i find this example.
https://flows.nodered.org/flow/36f2de38ed4bb62cf3a5e8fdc76d779e
but can some explain why?
many thanks
many thanks
Explain what about it?
Unless you need to do what that flow does then it is not relevant to your problem.
What exactly are you trying to do?
@Colin , hi i want to display both real time series curve in one chart.
that is two real time curve?
i have try
var total = msg.payload.data.count;
for(var i = 0;i<=20 ; i++){
temp.push({"x":msg.payload.data.datastreams[0].datapoints[i].at, "y":parseInt(msg.payload.data.datastreams[0].datapoints[i].value.substr(-6))/10
wind.push({"x":msg.payload.data.datastreams[0].datapoints[i].at, "y":parseInt(msg.payload.data.datastreams[0].datapoints[i].value.substr(9,11))/100
msg1.topic = "A"
msg1.payload = [{
"series": ["WindSpeed"],
"data": [ temp],
"labels": [""]
msg2.topic = "B"
msg2.payload = [{
"series": ["Temperature"],
"data": [ wind],
"labels": [""]
return msg1,msg2;
but without success.
and this is my single real time curve with result from API
let data =[];
//for (let prop in msg.payload) {
// data.push({"x":msg.payload.data.datastreams[1].datapoints[prop].value, "y":msg.payload[prop].at});
for (var i = 0; i<total; i++){
data.push({"x":msg.payload.data.datastreams[0].datapoints[i].at, "y":parseInt(msg.payload.data.datastreams[0].datapoints[i].value.substr(-6))/10
//payload.data.datastreams[1].datapoints[0].value
msg.data = data;
series = [];
data = [];
data_1 = [];
labels = [];
var msg1 = {};
var msg2 = {};
series.push("Count","test","abc");
labels.push("Labels");
data.push(msg.data);
msg.payload = [{"series":series, "data":data,"labels": labels}];
//series.push("Count","test","abc");
//labels.push("Labels");
//data.push(msg2.data);
//msg2.payload = [{"series":series, "data":data,"labels": labels}];
Read the node red docs page on Writing Functions to see how to correctly return two messages.
i have successful in sending two messgae,
by modifyingreturn [[msg1,msg2]];
however, the chart is now displaying only the chart on ONLY last msg,
but not both
any more hints , thanks
You don't need to send two separated messages. You have data for two series.
Do following
msg.payload = [{
"series": ["WindSpeed","Temperature"],
"data": [ wind,temp],
"labels": [""]
thanks~
it works well
