I'm looking for the syntax from openweather to dashbard.
the usual works: var msg6 = { payload:msg.payload.windspeed};
but not for 'rain'.
Looked in openweather but no luck.
thaks
works well with msg.payload.humidity as the link suggests but no variable for rain, or rainfall.
If you use a debug node to look at the payload is the rain there?
No, it's not.
I went with darksky instead.
Thanks to you all.
I am just setting up a retic system in node red and going to incorporate rainfall darksky looks good but only a short term solution. Any ideas what you are going to replace darksky with now apple has bought it and discontinuing the API next year?
Where are you based ? For instance in Australia - the Australian BOM offers a free download/XLM feed for most areas (the depth and breadth of info differs based on region
Craig
Yer I am in Perth. I there is a package node-bom which will get data from bom. I will have a look into this.
Nope no package that i have found - i am getting most of my data through Home Assistant as there is some really good stuff over there for using BOM and then i pump it out to my NR instance.
I also have a basic flow that can pull down the BOM stuff and you can extract whatever you want from it - but it is a little fiddly
Craig
I am HA user too, doing up retic system and wanted rainfall predictions + rainfall mm in last X days to make node red skip watering where needed.
Well have a look at this over here on the HA forums
Its a long read but will get you the info you want, you could then grab it and send it over to NR
They do some weird stuff with NR in HA - so i would suggest running a seperate instance rather than the one provided in the Integrations
Craig
Craig
Rain has been added 3 days ago to the node-red integration:
