Hi everyone!
Can anyone help me one Track node?
I did it this way but it only returned the map... and i need to return a track with the value i return...
Function 1:
Function 2:
Function 3:
Function 4:
Wrong Result:
Hi, I'm not sure I understand the problem you are asking about ? The messages look ok. You need to wait for the map to connect (green under the map node) before you press inject. If you want a track then you need to add a track node as well.
For the top part of the flow yes
