Trying to split a status text on line break
I have a payload.status string with I believe line breaks. If I try to send the string as it is to my dashboard text node though, I have no line break. So I thought I try to split the string at the line break, then after each part I add a
and send it to the text node.
Not sure this is the right approach though
Here is a screen grab of the debug, as when I try and copy paste the line break symbol it doesnt work.
The screen grab has my attempt of splitting and on the right side status: "14/12 Thalia... is the string I need to split
(this is a calendar retrieved from google calendar via Homeseer)
msg.payload = msg.payload.status.split('</p>')
Read the built in help...
And always use the great tools Node-RED provides...
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
As for how to split in a JS function - always go look on mdn
update...
Forgot to say, the symbol you see in the debug output is a newline character. In JS strings, you type these as \n - so you probably would want msg.payload = msg.payload.status.split('\n')
You could just use <pre></pre> tags around the text, to display it in the text node.
e.g.
[{"id":"53063e508fc2d807","type":"inject","z":"452103ea51141731","name":"text with line breaks","props":[{"p":"payload.status","v":"\"text one\\ntext two\\ntext three\\n\"","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":4100,"wires":[["4e323c6454e038e3","449c43256cc9d923"]]},{"id":"4e323c6454e038e3","type":"debug","z":"452103ea51141731","name":"debug 110","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":530,"y":4040,"wires":[]},{"id":"449c43256cc9d923","type":"ui_text","z":"452103ea51141731","group":"2d4fe667.28f8ba","order":17,"width":0,"height":0,"name":"","label":"text","format":"<pre>{{msg.payload.status}}</pre>","layout":"row-spread","className":"","x":470,"y":3980,"wires":[]},{"id":"2d4fe667.28f8ba","type":"ui_group","name":"demo","tab":"1caa8458.b17814","order":2,"disp":true,"width":"12","collapse":false},{"id":"1caa8458.b17814","type":"ui_tab","name":"Demo","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
That looks the easiest solution as I was just trying to figure out how to display the array the function gives me. Now I came across the next (expected) issue. Its displaying 4 lines out of 6. I thought the text node might be restricted with how many lines it can display. Is there a way to change the height to get more lines in ? This changes all the time, as sometimes I can have 15 or so lines, other times only 1 or 2
I just seen it had been blocked by another text node, it does display more than 4 lines. But it doesnt look right, I think the height of the display field might need adjusting ?
This is from 2 text nodes
Playing around with the formatting to get it to display nicely. I can set the colour of the text, but then I have a indent on the first line. No idea where that comes from, its not there if I dont change the colour...
If I have spacers under the text field, it looks a bit nicer but it seems to center the text (height)
I use this in the text node value
<pre><font color= {{"red"}} > {{msg.payload.status}} </font></pre>
<font color="red"><pre>{{msg.payload.status}}</pre></font>
Notice no white space between > and {
I did not see that... the indent is now gone
