Is there an easier way to accomplish this? I am trying to create a pseudo three way light switch with two Tasmota switches. LobbyA has the load and LobbyB only sends on/off to LobbyA and back to Dashboard node.
This is similar to SmartHome Insteon "Linking." I am hoping for a better way so that 4,5,n-way switching can be implemented.
[{"id":"26f841ca.725036","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"6478eae2.ad6d94","type":"ui_switch","z":"26f841ca.725036","name":"Lobby Chandelier","label":"Lobby Chandelier","tooltip":"","group":"4bbcf441.3900e4","order":4,"width":"4","height":"1","passthru":false,"decouple":"false","topic":"House/LightLobbyA/cmnd/POWER","style":"","onvalue":"ON","onvalueType":"str","onicon":"","oncolor":"","offvalue":"OFF","offvalueType":"str","officon":"","offcolor":"","x":790,"y":600,"wires":[["a0834568.7e447"]],"inputLabels":["House/LightLobbyA/stat/POWER"]},{"id":"7ff3a66a.bd9c08","type":"mqtt in","z":"26f841ca.725036","name":"","topic":"House/LightLobbyA/stat/POWER","qos":"2","broker":"12dd1610.da9e4a","x":150,"y":600,"wires":[["78851a6c.3ba7fc","6478eae2.ad6d94","bb484857.94bc"]]},{"id":"93a76ea4.106b1","type":"debug","z":"26f841ca.725036","name":"Debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":990,"y":760,"wires":[],"inputLabels":["House/#"]},{"id":"52e0bc3b.617904","type":"mqtt in","z":"26f841ca.725036","name":"","topic":"House/LightLobbyB/stat/POWER","qos":"2","broker":"12dd1610.da9e4a","x":150,"y":700,"wires":[["d32d9cf3.23946"]]},{"id":"de649eb2.e3574","type":"ui_text","z":"26f841ca.725036","group":"4bbcf441.3900e4","order":6,"width":"2","height":"1","name":"","label":"","format":"<font color={{msg.color}} ><i class=\"fa fa-circle\" style=\"font-size:24px;\"></i></font>","layout":"row-spread","x":830,"y":640,"wires":[]},{"id":"78851a6c.3ba7fc","type":"function","z":"26f841ca.725036","name":"ColorSet","func":"msg.color = (msg.payload === \"ON\")?\"green\":\"grey\";\nreturn msg;","outputs":1,"noerr":0,"x":620,"y":640,"wires":[["de649eb2.e3574"]]},{"id":"d32d9cf3.23946","type":"function","z":"26f841ca.725036","name":"3wayBtoA","func":"var newMsg = { topic: \"House/LightLobbyA/cmnd/POWER\"}; \n\nvar LobbyA=flow.get('LobbyA') || 0;\n\n//if (msg.topic===\"House/LightLobbyA/stat/POWER\") {\n if (LobbyA===0) {\n if (msg.payload === \"ON\") {\n newMsg.payload = \"ON\";\n LobbyA=1\n flow.set('LobbyA',LobbyA);\n return newMsg; \n }\n }\n else {\n if (msg.payload === \"OFF\") {\n newMsg.payload = \"OFF\";\n LobbyA=0;\n flow.set('LobbyA',LobbyA);\n return newMsg; \n }\n }\n//}","outputs":1,"noerr":0,"x":500,"y":700,"wires":[["93a76ea4.106b1","acbfa624.3650d8"]],"inputLabels":["House/LightLobbyB/stat/POWER"]},{"id":"acbfa624.3650d8","type":"mqtt out","z":"26f841ca.725036","name":"","topic":"","qos":"","retain":"","broker":"12dd1610.da9e4a","x":990,"y":700,"wires":[]},{"id":"3cc1c6be.263a22","type":"inject","z":"26f841ca.725036","name":"","topic":"","payload":"ON","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":290,"y":760,"wires":[["d32d9cf3.23946"]],"outputLabels":["House/LightLobbyB/stat/POWER"]},{"id":"a270d733.96bef8","type":"inject","z":"26f841ca.725036","name":"","topic":"","payload":"OFF","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":290,"y":800,"wires":[["d32d9cf3.23946"]],"outputLabels":["House/LightLobbyB/stat/POWER"]},{"id":"bb484857.94bc","type":"function","z":"26f841ca.725036","name":"3wayAtoB","func":"var newMsg = { topic: \"House/LightLobbyB/cmnd/POWER\"}; \nvar LobbyB=flow.get('LobbyB') || 0;\n\n//if (msg.topic===\"House/LightLobbyA/stat/POWER\") {\n if (LobbyB===0) {\n if (msg.payload === \"ON\") {\n newMsg.payload = \"ON\";\n LobbyB=1\n flow.set('LobbyB',LobbyB);\n return newMsg; \n }\n }\n else {\n if (msg.payload === \"OFF\") {\n newMsg.payload = \"OFF\";\n LobbyB=0;\n flow.set('LobbyB',LobbyB);\n return newMsg; \n }\n }\n//}\n","outputs":1,"noerr":0,"x":500,"y":560,"wires":[["c7962c05.28c8e8","a0834568.7e447"]],"inputLabels":["House/LightLobbyA/stat/POWER"]},{"id":"a0834568.7e447","type":"mqtt out","z":"26f841ca.725036","name":"","topic":"","qos":"","retain":"","broker":"12dd1610.da9e4a","x":990,"y":600,"wires":[]},{"id":"c7962c05.28c8e8","type":"debug","z":"26f841ca.725036","name":"Debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":990,"y":540,"wires":[],"inputLabels":["House/#"]},{"id":"406daced.472844","type":"inject","z":"26f841ca.725036","name":"","topic":"","payload":"ON","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":290,"y":500,"wires":[["bb484857.94bc"]],"outputLabels":["House/LightLobbyA/stat/POWER"]},{"id":"a33d117e.961728","type":"inject","z":"26f841ca.725036","name":"","topic":"","payload":"OFF","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":290,"y":540,"wires":[["bb484857.94bc"]],"outputLabels":["House/LightLobbyA/stat/POWER"]},{"id":"4bbcf441.3900e4","type":"ui_group","z":"","name":"Home","tab":"3f9beed4.78316a","order":1,"disp":true,"width":"6","collapse":false},{"id":"12dd1610.da9e4a","type":"mqtt-broker","z":"","name":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"3f9beed4.78316a","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
