Can someone start me off where/how I begin to resolve the time difference.
I understand that Node-Red takes the time from the NTP server but it doesnt appear to be doing that.
I set the time in Home Assistant, adding a helper.
I am running Node-Red via Home Assistant
The time at the top of the debug output (11:00:09) is the time in the browser, not the node-red server.
You may have to ask on a Home Assistant forum why the time in node-red in HA is not showing correctly. Very few here use HA, preferring to do everything in node-red.
Thanks Colin.
It turned out to be a problem on my router reagrding IP addresses.
