sorry for the late reply.
[{"id":"6cd9fe0e.395b9","type":"function","z":"dbe1e11e.1ebd5","name":"System-Power: On","func":"msg.payload = \"system-power=on\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":410,"y":560,"wires":[["ea7fdea3.8aed8"]]},{"id":"f185c2dc.05253","type":"function","z":"dbe1e11e.1ebd5","name":"System-Power:Standby","func":"msg.payload = \"system-power=standby\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":430,"y":500,"wires":[["ea7fdea3.8aed8"]]},{"id":"bba28404.921bd8","type":"eiscp-in","z":"dbe1e11e.1ebd5","name":"Küche","controller":"5502d6b5.2ee598","x":110,"y":220,"wires":[["c1c675d9.9a1e48","ab97bf97.9ec73"]]},{"id":"c1c675d9.9a1e48","type":"switch","z":"dbe1e11e.1ebd5","name":"Split volume status","property":"payload.command[0]","propertyType":"msg","rules":[{"t":"eq","v":"master-volume","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":410,"y":220,"wires":[["f18be6f8.c505a"]]},{"id":"f4839b5c.f13f08","type":"change","z":"dbe1e11e.1ebd5","name":"Current power status","rules":[{"t":"set","p":"topic","pt":"msg","to":"system-power","tot":"str"},{"t":"move","p":"payload.argument","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"payload.command","pt":"msg"},{"t":"delete","p":"payload.argument","pt":"msg"},{"t":"delete","p":"payload.iscp_command","pt":"msg"},{"t":"delete","p":"payload.host","pt":"msg"},{"t":"delete","p":"payload.port","pt":"msg"},{"t":"delete","p":"payload.model","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":260,"wires":[["da94743a.f74698"]]},{"id":"ab97bf97.9ec73","type":"switch","z":"dbe1e11e.1ebd5","name":"Split system status","property":"payload.command","propertyType":"msg","rules":[{"t":"eq","v":"system-power","vt":"str"},{"t":"eq","v":"audio-muting","vt":"str"},{"t":"eq","v":"input-selector","vt":"str"},{"t":"eq","v":"preset","vt":"str"},{"t":"eq","v":"net-usb-title-name","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":410,"y":340,"wires":[["f4839b5c.f13f08"],["33f36e31.261be2"],["37b4e825.852598"],["b520bd63.1951f"],["e09a44ea.1d6f18"]]},{"id":"33f36e31.261be2","type":"change","z":"dbe1e11e.1ebd5","name":"Current audio-muting status","rules":[{"t":"set","p":"topic","pt":"msg","to":"audio-muting","tot":"str"},{"t":"move","p":"payload.argument","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"payload.command","pt":"msg"},{"t":"delete","p":"payload.argument","pt":"msg"},{"t":"delete","p":"payload.iscp_command","pt":"msg"},{"t":"delete","p":"payload.host","pt":"msg"},{"t":"delete","p":"payload.port","pt":"msg"},{"t":"delete","p":"payload.model","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":300,"wires":[[]]},{"id":"37b4e825.852598","type":"change","z":"dbe1e11e.1ebd5","name":"Current input-selector status","rules":[{"t":"set","p":"topic","pt":"msg","to":"input-selector","tot":"str"},{"t":"move","p":"payload.iscp_command","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"payload.command","pt":"msg"},{"t":"delete","p":"payload.iscp_command","pt":"msg"},{"t":"delete","p":"payload.host","pt":"msg"},{"t":"delete","p":"payload.port","pt":"msg"},{"t":"delete","p":"payload.model","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":340,"wires":[[]]},{"id":"b520bd63.1951f","type":"change","z":"dbe1e11e.1ebd5","name":"Current station preset","rules":[{"t":"set","p":"topic","pt":"msg","to":"preset","tot":"str"},{"t":"move","p":"payload.iscp_command","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"payload.command","pt":"msg"},{"t":"delete","p":"payload.iscp_command","pt":"msg"},{"t":"delete","p":"payload.host","pt":"msg"},{"t":"delete","p":"payload.port","pt":"msg"},{"t":"delete","p":"payload.model","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":680,"y":380,"wires":[[]]},{"id":"cd0dbe1.64b244","type":"function","z":"dbe1e11e.1ebd5","name":"master volume -","func":"var x =msg.payload;\nmsg.payload = x-1;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":980,"y":180,"wires":[["6bca686d.b6e938"]]},{"id":"f9bfb93e.6d76f8","type":"function","z":"dbe1e11e.1ebd5","name":"master volume +","func":"var x =msg.payload;\nmsg.payload = x+1;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":990,"y":140,"wires":[["daa60b52.f90f78"]]},{"id":"9277c2ba.e51a8","type":"function","z":"dbe1e11e.1ebd5","name":"master-volume minus hex get","func":"var x = flow.get('kueche_minus');\nmsg={raw:x};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":450,"y":620,"wires":[["ea7fdea3.8aed8"]]},{"id":"6bca686d.b6e938","type":"change","z":"dbe1e11e.1ebd5","name":"master volume - in hex","rules":[{"t":"change","p":"payload","pt":"msg","from":"0","fromt":"num","to":"MVL00","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"MVL01","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"MVL02","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"MVL03","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"MVL04","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"MVL05","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"MVL06","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"7","fromt":"num","to":"MVL07","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"8","fromt":"num","to":"MVL08","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"9","fromt":"num","to":"MVL09","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"10","fromt":"num","to":"MVL0A","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"11","fromt":"num","to":"MVL0B","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"12","fromt":"num","to":"MVL0C","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"13","fromt":"num","to":"MVL0D","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"14","fromt":"num","to":"MVL0E","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"15","fromt":"num","to":"MVL0F","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"16","fromt":"num","to":"MVL10","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"17","fromt":"num","to":"MVL11","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"18","fromt":"num","to":"MVL12","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"19","fromt":"num","to":"MVL13","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"20","fromt":"num","to":"MVL14","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"21","fromt":"num","to":"MVL15","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"22","fromt":"num","to":"MVL16","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"23","fromt":"num","to":"MVL17","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"24","fromt":"num","to":"MVL18","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"25","fromt":"num","to":"MVL19","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"26","fromt":"num","to":"MVL1A","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"27","fromt":"num","to":"MVL1B","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"28","fromt":"num","to":"MVL1C","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"29","fromt":"num","to":"MVL1D","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"30","fromt":"num","to":"MVL1E","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"31","fromt":"num","to":"MVL1F","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"32","fromt":"num","to":"MVL20","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"33","fromt":"num","to":"MVL21","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"34","fromt":"num","to":"MVL22","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"35","fromt":"num","to":"MVL23","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1220,"y":180,"wires":[["11daab13.69f1e5"]]},{"id":"daa60b52.f90f78","type":"change","z":"dbe1e11e.1ebd5","name":"master volume + in hex","rules":[{"t":"change","p":"payload","pt":"msg","from":"0","fromt":"num","to":"MVL00","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"MVL01","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"MVL02","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"MVL03","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"MVL04","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"MVL05","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"MVL06","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"7","fromt":"num","to":"MVL07","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"8","fromt":"num","to":"MVL08","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"9","fromt":"num","to":"MVL09","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"10","fromt":"num","to":"MVL0A","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"11","fromt":"num","to":"MVL0B","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"12","fromt":"num","to":"MVL0C","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"13","fromt":"num","to":"MVL0D","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"14","fromt":"num","to":"MVL0E","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"15","fromt":"num","to":"MVL0F","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"16","fromt":"num","to":"MVL10","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"17","fromt":"num","to":"MVL11","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"18","fromt":"num","to":"MVL12","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"19","fromt":"num","to":"MVL13","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"20","fromt":"num","to":"MVL14","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"21","fromt":"num","to":"MVL15","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"22","fromt":"num","to":"MVL16","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"23","fromt":"num","to":"MVL17","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"24","fromt":"num","to":"MVL18","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"25","fromt":"num","to":"MVL19","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"26","fromt":"num","to":"MVL1A","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"27","fromt":"num","to":"MVL1B","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"28","fromt":"num","to":"MVL1C","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"29","fromt":"num","to":"MVL1D","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"30","fromt":"num","to":"MVL1E","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"31","fromt":"num","to":"MVL1F","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"32","fromt":"num","to":"MVL20","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"33","fromt":"num","to":"MVL21","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"34","fromt":"num","to":"MVL22","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"35","fromt":"num","to":"MVL23","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1230,"y":140,"wires":[["75cfb9fb.8ecdd8"]]},{"id":"11daab13.69f1e5","type":"function","z":"dbe1e11e.1ebd5","name":"master volume minus hex set","func":"flow.set('kueche_minus', msg.payload);\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1480,"y":180,"wires":[[]]},{"id":"75cfb9fb.8ecdd8","type":"function","z":"dbe1e11e.1ebd5","name":"master volume plus hex set","func":"flow.set('kueche_plus', msg.payload);\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1480,"y":140,"wires":[[]]},{"id":"5c998ad9.c21064","type":"function","z":"dbe1e11e.1ebd5","name":"master-volume plus hex get","func":"var x = flow.get('kueche_plus');\nmsg={raw:x};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":440,"y":680,"wires":[["ea7fdea3.8aed8"]]},{"id":"ea7fdea3.8aed8","type":"eiscp-out","z":"dbe1e11e.1ebd5","name":"Küche","controller":"5502d6b5.2ee598","x":850,"y":640,"wires":[]},{"id":"cb5d3211.21f1f","type":"ccu-sysvar","z":"dbe1e11e.1ebd5","name":"Kueche:Level","ccuConfig":"38263145.35ea0e","topic":"ReGaHSS/${Name}","change":true,"cache":true,"x":980,"y":220,"wires":[[]]},{"id":"f18be6f8.c505a","type":"change","z":"dbe1e11e.1ebd5","name":"Current master volume-status","rules":[{"t":"set","p":"topic","pt":"msg","to":"master-volume","tot":"str"},{"t":"move","p":"payload.argument","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"payload.command","pt":"msg"},{"t":"delete","p":"payload.argument","pt":"msg"},{"t":"delete","p":"payload.iscp_command","pt":"msg"},{"t":"delete","p":"payload.host","pt":"msg"},{"t":"delete","p":"payload.port","pt":"msg"},{"t":"delete","p":"payload.model","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":220,"wires":[["cb5d3211.21f1f","f9bfb93e.6d76f8","cd0dbe1.64b244","f19560c1.1d029","86176f4a.c5bcd"]]},{"id":"e09a44ea.1d6f18","type":"change","z":"dbe1e11e.1ebd5","name":"Current title name","rules":[{"t":"set","p":"topic","pt":"msg","to":"net-usb-title-name","tot":"str"},{"t":"move","p":"payload.iscp_command","pt":"msg","to":"payload","tot":"msg"},{"t":"delete","p":"payload.command","pt":"msg"},{"t":"delete","p":"payload.argument","pt":"msg"},{"t":"delete","p":"payload.iscp_command","pt":"msg"},{"t":"delete","p":"payload.host","pt":"msg"},{"t":"delete","p":"payload.port","pt":"msg"},{"t":"delete","p":"payload.model","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":420,"wires":[["ad8c09a0.86f688"]]},{"id":"181677c1.293c48","type":"ccu-sysvar","z":"dbe1e11e.1ebd5","name":"Kueche:Info","ccuConfig":"38263145.35ea0e","topic":"ReGaHSS/${Name}","change":true,"cache":true,"x":1190,"y":420,"wires":[[]]},{"id":"ad8c09a0.86f688","type":"change","z":"dbe1e11e.1ebd5","name":"delete \"NTI\"","rules":[{"t":"change","p":"payload","pt":"msg","from":"NTI","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":420,"wires":[["181677c1.293c48"]]},{"id":"5df0161b.f73198","type":"ccu-rpc-event","z":"dbe1e11e.1ebd5","name":"Taste 1","iface":"HmIP-RF","ccuConfig":"38263145.35ea0e","rooms":"","roomsRx":"str","functions":"","functionsRx":"str","device":"","deviceRx":"str","deviceName":"","deviceNameRx":"str","deviceType":"","deviceTypeRx":"str","channel":"","channelRx":"str","channelName":"Kueche:Wandtaster_ONKYO:1","channelNameRx":"str","channelType":"","channelTypeRx":"str","channelIndex":"","channelIndexRx":"str","datapoint":"PRESS_SHORT","datapointRx":"str","change":false,"working":false,"cache":false,"topic":"${CCU}/${Interface}/${channelName}/${datapoint}","x":110,"y":500,"wires":[["f185c2dc.05253"]]},{"id":"5bd62ac5.51ea94","type":"ccu-rpc-event","z":"dbe1e11e.1ebd5","name":"Taste 2","iface":"HmIP-RF","ccuConfig":"38263145.35ea0e","rooms":"","roomsRx":"str","functions":"","functionsRx":"str","device":"","deviceRx":"str","deviceName":"","deviceNameRx":"str","deviceType":"","deviceTypeRx":"str","channel":"","channelRx":"str","channelName":"Kueche:Wandtaster_ONKYO:2","channelNameRx":"str","channelType":"","channelTypeRx":"str","channelIndex":"","channelIndexRx":"str","datapoint":"PRESS_SHORT","datapointRx":"str","change":false,"working":false,"cache":false,"topic":"${CCU}/${Interface}/${channelName}/${datapoint}","x":110,"y":560,"wires":[["6cd9fe0e.395b9"]]},{"id":"a49750d5.8177","type":"ccu-rpc-event","z":"dbe1e11e.1ebd5","name":"Taste 3","iface":"HmIP-RF","ccuConfig":"38263145.35ea0e","rooms":"","roomsRx":"str","functions":"","functionsRx":"str","device":"","deviceRx":"str","deviceName":"","deviceNameRx":"str","deviceType":"","deviceTypeRx":"str","channel":"","channelRx":"str","channelName":"Kueche:Wandtaster_ONKYO:3","channelNameRx":"str","channelType":"","channelTypeRx":"str","channelIndex":"","channelIndexRx":"str","datapoint":"PRESS_SHORT","datapointRx":"str","change":false,"working":false,"cache":false,"topic":"${CCU}/${Interface}/${channelName}/${datapoint}","x":110,"y":620,"wires":[["9277c2ba.e51a8"]]},{"id":"d1724451.619438","type":"ccu-rpc-event","z":"dbe1e11e.1ebd5","name":"Taste 4","iface":"HmIP-RF","ccuConfig":"38263145.35ea0e","rooms":"","roomsRx":"str","functions":"","functionsRx":"str","device":"","deviceRx":"str","deviceName":"","deviceNameRx":"str","deviceType":"","deviceTypeRx":"str","channel":"","channelRx":"str","channelName":"Kueche:Wandtaster_ONKYO:4","channelNameRx":"str","channelType":"","channelTypeRx":"str","channelIndex":"","channelIndexRx":"str","datapoint":"PRESS_SHORT","datapointRx":"str","change":false,"working":false,"cache":false,"topic":"${CCU}/${Interface}/${channelName}/${datapoint}","x":110,"y":680,"wires":[["5c998ad9.c21064"]]},{"id":"f19560c1.1d029","type":"function","z":"dbe1e11e.1ebd5","name":"master volume -3","func":"var x =msg.payload;\nmsg.payload = x-3;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":990,"y":100,"wires":[["81093e8b.df5cb"]]},{"id":"86176f4a.c5bcd","type":"function","z":"dbe1e11e.1ebd5","name":"master volume +3","func":"var x =msg.payload;\nmsg.payload = x+3;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":990,"y":60,"wires":[["322511fc.a10d7e"]]},{"id":"81093e8b.df5cb","type":"change","z":"dbe1e11e.1ebd5","name":"master volume - in hex","rules":[{"t":"change","p":"payload","pt":"msg","from":"0","fromt":"num","to":"MVL00","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"MVL01","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"MVL02","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"MVL03","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"MVL04","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"MVL05","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"MVL06","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"7","fromt":"num","to":"MVL07","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"8","fromt":"num","to":"MVL08","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"9","fromt":"num","to":"MVL09","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"10","fromt":"num","to":"MVL0A","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"11","fromt":"num","to":"MVL0B","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"12","fromt":"num","to":"MVL0C","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"13","fromt":"num","to":"MVL0D","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"14","fromt":"num","to":"MVL0E","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"15","fromt":"num","to":"MVL0F","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"16","fromt":"num","to":"MVL10","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"17","fromt":"num","to":"MVL11","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"18","fromt":"num","to":"MVL12","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"19","fromt":"num","to":"MVL13","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"20","fromt":"num","to":"MVL14","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"21","fromt":"num","to":"MVL15","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"22","fromt":"num","to":"MVL16","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"23","fromt":"num","to":"MVL17","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"24","fromt":"num","to":"MVL18","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"25","fromt":"num","to":"MVL19","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"26","fromt":"num","to":"MVL1A","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"27","fromt":"num","to":"MVL1B","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"28","fromt":"num","to":"MVL1C","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"29","fromt":"num","to":"MVL1D","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"30","fromt":"num","to":"MVL1E","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"31","fromt":"num","to":"MVL1F","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"32","fromt":"num","to":"MVL20","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"33","fromt":"num","to":"MVL21","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"34","fromt":"num","to":"MVL22","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"35","fromt":"num","to":"MVL23","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1220,"y":100,"wires":[["416705e5.557f0c"]]},{"id":"322511fc.a10d7e","type":"change","z":"dbe1e11e.1ebd5","name":"master volume + in hex","rules":[{"t":"change","p":"payload","pt":"msg","from":"0","fromt":"num","to":"MVL00","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"1","fromt":"num","to":"MVL01","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"2","fromt":"num","to":"MVL02","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"3","fromt":"num","to":"MVL03","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"4","fromt":"num","to":"MVL04","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"5","fromt":"num","to":"MVL05","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"6","fromt":"num","to":"MVL06","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"7","fromt":"num","to":"MVL07","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"8","fromt":"num","to":"MVL08","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"9","fromt":"num","to":"MVL09","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"10","fromt":"num","to":"MVL0A","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"11","fromt":"num","to":"MVL0B","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"12","fromt":"num","to":"MVL0C","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"13","fromt":"num","to":"MVL0D","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"14","fromt":"num","to":"MVL0E","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"15","fromt":"num","to":"MVL0F","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"16","fromt":"num","to":"MVL10","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"17","fromt":"num","to":"MVL11","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"18","fromt":"num","to":"MVL12","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"19","fromt":"num","to":"MVL13","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"20","fromt":"num","to":"MVL14","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"21","fromt":"num","to":"MVL15","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"22","fromt":"num","to":"MVL16","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"23","fromt":"num","to":"MVL17","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"24","fromt":"num","to":"MVL18","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"25","fromt":"num","to":"MVL19","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"26","fromt":"num","to":"MVL1A","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"27","fromt":"num","to":"MVL1B","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"28","fromt":"num","to":"MVL1C","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"29","fromt":"num","to":"MVL1D","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"30","fromt":"num","to":"MVL1E","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"31","fromt":"num","to":"MVL1F","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"32","fromt":"num","to":"MVL20","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"33","fromt":"num","to":"MVL21","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"34","fromt":"num","to":"MVL22","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"35","fromt":"num","to":"MVL23","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1230,"y":60,"wires":[["813b68d4.a49598"]]},{"id":"416705e5.557f0c","type":"function","z":"dbe1e11e.1ebd5","name":"master volume minus 3 hex set","func":"flow.set('kueche_minus3', msg.payload);\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1490,"y":100,"wires":[[]]},{"id":"813b68d4.a49598","type":"function","z":"dbe1e11e.1ebd5","name":"master volume plus 3 hex set","func":"flow.set('kueche_plus3', msg.payload);\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1480,"y":60,"wires":[[]]},{"id":"2a573773.809888","type":"function","z":"dbe1e11e.1ebd5","name":"master-volume minus 3 hex get","func":"var x = flow.get('kueche_minus3');\nmsg={raw:x};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":450,"y":740,"wires":[["ea7fdea3.8aed8"]]},{"id":"5ca7c2a3.3f4bcc","type":"function","z":"dbe1e11e.1ebd5","name":"master-volume plus 3 hex get","func":"var x = flow.get('kueche_plus3');\nmsg={raw:x};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":450,"y":800,"wires":[["ea7fdea3.8aed8"]]},{"id":"2acf2140.ca5fae","type":"ccu-rpc-event","z":"dbe1e11e.1ebd5","name":"Taste 3 lang","iface":"HmIP-RF","ccuConfig":"38263145.35ea0e","rooms":"","roomsRx":"str","functions":"","functionsRx":"str","device":"","deviceRx":"str","deviceName":"","deviceNameRx":"str","deviceType":"","deviceTypeRx":"str","channel":"","channelRx":"str","channelName":"Kueche:Wandtaster_ONKYO:3","channelNameRx":"str","channelType":"","channelTypeRx":"str","channelIndex":"","channelIndexRx":"str","datapoint":"PRESS_LONG_RELEASE","datapointRx":"str","change":false,"working":false,"cache":false,"topic":"${CCU}/${Interface}/${channelName}/${datapoint}","x":130,"y":740,"wires":[["2a573773.809888"]]},{"id":"7d26f7e6.2aebb8","type":"ccu-rpc-event","z":"dbe1e11e.1ebd5","name":"Taste 4 lang","iface":"","ccuConfig":"38263145.35ea0e","rooms":"","roomsRx":"str","functions":"","functionsRx":"str","device":"","deviceRx":"str","deviceName":"","deviceNameRx":"str","deviceType":"","deviceTypeRx":"str","channel":"","channelRx":"str","channelName":"Kueche:Wandtaster_ONKYO:4","channelNameRx":"str","channelType":"","channelTypeRx":"str","channelIndex":"","channelIndexRx":"str","datapoint":"PRESS_LONG_RELEASE","datapointRx":"str","change":false,"working":false,"cache":false,"topic":"${CCU}/${Interface}/${channelName}/${datapoint}","x":130,"y":800,"wires":[["5ca7c2a3.3f4bcc"]]},{"id":"da94743a.f74698","type":"ccu-sysvar","z":"dbe1e11e.1ebd5","name":"Kueche:Power","ccuConfig":"38263145.35ea0e","topic":"ReGaHSS/${Name}","change":true,"cache":true,"x":980,"y":280,"wires":[[]]},{"id":"5502d6b5.2ee598","type":"eiscp-controller","name":"Küche:NCP-302","host":"10.10.10.22","port":"60128","model":"NCP-302"},{"id":"38263145.35ea0e","type":"ccu-connection","name":"localhost","host":"localhost","regaEnabled":true,"bcrfEnabled":true,"iprfEnabled":true,"virtEnabled":true,"bcwiEnabled":false,"cuxdEnabled":true,"regaPoll":true,"regaInterval":"30","rpcPingTimeout":"60","rpcInitAddress":"127.0.0.1","rpcServerHost":"127.0.0.1","rpcBinPort":"2047","rpcXmlPort":"2048","tls":false,"inSecure":false,"authentication":false,"username":"Admin","password":"Ej388004","queueTimeout":"5000","queuePause":"250","contextStore":""}]
Here you can see that the current volume states are the same in node red.
But the speakers have two different volume states.
