node goes to the input of that first block of code.
Conditions 1 and 2 are usually averted as I see the Fan stalled indication and go and give it a nudge and it is ok. (That's a whole other problem, I'm getting a new fan but ITMT)
And reset is when things have settled down and I don't need any blinking LEDs.
Normal temperaure range (with fan working) is 39 - 44 deg c.
So if it gets above 47, it sets off the Fan stalled warning and maintains it until the temperature gets back below 40.
Shouldn't the inject nodes have value of temperature as inject payload instead of timestamp ? (except for msg.reset), and the inject nodes also should be feeding the switch node marked (47/40) to simulate the real inputs from field.
Ah, ok.
The 0 1 2 3 values are set by the temperatures being at/above (or below) a value.
I know that can be seen as messy, but this way I don't have to look at the temperature's value to know what is happening. But the payload tells me.
In the second part/bit of code the timestamp is replaced with the value needed in the change node.
So the inject is only injecting a message which is then handled/changed in the next node.
Its just my OCD kicked in. so did you find out what is the issue?
No.
Still confused why when things go really wrong, the times are wrong for the blinking.
No problems with OCD. :wink:
