Toggle node (subflow)
This is my effort at a node which could be handy for people who like flashy things on their dashboard.
You want to make a light blink rather than just be constantly on.
Though not complicated, this may save you some heart ache.
The toggle node does this for you and you can configure it with 3 settings:
1 - how fast you want it to toggle. (Set in milliseconds)
2 - The first message to be sent
3 - The second message to be sent
There is an optional offmsg which could be handy if you are blinking a light between two colours and want it off when the flashing has stopped.
Example flow included.
Subflow node:
[{"id":"ca5e1e7f2227fa14","type":"subflow","name":"Toggler","info":"# **Output toggle node to send alternating messages at a specified frequency.\n# **\n## 3 things need to be set to configure this subflow\n * 1 - `delay`:  milliseconds between toggls\n * 2 - `msg1`:   text message for state 1\n * 3 - `msg2`:   text message for state 2\n \n## Optional:\n`offmsg` - sent when it is reset.\nMay be handy to make sure things are *off*.\n\n## Input message\nTo start send `msg.payload` (anything)\n\nTo stop, send `msg.reset` (anything but don't use `timestamp`)\n\nSet the variables (`delay`, `msg1`, `msg2` and optionally `offmsg`) as environment variables in this node's config page.\n","category":"","in":[{"x":50,"y":80,"wires":[{"id":"bebc43cf227dc00a"},{"id":"8e3e5f0baa510afb"}]}],"out":[{"x":660,"y":80,"wires":[{"id":"7f2e332fb32d3422","port":0},{"id":"0666cb89ee9025cf","port":0}]}],"env":[],"meta":{"module":"Toggler","version":"0.1","desc":"Toggles output between `msg1` and `msg2` set in node config"},"color":"#A6BBCF","icon":"node-red-contrib-bool-gate/switch.png"},{"id":"a19da66d6694960f","type":"trigger","z":"ca5e1e7f2227fa14","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"-2","extend":false,"overrideDelay":true,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":380,"y":80,"wires":[["7f2e332fb32d3422"]]},{"id":"7f2e332fb32d3422","type":"function","z":"ca5e1e7f2227fa14","name":"toggle","func":"let c = context.get(\"counter\") ||0;\nif (c == 0)\n{\n    //  0\n    //msg.payload = \"rgb,1,0,18,12\";\n    msg.payload = env.get(\"msg1\");\n} else\nif (c == 1)\n{\n    //  1\n    //msg.payload = \"rgb,1,0,0,0\";\n    msg.payload = env.get(\"msg2\");\n}\nc = (c + 1) % 2;\ncontext.set(\"counter\",c);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":80,"wires":[[]]},{"id":"bebc43cf227dc00a","type":"change","z":"ca5e1e7f2227fa14","name":"","rules":[{"t":"set","p":"delay","pt":"msg","to":"delay","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":190,"y":80,"wires":[["a19da66d6694960f"]]},{"id":"8e3e5f0baa510afb","type":"switch","z":"ca5e1e7f2227fa14","name":"reset?","property":"reset","propertyType":"msg","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":160,"y":120,"wires":[["705f9da2fdc55481"]]},{"id":"705f9da2fdc55481","type":"switch","z":"ca5e1e7f2227fa14","name":"off msg?","property":"offmsg","propertyType":"env","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":360,"y":120,"wires":[["0666cb89ee9025cf"]]},{"id":"0666cb89ee9025cf","type":"change","z":"ca5e1e7f2227fa14","name":"set off message","rules":[{"t":"set","p":"payload","pt":"msg","to":"offmsg","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":120,"wires":[[]]},{"id":"2d6c0ca8e486046c","type":"subflow:ca5e1e7f2227fa14","z":"3b6b347467ee4c87","name":"","env":[{"name":"delay","value":"1000","type":"num"},{"name":"msg1","value":"message 1","type":"str"},{"name":"msg2","value":"message 2","type":"str"},{"name":"offmsg","value":"off","type":"str"}],"x":420,"y":280,"wires":[["6e383c3d1a21b3aa"]],"info":"** 3 things needed to configure\n1 - delay:  milliseconds between toggling\n2 - msg1:   text message 1\n3 - msg2:   text message 2\n"}]
Example flow:
[{"id":"ca5e1e7f2227fa14","type":"subflow","name":"Toggler","info":"# **Output toggle node to send alternating messages at a specified frequency.\n# **\n## 3 things need to be set to configure this subflow\n * 1 - `delay`:  milliseconds between toggls\n * 2 - `msg1`:   text message for state 1\n * 3 - `msg2`:   text message for state 2\n \n## Optional:\n`offmsg` - sent when it is reset.\nMay be handy to make sure things are *off*.\n\n## Input message\nTo start send `msg.payload` (anything)\n\nTo stop, send `msg.reset` (anything but don't use `timestamp`)\n\nSet the variables (`delay`, `msg1`, `msg2` and optionally `offmsg`) as environment variables in this node's config page.\n","category":"","in":[{"x":50,"y":80,"wires":[{"id":"bebc43cf227dc00a"},{"id":"8e3e5f0baa510afb"}]}],"out":[{"x":660,"y":80,"wires":[{"id":"7f2e332fb32d3422","port":0},{"id":"0666cb89ee9025cf","port":0}]}],"env":[],"meta":{"module":"Toggler","version":"0.1","desc":"Toggles output between `msg1` and `msg2` set in node config"},"color":"#A6BBCF","icon":"node-red-contrib-bool-gate/switch.png"},{"id":"a19da66d6694960f","type":"trigger","z":"ca5e1e7f2227fa14","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"-2","extend":false,"overrideDelay":true,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":380,"y":80,"wires":[["7f2e332fb32d3422"]]},{"id":"7f2e332fb32d3422","type":"function","z":"ca5e1e7f2227fa14","name":"toggle","func":"let c = context.get(\"counter\") ||0;\nif (c == 0)\n{\n    //  0\n    //msg.payload = \"rgb,1,0,18,12\";\n    msg.payload = env.get(\"msg1\");\n} else\nif (c == 1)\n{\n    //  1\n    //msg.payload = \"rgb,1,0,0,0\";\n    msg.payload = env.get(\"msg2\");\n}\nc = (c + 1) % 2;\ncontext.set(\"counter\",c);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":80,"wires":[[]]},{"id":"bebc43cf227dc00a","type":"change","z":"ca5e1e7f2227fa14","name":"","rules":[{"t":"set","p":"delay","pt":"msg","to":"delay","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":190,"y":80,"wires":[["a19da66d6694960f"]]},{"id":"8e3e5f0baa510afb","type":"switch","z":"ca5e1e7f2227fa14","name":"reset?","property":"reset","propertyType":"msg","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":160,"y":120,"wires":[["705f9da2fdc55481"]]},{"id":"705f9da2fdc55481","type":"switch","z":"ca5e1e7f2227fa14","name":"off msg?","property":"offmsg","propertyType":"env","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":360,"y":120,"wires":[["0666cb89ee9025cf"]]},{"id":"0666cb89ee9025cf","type":"change","z":"ca5e1e7f2227fa14","name":"set off message","rules":[{"t":"set","p":"payload","pt":"msg","to":"offmsg","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":120,"wires":[[]]},{"id":"7679fb92b3291a98","type":"inject","z":"3b6b347467ee4c87","name":"start","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":210,"y":260,"wires":[["2d6c0ca8e486046c"]]},{"id":"fc206ec3b72d19b7","type":"inject","z":"3b6b347467ee4c87","name":"stop","props":[{"p":"reset","v":"blah","vt":"str"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":210,"y":300,"wires":[["2d6c0ca8e486046c"]]},{"id":"6e383c3d1a21b3aa","type":"debug","z":"3b6b347467ee4c87","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":580,"y":280,"wires":[]},{"id":"2d6c0ca8e486046c","type":"subflow:ca5e1e7f2227fa14","z":"3b6b347467ee4c87","name":"","env":[{"name":"delay","value":"1000","type":"num"},{"name":"msg1","value":"message 1","type":"str"},{"name":"msg2","value":"message 2","type":"str"},{"name":"offmsg","value":"off","type":"str"}],"x":420,"y":280,"wires":[["6e383c3d1a21b3aa"]],"info":"** 3 things needed to configure\n1 - delay:  milliseconds between toggling\n2 - msg1:   text message 1\n3 - msg2:   text message 2\n"}]
Enjoy!
:slight_smile:
Ok, I fixed a small problem with the reset input.
This works a bit better with what it will accept.
[{"id":"ca5e1e7f2227fa14","type":"subflow","name":"Toggler","info":"# **Output toggle node to send alternating messages at a specified frequency.\n# **\n## 3 things need to be set to configure this subflow\n * 1 - `delay`:  milliseconds between toggls\n * 2 - `msg1`:   text message for state 1\n * 3 - `msg2`:   text message for state 2\n \n## Optional:\n`offmsg` - sent when it is reset.\nMay be handy to make sure things are *off*.\n\n## Input message\nTo start send `msg.payload` (anything)\n\nTo stop, send `msg.reset` (anything but don't use `timestamp`)\n\nSet the variables (`delay`, `msg1`, `msg2` and optionally `offmsg`) as environment variables in this node's config page.\n","category":"","in":[{"x":50,"y":80,"wires":[{"id":"bebc43cf227dc00a"},{"id":"8e3e5f0baa510afb"}]}],"out":[{"x":660,"y":80,"wires":[{"id":"7f2e332fb32d3422","port":0},{"id":"0666cb89ee9025cf","port":0}]}],"env":[],"meta":{"module":"Toggler","version":"0.1","desc":"Toggles output between `msg1` and `msg2` set in node config"},"color":"#A6BBCF","icon":"node-red-contrib-bool-gate/switch.png"},{"id":"a19da66d6694960f","type":"trigger","z":"ca5e1e7f2227fa14","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"-2","extend":false,"overrideDelay":true,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":380,"y":80,"wires":[["7f2e332fb32d3422"]]},{"id":"7f2e332fb32d3422","type":"function","z":"ca5e1e7f2227fa14","name":"toggle","func":"let c = context.get(\"counter\") ||0;\nif (c == 0)\n{\n    //  0\n    //msg.payload = \"rgb,1,0,18,12\";\n    msg.payload = env.get(\"msg1\");\n} else\nif (c == 1)\n{\n    //  1\n    //msg.payload = \"rgb,1,0,0,0\";\n    msg.payload = env.get(\"msg2\");\n}\nc = (c + 1) % 2;\ncontext.set(\"counter\",c);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":80,"wires":[[]]},{"id":"bebc43cf227dc00a","type":"change","z":"ca5e1e7f2227fa14","name":"","rules":[{"t":"set","p":"delay","pt":"msg","to":"delay","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":190,"y":80,"wires":[["a19da66d6694960f"]]},{"id":"8e3e5f0baa510afb","type":"switch","z":"ca5e1e7f2227fa14","name":"reset?","property":"reset","propertyType":"msg","rules":[{"t":"nnull"}],"checkall":"true","repair":false,"outputs":1,"x":160,"y":120,"wires":[["705f9da2fdc55481"]]},{"id":"705f9da2fdc55481","type":"switch","z":"ca5e1e7f2227fa14","name":"off msg?","property":"offmsg","propertyType":"env","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":360,"y":120,"wires":[["0666cb89ee9025cf"]]},{"id":"0666cb89ee9025cf","type":"change","z":"ca5e1e7f2227fa14","name":"set off message","rules":[{"t":"set","p":"payload","pt":"msg","to":"offmsg","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":120,"wires":[[]]},{"id":"171d974123a15379","type":"subflow:ca5e1e7f2227fa14","z":"7e987ddf260bdf0d","name":"","env":[{"name":"delay","value":"1000","type":"num"},{"name":"msg1","value":"message 1","type":"str"},{"name":"msg2","value":"message 2","type":"str"},{"name":"offmsg","value":"message 2","type":"str"}],"x":410,"y":1190,"wires":[["03dd24229eac2d14"]],"info":"** 3 things needed to configure\n1 - delay:  milliseconds between toggling\n2 - msg1:   text message 1\n3 - msg2:   text message 2\n"}]
Hi, I had customised something like this for my project. i had also put status message by copying from somewhere else. Have added that bit in your code.
please give comments, is this the way to do status ?
[{"id":"ca5e1e7f2227fa14","type":"subflow","name":"Toggler","info":"# **Output toggle node to send alternating messages at a specified frequency.\n# **\n## 3 things need to be set to configure this subflow\n * 1 - `delay`:  milliseconds between toggls\n * 2 - `msg1`:   text message for state 1\n * 3 - `msg2`:   text message for state 2\n \n## Optional:\n`offmsg` - sent when it is reset.\nMay be handy to make sure things are *off*.\n\n## Input message\nTo start send `msg.payload` (anything)\n\nTo stop, send `msg.reset` (anything but don't use `timestamp`)\n\nSet the variables (`delay`, `msg1`, `msg2` and optionally `offmsg`) as environment variables in this node's config page.\n","category":"","in":[{"x":50,"y":80,"wires":[{"id":"bebc43cf227dc00a"},{"id":"8e3e5f0baa510afb"}]}],"out":[{"x":660,"y":80,"wires":[{"id":"7f2e332fb32d3422","port":0},{"id":"0666cb89ee9025cf","port":0}]}],"env":[],"meta":{"module":"Toggler","version":"0.1","desc":"Toggles output between `msg1` and `msg2` set in node config"},"color":"#A6BBCF","icon":"node-red-contrib-bool-gate/switch.png","status":{"x":720,"y":250,"wires":[{"id":"35b8fce3ecba3c2c","port":1},{"id":"16fed96dce14c03b","port":1}]}},{"id":"a19da66d6694960f","type":"trigger","z":"ca5e1e7f2227fa14","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"-2","extend":false,"overrideDelay":true,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":380,"y":80,"wires":[["7f2e332fb32d3422"]]},{"id":"7f2e332fb32d3422","type":"function","z":"ca5e1e7f2227fa14","name":"toggle","func":"let c = context.get(\"counter\") ||0;\nif (c == 0)\n{\n    //  0\n    //msg.payload = \"rgb,1,0,18,12\";\n    msg.payload = env.get(\"msg1\");\n} else\nif (c == 1)\n{\n    //  1\n    //msg.payload = \"rgb,1,0,0,0\";\n    msg.payload = env.get(\"msg2\");\n}\nc = (c + 1) % 2;\ncontext.set(\"counter\",c);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":540,"y":80,"wires":[["04d482a4531aeafe"]]},{"id":"bebc43cf227dc00a","type":"change","z":"ca5e1e7f2227fa14","name":"","rules":[{"t":"set","p":"delay","pt":"msg","to":"delay","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":190,"y":80,"wires":[["a19da66d6694960f"]]},{"id":"8e3e5f0baa510afb","type":"switch","z":"ca5e1e7f2227fa14","name":"reset?","property":"reset","propertyType":"msg","rules":[{"t":"nnull"}],"checkall":"true","repair":false,"outputs":1,"x":160,"y":120,"wires":[["705f9da2fdc55481"]]},{"id":"705f9da2fdc55481","type":"switch","z":"ca5e1e7f2227fa14","name":"off msg?","property":"offmsg","propertyType":"env","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":330,"y":120,"wires":[["0666cb89ee9025cf"]]},{"id":"0666cb89ee9025cf","type":"change","z":"ca5e1e7f2227fa14","name":"set off message","rules":[{"t":"set","p":"payload","pt":"msg","to":"offmsg","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":120,"wires":[[]]},{"id":"35b8fce3ecba3c2c","type":"function","z":"ca5e1e7f2227fa14","name":"Red-Hiding","func":"let statusMsg = { fill:\"red\", shape:\"ring\", text:\"Message 1\" };\nreturn [msg, {payload:statusMsg}];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":510,"y":250,"wires":[[],[]]},{"id":"16fed96dce14c03b","type":"function","z":"ca5e1e7f2227fa14","name":"Green-Showing","func":"let statusMsg = { fill:\"green\", shape:\"dot\", text:\"Message 2\" };\nreturn [msg, {payload:statusMsg}];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":520,"y":290,"wires":[[],[]]},{"id":"04d482a4531aeafe","type":"switch","z":"ca5e1e7f2227fa14","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"message 1","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":420,"y":190,"wires":[["35b8fce3ecba3c2c"],["16fed96dce14c03b"]]},{"id":"171d974123a15379","type":"subflow:ca5e1e7f2227fa14","z":"80b11551520ed2c0","name":"","env":[{"name":"delay","value":"1000","type":"num"},{"name":"msg1","value":"message 1","type":"str"},{"name":"msg2","value":"message 2","type":"str"},{"name":"offmsg","value":"message 2","type":"str"}],"x":1950,"y":3350,"wires":[["f94723c8885856e9"]],"info":"** 3 things needed to configure\n1 - delay:  milliseconds between toggling\n2 - msg1:   text message 1\n3 - msg2:   text message 2\n"}]
Is this a node you wrote or mine with extra stuff added?
its yours, sorry, i just added my bit to it, my node was highly customised to share
There are so many holes in what you added sorry.
I see what you tried to do, but it not really correct in how it was done.
would highly appreciate if you could show me how to do it.
you see, its actually me 'trying_to_learn'
To do what you want I am going to have to sit down and study for a while.
This is version 1.1 of the node with an added text indicator to show it is toggling.
[{"id":"ca5e1e7f2227fa14","type":"subflow","name":"Toggler","info":"# **Output toggle node to send alternating messages at a specified frequency.\n# **\n## 3 things need to be set to configure this subflow\n * 1 - `delay`:  milliseconds between toggls\n * 2 - `msg1`:   text message for state 1\n * 3 - `msg2`:   text message for state 2\n \n## Optional:\n`offmsg` - sent when it is reset.\nMay be handy to make sure things are *off*.\n\n## Input message\nTo start send `msg.payload` (anything)\n\nTo stop, send `msg.reset` (anything but don't use `timestamp`)\n\nSet the variables (`delay`, `msg1`, `msg2` and optionally `offmsg`) as environment variables in this node's config page.\n","category":"","in":[{"x":50,"y":80,"wires":[{"id":"bebc43cf227dc00a"},{"id":"8e3e5f0baa510afb"}]}],"out":[{"x":660,"y":80,"wires":[{"id":"7f2e332fb32d3422","port":0},{"id":"0666cb89ee9025cf","port":0}]}],"env":[],"meta":{"module":"Toggler","version":"0.1.1","desc":"Toggles output between `msg1` and `msg2` set in node config"},"color":"#A6BBCF","icon":"node-red-contrib-bool-gate/switch.png","status":{"x":660,"y":180,"wires":[{"id":"b1feb246df6a838b","port":0}]}},{"id":"a19da66d6694960f","type":"trigger","z":"ca5e1e7f2227fa14","name":"","op1":"1","op2":"0","op1type":"str","op2type":"str","duration":"-2","extend":false,"overrideDelay":true,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":380,"y":80,"wires":[["7f2e332fb32d3422"]]},{"id":"7f2e332fb32d3422","type":"function","z":"ca5e1e7f2227fa14","name":"toggle","func":"msg1 = {};\nlet c = context.get(\"counter\") ||0;\nif (c == 0)\n{\n    //  0\n    //msg.payload = \"rgb,1,0,18,12\";\n    msg.payload = env.get(\"msg1\");\n} else\nif (c == 1)\n{\n    //  1\n    //msg.payload = \"rgb,1,0,0,0\";\n    msg.payload = env.get(\"msg2\");\n}\nmsg1.payload = c;\nc = (c + 1) % 2;\ncontext.set(\"counter\",c);\nreturn [msg,msg1];","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":80,"wires":[[],["b1feb246df6a838b"]]},{"id":"bebc43cf227dc00a","type":"change","z":"ca5e1e7f2227fa14","name":"","rules":[{"t":"set","p":"delay","pt":"msg","to":"delay","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":190,"y":80,"wires":[["a19da66d6694960f"]]},{"id":"8e3e5f0baa510afb","type":"switch","z":"ca5e1e7f2227fa14","name":"reset?","property":"reset","propertyType":"msg","rules":[{"t":"nnull"}],"checkall":"true","repair":false,"outputs":1,"x":160,"y":120,"wires":[["705f9da2fdc55481","490014d846f3ef05"]]},{"id":"705f9da2fdc55481","type":"switch","z":"ca5e1e7f2227fa14","name":"off msg?","property":"offmsg","propertyType":"env","rules":[{"t":"nempty"}],"checkall":"true","repair":false,"outputs":1,"x":360,"y":120,"wires":[["0666cb89ee9025cf"]]},{"id":"0666cb89ee9025cf","type":"change","z":"ca5e1e7f2227fa14","name":"set off message","rules":[{"t":"set","p":"payload","pt":"msg","to":"offmsg","tot":"env"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":120,"wires":[[]]},{"id":"b1feb246df6a838b","type":"function","z":"ca5e1e7f2227fa14","name":"","func":"let c = msg.payload;\nif (c == 0)\n{\n    msg.payload = ({text: \"A\"});\n} else if (c == 1)\n{\n    msg.payload = ({text: \"B\"});\n} else\n    msg.payload = ({text:\" \"});\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":180,"wires":[[]]},{"id":"490014d846f3ef05","type":"change","z":"ca5e1e7f2227fa14","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"reset","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":325,"y":180,"wires":[["b1feb246df6a838b"]],"l":false},{"id":"171d974123a15379","type":"subflow:ca5e1e7f2227fa14","z":"7e987ddf260bdf0d","name":"","env":[{"name":"delay","value":"1000","type":"num"},{"name":"msg1","value":"message 1","type":"str"},{"name":"msg2","value":"message 2","type":"str"},{"name":"offmsg","value":"message 2","type":"str"}],"x":410,"y":1190,"wires":[["03dd24229eac2d14"]],"info":"** 3 things needed to configure\n1 - delay:  milliseconds between toggling\n2 - msg1:   text message 1\n3 - msg2:   text message 2\n"}]
