You can do this in a change node to, using JSONata. Feed your array into the change node to see the result.
$sum($$.payload.used)
[{"id":"8b46158f.df50e8","type":"inject","z":"b779de97.b1b46","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"used\":2},{\"used\":4}]","payloadType":"json","x":460,"y":3820,"wires":[["3b5365c7.3e3092"]]},{"id":"3b5365c7.3e3092","type":"change","z":"b779de97.b1b46","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$sum($$.payload.used)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":3820,"wires":[["a76897c9.a113f8"]]},{"id":"a76897c9.a113f8","type":"debug","z":"b779de97.b1b46","name":"","active":true,"console":"false","complete":"false","x":899,"y":3740,"wires":[]}]
