So, managed to get the information I was after from my GL.iNET Router.
Below is a flow that gets the Security Token and then you can GET or POST a URL to the router to obtain the client list and cell information. If it is of use to anyone, well, here it is...
"id": "0f814aab11ca6a59",
"type": "inject",
"z": "362ac6b30a7e45bc",
"name": "Click me",
"props": [],
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payloadType": "str",
"x": 140,
"y": 320,
"360590ca88c2741e"
"id": "360590ca88c2741e",
"type": "function",
"name": "Curl token",
"func": "//original curl: \n//\n//curl http://1.2.3.4/api/router/login -d \"pwd=XXYYZZAABB\"\nmsg.headers = {}; \n\nmsg.method = \"post\";\nmsg.url = \"http://<IP_ADDRESS>/api/router/login\";\nmsg.payload = \"<PASSWORD>\";\nmsg.headers[\"Content-Type\"] = \"application/x-www-form-urlencoded\";\nmsg.cookies = null;\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 370,
"y": 320,
"af82bb868566726f"
"id": "af82bb868566726f",
"type": "http request",
"method": "use",
"ret": "txt",
"paytoqs": "ignore",
"url": "",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"credentials": {},
"x": 550,
"y": 320,
"ea345df5628fa288"
"id": "ea345df5628fa288",
"type": "function",
"name": "global.curlToken",
"func": "let curlToken = msg.payload;\nlet curlTest = msg.payload.slice(8, 9);\nmsg.test = curlTest;\n\nif (curlTest === \"0\"){\n curlToken = curlToken.slice(19, 51);\n global.set('curlToken', curlToken);\n msg.payload = \"Token OK\";\n} else {\n msg.payload = \"Token Error\";\n}\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 740,
"y": 320,
"c402da04521e4baa"
"id": "7fa01b1b8e12231b",
"method": "use",
"ret": "txt",
"url": "http://<IP_ADDRESS>/{{{topic}}}",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"credentials": {
"user": "",
"password": ""
"x": 550,
"y": 360,
"78aa4714ee584214"
"id": "c402da04521e4baa",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1030,
"y": 360,
"id": "3995f987df0f97bc",
"type": "inject",
"props": [
"p": "topic",
"vt": "str"
"p": "method",
"v": "get",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "api/client/list",
"x": 130,
"y": 360,
"ea6f81fcf7ea3965"
"id": "ea6f81fcf7ea3965",
"type": "function",
"func": "msg.headers = {}; \n\nlet curlToken = global.get('curlToken');\n\nmsg.headers[\"Content-Type\"] = 'application/x-www-form-urlencoded';\nmsg.headers[\"Authorization\"] = curlToken;\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 370,
"y": 360,
"7fa01b1b8e12231b"
"id": "c4fb67c8a0f07f31",
"type": "function",
"func": "msg.headers = {}; \n\nlet curlToken = global.get('curlToken');\n\nmsg.headers[\"Content-Type\"] = \"application/x-www-form-urlencoded\";\nmsg.headers[\"Authorization\"] = curlToken;\nmsg.payload = \"modem_id=1&bus=1-1.2\";\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 370,
"y": 400,
"1220b9f446f8bb67"
"id": "e09431020a17d4eb",
"type": "inject",
"props": [
"p": "topic",
"vt": "str"
"p": "method",
"v": "post",
"vt": "str"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "api/modem/cells/get",
"x": 160,
"y": 400,
"c4fb67c8a0f07f31"
"id": "78aa4714ee584214",
"type": "json",
"property": "payload",
"action": "",
"pretty": false,
"x": 710,
"y": 360,
"c402da04521e4baa"
"id": "1220b9f446f8bb67",
"method": "use",
"ret": "txt",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"credentials": {
"user": "",
"password": ""
"x": 550,
"y": 400,
"fcd29dc0e286e61e"
"id": "fcd29dc0e286e61e",
"type": "json",
"action": "",
"pretty": false,
"x": 710,
"y": 400,
"9c0b88b96b6039d3"
"id": "9c0b88b96b6039d3",
"type": "function",
"func": "let rssi = msg.payload.cells[0].rssi\nmsg.payload = msg.payload.cells[0].rssi;\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 860,
"y": 400,
"c402da04521e4baa"
Thank you everyone for your help!
EDIT: Modified Flow with thanks to @UnborN and @E1cid for making it easier and less convoluted!!
