Hi @Colin , could you write me the function what would decode values from below respond:
{"_msgid":"6e52e585.d00a6c","timestamp":1623433951765,"statusCode":200,"headers":{"date":"Fri, 11 Jun 2021 17:52:32 GMT","server":"Apache","access-control-allow-origin":"*","access-control-allow-headers":"*","vary":"Accept","x-rate-limit-limit":"1000","x-rate-limit-remaining":"999","x-rate-limit-reset":"3","access-control-allow-credentials":"false","set-cookie":["_csrf=d4tZYLe-lb9jnWujx8DIuSIcAWxfm_QB; path=/; secure; httponly"],"x-frame-options":"sameorigin","content-length":"170","connection":"close","content-type":"application/json; charset=UTF-8","x-node-red-request-node":"7e6b7728"},"responseUrl":"https://api2.tigoenergy.com/api/v3/data/summary?system_id=52705","payload":"{\"summary\":{\"lifetime_energy_dc\":\"834644.65666667\",\"ytd_energy_dc\":\"834644.66\",\"daily_energy_dc\":\"14931.71\",\"last_power_dc\":458,\"updated_on\":\"2021-06-11T18:39:00+01:00\"}}","redirectList":[],"responseCookies":{"_csrf":{"path":"/","value":"d4tZYLe-lb9jnWujx8DIuSIcAWxfm_QB"}}}
from payload I am looking for:
lifetime_energy_dc
ytd_energy_dc
daily_energy_dc
last_power_dc
I am injecting the timestamp so this can be use by InfluxDB to place it in time.
Colin
11 June 2021 21:13
43
Sorry, I am away at the moment and unable to contribute.
No rush @Colin . Whenever you have a moment.
Colin
12 June 2021 10:24
45
Have you tried to work it out yourself?
As I mentioned before I have no programming experiences at all. Some simple changes in the code are not the problem but this is a bit too complicated.
Send this thru a json node and look at the output
I tried to send this to InfluxDB as json but getting error:
receiving in json:
{"_msgid":"aa87fcac.5b45","timestamp":1623532528259,"statusCode":200,"headers":{"date":"Sat, 12 Jun 2021 21:15:28 GMT","server":"Apache","access-control-allow-origin":"*","access-control-allow-headers":"*","vary":"Accept","x-rate-limit-limit":"1000","x-rate-limit-remaining":"999","x-rate-limit-reset":"3","access-control-allow-credentials":"false","set-cookie":["_csrf=JnmKc8FCTpdEKHGIn6lu-30nWcoj_ABR; path=/; secure; httponly"],"x-frame-options":"sameorigin","content-length":"168","connection":"close","content-type":"application/json; charset=UTF-8","x-node-red-request-node":"479acce0"},"responseUrl":"https://api2.tigoenergy.com/api/v3/data/summary?system_id=52705","payload":{"summary":{"lifetime_energy_dc":"859723.86666667","ytd_energy_dc":"859723.87","daily_energy_dc":"24233.87","last_power_dc":0,"updated_on":"2021-06-12T21:36:00+01:00"}},"redirectList":[],"responseCookies":{"_csrf":{"path":"/","value":"JnmKc8FCTpdEKHGIn6lu-30nWcoj_ABR"}}}
getting error:
TypeError: points.forEach is not a function
Please help me to capture values from
payload -> Summary ->
lifetime_energy_dc:
ytd_energy_dc:
daily_energy_dc:
Sorry, I was refering to your trying to get the data from msg.payload. In the sample data you provided. What you provided msg.payload is a string representation of an object so you need feed it thru a json node to turn it into an object. Then you will be able to address the data.
Thereās a great page in the docs that will explain how to use the debug panel to find the right path to any data item.
https://nodered.org/docs/user-guide/messages
