Trigger dashboard notification based on chart data from .txt
Hi so I am having an issue; I want a notification to appear on my dashboard based on the result on my chart.
For example, if my total on my chart is above 42, a notification to be triggered.
Here is my flow, please let me know if additional data is needed:
[{"id":"83afaffb.3b3b8","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"5b05e4d0.376cbc","type":"ui_date_picker","z":"83afaffb.3b3b8","d":true,"name":"","label":"date","group":"f2049ccb.8069d","order":3,"width":0,"height":0,"passthru":true,"topic":"","x":90,"y":200,"wires":[[]]},{"id":"34e601e9.f5a0fe","type":"ui_text","z":"83afaffb.3b3b8","d":true,"group":"f2049ccb.8069d","order":1,"width":0,"height":0,"name":"","label":"Customer Tracker","format":"{{msg.payload}}","layout":"row-spread","x":330,"y":160,"wires":[]},{"id":"49a290d7.b57b2","type":"ui_text","z":"83afaffb.3b3b8","d":true,"group":"f2049ccb.8069d","order":2,"width":0,"height":0,"name":"","label":"Current visitors: ","format":"{{msg.currentVisitors}}","layout":"row-spread","x":120,"y":160,"wires":[]},{"id":"5dac79d1.b216c8","type":"ui_chart","z":"83afaffb.3b3b8","d":true,"name":"","group":"f2049ccb.8069d","order":4,"width":0,"height":0,"label":"Visitors in the Store","chartType":"line","legend":"false","xformat":"dd HH:mm","interpolate":"linear","nodata":"","dot":false,"ymin":"0","ymax":"500","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":250,"y":200,"wires":[[]]},{"id":"9a93de94.d4315","type":"ui_toast","z":"83afaffb.3b3b8","d":true,"position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":true,"topic":"","name":"Attendant needed for Cart Collection","x":330,"y":240,"wires":[]},{"id":"fc31e116.b524b","type":"ui_text_input","z":"83afaffb.3b3b8","d":true,"name":"","label":"","tooltip":"","group":"f2049ccb.8069d","order":5,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":100,"y":240,"wires":[["9a93de94.d4315"]]},{"id":"a90dcc8a.b385d","type":"inject","z":"83afaffb.3b3b8","d":true,"name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":100,"y":400,"wires":[["5b7951c7.b0fa5"]]},{"id":"77bf8b0.fc7be74","type":"debug","z":"83afaffb.3b3b8","d":true,"name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":290,"y":500,"wires":[]},{"id":"5b7951c7.b0fa5","type":"function","z":"83afaffb.3b3b8","d":true,"name":"","func":"for (var i=0; i<400; i++){\n    node.send({payload:i});\n}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":100,"y":460,"wires":[["2241e549.57e14a"]]},{"id":"2241e549.57e14a","type":"delay","z":"83afaffb.3b3b8","d":true,"name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":110,"y":520,"wires":[["77bf8b0.fc7be74"]]},{"id":"af5a72c.966599","type":"inject","z":"83afaffb.3b3b8","d":true,"name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"100","payloadType":"num","x":80,"y":760,"wires":[["a17bdf83.68828"]]},{"id":"a17bdf83.68828","type":"function","z":"83afaffb.3b3b8","d":true,"name":"","func":"m = msg.payload;\nt = msg.topic;\n\nif (m === null) {\n        n = 0;\n    }\n\n  /*  \n  var n = localStorage.getItem('on_load_counter');\n\n    if (n === null) {\n        n = 0;\n    }\n\n    n++;\n\n    localStorage.setItem(\"on_load_counter\", n);\n\n    document.getElementById('CounterVisitor').innerHTML = n;\n*/\n\n/*\nif (value > 0) {\n        counter = value;\n    } else {\n        counter = 0;\n    }*/ \n    \nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":280,"y":760,"wires":[["6cd49acb.8b2dc4"]]},{"id":"6cd49acb.8b2dc4","type":"debug","z":"83afaffb.3b3b8","d":true,"name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":500,"y":760,"wires":[]},{"id":"4e0aab3b.54ee74","type":"trigger","z":"83afaffb.3b3b8","d":true,"name":"Notification","op1":"","op2":"0","op1type":"pay","op2type":"str","duration":"0","extend":false,"units":"min","reset":"42","bytopic":"all","topic":"topic","outputs":1,"x":550,"y":1143,"wires":[["7e85fea1.df0e3"]]},{"id":"4c7bfad1.4188f4","type":"switch","z":"83afaffb.3b3b8","d":true,"name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Empty","vt":"str"},{"t":"eq","v":"Full","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":270,"y":800,"wires":[[],[]]},{"id":"7365a220.e6887c","type":"inject","z":"83afaffb.3b3b8","d":true,"name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":80,"y":800,"wires":[[]]},{"id":"7e85fea1.df0e3","type":"ui_toast","z":"83afaffb.3b3b8","d":true,"position":"dialog","displayTime":"1","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"CLOSE","raw":false,"topic":"","name":"","x":730,"y":1143,"wires":[[]]},{"id":"df16ba6f.b5ed98","type":"function","z":"83afaffb.3b3b8","d":true,"name":"","func":"inside = msg.payload;\noutside = msg.topic;\n\nvisitors = inside - outside\n\n/* if (inside === null) {\n        inside = 0;\n    }\n    \n    else if \n    */\n\n  /*  \n  var n = localStorage.getItem('on_load_counter');\n\n    if (n === null) {\n        n = 0;\n    }\n\n    n++;\n\n    localStorage.setItem(\"on_load_counter\", n);\n\n    document.getElementById('CounterVisitor').innerHTML = n;\n*/\n\n/*\nif (value > 0) {\n        counter = value;\n    } else {\n        counter = 0;\n    }*/ \n    \nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":280,"y":720,"wires":[[]]},{"id":"af32e6bf.d49b88","type":"ui_template","z":"83afaffb.3b3b8","d":true,"group":"754f26ec.f54098","name":"fileInput","order":0,"width":"6","height":"1","format":"<div class=\"fileContainer\">\n    <input type=\"file\" name=\"file\" id=\"file\" class=\"inputfile\" />\n    <label for=\"file\">File</label>\n    <p style=\"margin:auto\" id=\"fileName\"></p>\n    <button class=\"vibrate filled touched smallfont rounded greybuttons\" ng-click=\"clear()\"> \n       <ng-md-icon style=\"color: #fff;\" icon=\"clear\">\n            <md-tooltip md-direction=\"bottom\">CLEAR</md-tooltip>\n        </ng-md-icon>\n    </button> \n</div>\n\n<style>\n    .fileContainer {\n        display: flex;\n    }\n    .inputfile {\n\twidth: 0.1px;\n\theight: 0.1px;\n\topacity: 0;\n\toverflow: hidden;\n\tposition: absolute;\n\tz-index: -1;\n}\n\n.inputfile + label {\n    font-size: 1.25em;\n    font-weight: 700;\n    color: white;\n    text-align: center;\n    padding: 5px;\n    width: 60px;\n    background-color: black;\n}\n\n.inputfile:focus + label,\n.inputfile + label:hover {\n    background-color: red;\n}\n\n.inputfile + label {\n\tcursor: pointer; /* \"hand\" cursor */\n}\n\n.inputfile:focus + label {\n\toutline: 1px dotted #000;\n\toutline: -webkit-focus-ring-color auto 5px;\n}\n\n.inputfile + label * {\n\tpointer-events: none;\n}\n\n</style>\n\n<script>\n(function(scope) {\n   var fileInput = $('#file')\n   var fileName = $('#fileName')\n   \n   scope.clear = function() {\n       fileInput.val('').trigger('change')\n   }\n   \n   fileInput.on('change', function(event) {\n        var file = fileInput[0].files[0]; \n        \n        fileName.text(file ? file.name : '')\n        \n        if(file) {\n       \n            var reader = new FileReader();\n            reader.readAsBinaryString(file);\n        \n            reader.onload = function() {\n                scope.send({payload: reader.result, file: file.name})\n            };\n            reader.onerror = function() {\n                console.log('Error while reading files');\n            };\n        } else\n            scope.send({payload: null})\n   })\n    \n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":80,"y":900,"wires":[["ddc659f0.778d98","c10c65d7.4485f8"]]},{"id":"c10c65d7.4485f8","type":"function","z":"83afaffb.3b3b8","d":true,"name":"","func":"var toDelete = !msg.payload\n\nif(!toDelete) {\n    var buffer = new Buffer(msg.payload, \"binary\");\n    node.send({topic: 'create', payload: buffer, filename: 'files/' + msg.file})\n    flow.set('file', msg.file.name)\n}\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":283,"y":901,"wires":[["e4e08715.d78618"]]},{"id":"e4e08715.d78618","type":"file","z":"83afaffb.3b3b8","d":true,"name":"","filename":"","appendNewline":true,"createDir":false,"overwriteFile":"false","encoding":"none","x":519,"y":902,"wires":[[]]},{"id":"ddc659f0.778d98","type":"exec","z":"83afaffb.3b3b8","d":true,"command":"rm -rf files/*","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":307,"y":970,"wires":[[],[],[]]},{"id":"5ff0f263.c62e1c","type":"comment","z":"83afaffb.3b3b8","d":true,"name":"Just a live view of cameras","info":"","x":190,"y":1618,"wires":[]},{"id":"a8975bf6.441168","type":"inject","z":"83afaffb.3b3b8","d":true,"name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"30","crontab":"","once":true,"onceDelay":"10","topic":"","payload":"checkWeb","payloadType":"str","x":150,"y":1718,"wires":[["59e4e15d.ac81c"]]},{"id":"59e4e15d.ac81c","type":"ui_template","z":"83afaffb.3b3b8","d":true,"group":"e56f5108.01102","name":"Just a view of cameras","order":1,"width":"35","height":"12","format":"<!DOCTYPE html>\n<html>\n<style>\nimg {\n    border: 1px solid #ddd;\n    border-radius: 8px;\n    padding: 2px;\n    width: 405px;\n}\n</style>\n\n<script type=\"text/javascript\">\nscope.$watch('msg', function(msg) {\n    inMessage(msg.payload);\n});\n\nfunction updatePic() {\n    document.getElementById('c51').src = \"http://192.168.0.234:8081/1/stream\";\n    document.getElementById('c52').src = \"http://192.168.0.234:8081/1/stream\";\n    document.getElementById('c53').src = \"http://192.168.0.234:8081/1/stream\";\n    document.getElementById('c54').src = \"http://192.168.0.234:8081/1/stream\";\n    document.getElementById('c55').src = \"http://192.168.0.234:8081/1/stream\";\n    document.getElementById('c56').src = \"http://192.168.0.234:8081/1/stream\";\n    document.getElementById('c57').src = \"http://192.168.0.234:8081/1/stream\";\n    document.getElementById('c58').src = \"http://192.168.0.234:8081/1/stream\";\n    //alert('updated pics');\n}\n\nfunction inMessage(event) {\n    if (event.match('checkWeb')) {\n        updatePic();\n    }\n}\n\n</script>\n<center>\n<table>\n    <tr><!-- Row 1 -->\n    \t\t<td style=\"text-align: center\"><img src=\"\" id=\"c51\" /></td>\n   \t\t    <td style=\"text-align: center\"><img src=\"\" id=\"c52\" /></td>\n    \t\t<td style=\"text-align: center\"><img src=\"\" id=\"c53\" /></td>\n    \t\t<td style=\"text-align: center\"><img src=\"\" id=\"c54\" /></td>\n    </tr>\n    <tr><!-- Row 2 -->\n    \t\t<td style=\"text-align: center\"><img src=\"\" id=\"c55\" /></td>\n   \t\t    <td style=\"text-align: center\"><img src=\"\" id=\"c56\" /></td>\n    \t\t<td style=\"text-align: center\"><img src=\"\" id=\"c57\" /></td>\n    \t\t<td style=\"text-align: center\"><img src=\"\" id=\"c58\" /></td>\n    </tr>\n</table>\n</center>\n</html>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":380,"y":1718,"wires":[[]]},{"id":"921878c7.455d08","type":"ui_template","z":"83afaffb.3b3b8","d":true,"group":"e56f5108.01102","name":"Clock Toolbar","order":5,"width":"0","height":"0","format":"\n<script id=\"titleScript\" type=\"text/javascript\">\n    $('#clock').remove();\n    var toolbar = $('.md-toolbar-tools');\n    var div = $('<div></div>');\n    var p = $('<p/ id=\"clock\">');\n    $('#titleScript').parent().hide();\n    div.append(p);\n    div[0].style.margin = '5px 5px 5px auto';\n    toolbar.append(div);\n\n    function displayTitle(lh) {\n        p.text(lh); \n    }\n    \n    function upTime() {\n        var d = new Date();\n        p.text(d.toLocaleTimeString('de-AT'));\n    }\n\n    // Watch the payload and update the title\n    (function(scope) {\n        scope.$watch('msg.payload', function(data) {\n            if (data.match(\"systemsummary\")) { //Systemstatus\n                m = data;\n                n = m.split(':');\n                //alert(n[1]);\n                var sSummary = parseInt(n[1], 10);\n                if(sSummary === 14){\n                    document.getElementById(\"clock\").style.backgroundColor =\"transparent\";\n                }\n                if(sSummary < 14){\n                    document.getElementById(\"clock\").style.backgroundColor =\"#FF0033\";\n                }\n            }else{\n                displayTitle(data);\n            }\n        });\n        setInterval(upTime,1000);\n    })(scope);\n</script>","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":160,"y":1658,"wires":[[]]},{"id":"bcf31f4d.05939","type":"inject","z":"83afaffb.3b3b8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"start","payload":"1","payloadType":"num","x":110,"y":1183,"wires":[["d9f00969.4b65f8"]]},{"id":"33aea16c.1ec5be","type":"ui_chart","z":"83afaffb.3b3b8","name":"","group":"31698392.1d898c","order":4,"width":0,"height":0,"label":"chart","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"2","removeOlderPoints":"1000","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":true,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":550,"y":1443,"wires":[[]]},{"id":"5ecc35a3.c4cc0c","type":"debug","z":"83afaffb.3b3b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":530,"y":1263,"wires":[]},{"id":"d9f00969.4b65f8","type":"file in","z":"83afaffb.3b3b8","name":"","filename":"realtest.txt","format":"utf8","chunk":false,"sendError":false,"encoding":"none","x":210,"y":1263,"wires":[["78aa41ff.b3d2f","5ecc35a3.c4cc0c","e1f987d3.f065f8"]]},{"id":"78aa41ff.b3d2f","type":"csv","z":"83afaffb.3b3b8","name":"","sep":",","hdrin":true,"hdrout":"","multi":"mult","ret":"\\n","temp":"","skip":"0","strings":true,"include_empty_strings":false,"include_null_values":false,"x":310,"y":1343,"wires":[["c4a5cccc.3b04","5ecc35a3.c4cc0c"]]},{"id":"c4a5cccc.3b04","type":"function","z":"83afaffb.3b3b8","name":"graph generate","func":"\nfunction toTimestamp(strDate){\n     var datum = Date.parse(strDate);\n     return datum/1000;\n    }\nvar payload=msg.payload;\n\n\nvar data_out=[];\nvar a1=[];\nfor(let i=0;i<payload.length;i++)\n{\n  \nvar Data= payload[i].Data.split(\"-\");\nvar t=Data[2]+\"/\"+Data[1]+\"/\"+Data[0];\nvar timestamp=toTimestamp(t+\" \"+payload[i][\"Godzina\"]);\n//var timestamp=toTimestamp(\"Godzina\");\n//console.log(t);\n\n/*\n// Requiring fs module in which\n// writeFile function is defined.const\nfs = require('fs')  \n// Data which will write in a file.\nlet data =\"Learning how to write in a file.\"  \n// Write data in 'Output.txt' .\nfs.writeFile('Output.txt', data, (err) => {      \n// In case of a error throw err.   \nif (err) throw err; })\n\n*/\n\nvar total={ \"x\": timestamp, \"y\":parseInt( payload[i][\"Total\"]) };\n\n\na1.push(total);\n\n/*if (total = 42){\nvar MAX = new Boolean(false);\n}\n */\n \n}\n\ndata_out=[a1];\nmsg.payload=[{\n\"series\": [\"Total\"],\n\"data\":data_out,\n\"labels\": [\"Total\"]\n}];\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":320,"y":1463,"wires":[["5ecc35a3.c4cc0c","33aea16c.1ec5be","4e0aab3b.54ee74"]]},{"id":"e1f987d3.f065f8","type":"function","z":"83afaffb.3b3b8","d":true,"name":"notification function","func":"var payload=msg.payload;\n\n\nfor(let i=0;i<payload.length;i++)\n{\n// var Data= payload[i].Data.split(\"-\");\nvar total= parseInt( payload[i][\"Total\"]);\nmsg.payload=total;\n}\n\n//return msg;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":350,"y":1143,"wires":[[]]},{"id":"9b612191.edbff","type":"ui_toast","z":"83afaffb.3b3b8","position":"top right","displayTime":"3","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"topic":"","name":"","x":710,"y":1363,"wires":[]},{"id":"f2049ccb.8069d","type":"ui_group","z":"","d":true,"name":"Visitor Count","tab":"36e2a801.ed67a8","order":1,"disp":true,"width":"16","collapse":false},{"id":"754f26ec.f54098","type":"ui_group","z":"","name":"New Message","tab":"","order":1,"disp":true,"width":"6","collapse":false},{"id":"e56f5108.01102","type":"ui_group","z":"","name":"LiveVideo","tab":"","order":1,"disp":false,"width":"35","collapse":false},{"id":"31698392.1d898c","type":"ui_group","z":"","name":"","tab":"36e2a801.ed67a8","order":2,"disp":true,"width":"16","collapse":false},{"id":"36e2a801.ed67a8","type":"ui_tab","z":"","name":"Welcome to SHOP ANALYTICS","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Welcome to the forum.
Don't attempt to do it based on what is on the chart, do it based on what is going into the chart. If you feed whatever it is that you want to check for >42 into a Switch node then you can get it to pass the message on whenever it is >42 and ignore any messages with the value <=42.
This topic was automatically closed after 60 days. New replies are no longer allowed.
