Hi. I have created three switch toggles (ui-switch) to control the visibility of three groups (B, Y, and Dev). Each group makes an HTTP GET request to a server and displays the values of two variables (A and B) on two text nodes. Based on the value of variable A, I use then, the audio-out node to play a .wav sound hosted on the web also using HTTP GET. Is there a way that I can check in a function if a group is visible, and if it is not, not to play the sound or even not to make the HTTP request to play the audio?
Here is the code just in case:
[{"id":"0ff5107726251a7b","type":"ui_switch","z":"af973086eb22abf7","name":"","label":"B","tooltip":"","group":"9967f535930bde14","order":3,"width":3,"height":1,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"{\"group\":{\"show\":[\"Dashboard_Blue\"]}}","onvalueType":"json","onicon":"","oncolor":"","offvalue":"{\"group\":{\"hide\":[\"Dashboard_Blue\"]}}","offvalueType":"json","officon":"","offcolor":"","animate":false,"className":"","x":1070,"y":160,"wires":[["4161f1cbf1b491ec"]]},{"id":"d0cdd265512356d6","type":"ui_switch","z":"af973086eb22abf7","name":"","label":"Y","tooltip":"","group":"9967f535930bde14","order":2,"width":3,"height":1,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"{\"group\":{\"show\":[\"Dashboard_Yellow\"]}}","onvalueType":"json","onicon":"","oncolor":"","offvalue":"{\"group\":{\"hide\":[\"Dashboard_Yellow\"]}}","offvalueType":"json","officon":"","offcolor":"","animate":false,"className":"","x":1070,"y":200,"wires":[["4161f1cbf1b491ec"]]},{"id":"e81f690a506457e3","type":"ui_switch","z":"af973086eb22abf7","name":"","label":"R","tooltip":"","group":"9967f535930bde14","order":1,"width":3,"height":1,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"","onvalueType":"json","onicon":"","oncolor":"","offvalue":"","offvalueType":"json","officon":"","offcolor":"","animate":false,"className":"","x":1070,"y":240,"wires":[["4161f1cbf1b491ec"]]},{"id":"bf91250ea47f8d98","type":"ui_switch","z":"af973086eb22abf7","name":"","label":"Dev","tooltip":"","group":"9967f535930bde14","order":4,"width":3,"height":1,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"{\"group\":{\"show\":[\"Dashboard_Dev\"]}}","onvalueType":"json","onicon":"","oncolor":"","offvalue":"{\"group\":{\"hide\":[\"Dashboard_Dev\"]}}","offvalueType":"json","officon":"","offcolor":"","animate":false,"className":"","x":1070,"y":280,"wires":[["4161f1cbf1b491ec"]]},{"id":"4161f1cbf1b491ec","type":"ui_ui_control","z":"af973086eb22abf7","name":"","events":"all","x":1260,"y":220,"wires":[[]]},{"id":"791bca6e1658bdf1","type":"comment","z":"af973086eb22abf7","name":"Toggles to make groups visible","info":"","x":1150,"y":100,"wires":[]},{"id":"4e76df42e55de63f","type":"inject","z":"af973086eb22abf7","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"6","crontab":"","once":true,"onceDelay":"0.20","topic":"","payload":"","payloadType":"date","x":90,"y":980,"wires":[["85c8daa2ccc414e8"]]},{"id":"2c23d8a49ddad178","type":"http request","z":"af973086eb22abf7","name":"","method":"GET","ret":"txt","paytoqs":"ignore","url":"http://192.168.0.75/code","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"x":390,"y":880,"wires":[[]]},{"id":"c8a905611e1d6e33","type":"json","z":"af973086eb22abf7","name":"","property":"payload","action":"","pretty":false,"x":570,"y":880,"wires":[[]]},{"id":"7a415a86f93310f1","type":"change","z":"af973086eb22abf7","name":"Code","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.code","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":920,"wires":[["5fb3ee0d69a81bde"]]},{"id":"8f218f33931e2770","type":"debug","z":"af973086eb22abf7","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1150,"y":900,"wires":[]},{"id":"85c8daa2ccc414e8","type":"function","z":"af973086eb22abf7","name":"","func":"source = Math.round(Math.random()*10);\ncode = Math.round((Math.random()*30)+0);\n\nmsg.payload = {\n source, code\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":380,"y":980,"wires":[["7a415a86f93310f1","2fd3f7c4bede209d"]]},{"id":"08ed86aacd811aa9","type":"ui_text","z":"af973086eb22abf7","group":"2b7cad2b43afc9b8","order":2,"width":0,"height":0,"name":"","label":"Code Blue_Puppet","format":"{{msg.payload}}","layout":"row-spread","className":"","x":1170,"y":940,"wires":[]},{"id":"5fb3ee0d69a81bde","type":"rbe","z":"af973086eb22abf7","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":870,"y":920,"wires":[["08ed86aacd811aa9","d6b81f1c0459ea2e"]]},{"id":"2fd3f7c4bede209d","type":"change","z":"af973086eb22abf7","name":"Source","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload.source","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":720,"y":840,"wires":[["146f0a14fa8f9b2c"]]},{"id":"146f0a14fa8f9b2c","type":"rbe","z":"af973086eb22abf7","name":"","func":"rbe","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":870,"y":840,"wires":[["9cf214c84060a29e"]]},{"id":"a5e1b6e52c6727f2","type":"debug","z":"af973086eb22abf7","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1150,"y":860,"wires":[]},{"id":"9cf214c84060a29e","type":"ui_text","z":"af973086eb22abf7","group":"2b7cad2b43afc9b8","order":1,"width":0,"height":0,"name":"","label":"Source Blue_Puppet","format":"{{msg.payload}}","layout":"row-spread","className":"","x":1180,"y":820,"wires":[]},{"id":"8a8ee83993d94625","type":"comment","z":"af973086eb22abf7","name":"Read from Puppet","info":"","x":110,"y":920,"wires":[]},{"id":"d6b81f1c0459ea2e","type":"function","z":"af973086eb22abf7","name":"","func":"var codeVal = msg.payload;\n\nmsg.url = \"http://nonmyth.danielecheverri.co/numbers/\"+codeVal+\".wav\";\n\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":880,"y":980,"wires":[["1d0e69fce9194438"]]},{"id":"1d0e69fce9194438","type":"http request","z":"af973086eb22abf7","name":"Download m3","method":"GET","ret":"bin","paytoqs":"ignore","url":"","tls":"","persist":false,"proxy":"","authType":"","senderr":false,"credentials":{},"x":900,"y":1020,"wires":[["486ca02fa1e797ce"]]},{"id":"486ca02fa1e797ce","type":"ui_audio","z":"af973086eb22abf7","name":"BlueOut","group":"2b7cad2b43afc9b8","voice":"","always":true,"x":1140,"y":1020,"wires":[]},{"id":"9967f535930bde14","type":"ui_group","name":"Toggles","tab":"e562a4a.39a9e58","order":1,"disp":false,"width":6,"collapse":false,"className":""},{"id":"2b7cad2b43afc9b8","type":"ui_group","name":"Blue","tab":"e562a4a.39a9e58","order":3,"disp":true,"width":6,"collapse":false,"className":""},{"id":"e562a4a.39a9e58","type":"ui_tab","name":"Dashboard","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
