I am getting a type error - Cannot read property '0' of undefined in my function node. I am not sure what is exactly the mistake. I have attached my flow. Can someone suggest me what should i do to solve the error. I am quite new to Node red.
[{"id":"678e3899.0cdf4","type":"inject","z":"99a7958.4ae3d68","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":200,"y":100,"wires":[["c9bb7218.572258"]]},{"id":"3bb10800.6e3de","type":"file in","z":"99a7958.4ae3d68","name":"","filename":"C:\\Users\\Public\\Varun\\PreHeating_2019-09-13_19-23-41.csv","format":"utf8","chunk":false,"sendError":false,"x":350,"y":340,"wires":[["d4fd98ff.6fd27"]]},{"id":"a4dc0c6d.b5db38","type":"function","z":"99a7958.4ae3d68","name":"Selecting the file","func":"\nmsg.filename = \"\\\\\\\\C:\\\\Users\\\\Public\\\\Varun\\\\PreHeating_2019-09-13_19-23-41.csv\";\nreturn msg;\n","outputs":1,"noerr":0,"x":630,"y":220,"wires":[["3bb10800.6e3de"]]},{"id":"3685a12.f68965e","type":"function","z":"99a7958.4ae3d68","name":"Calculate average ","func":"const inputArray = new Array (msg.payload.length);\n for (var n = 0 ; n < inputArray.length ; n++) {\n inputArray[n] = Object.values(msg.payload[n]);\n }\n\n // width and height of heating fields in pixels\n // dependant on distance between camera and object\n\n const FIELD_WIDTH = msg.config[0].col2;// 4;\n const FIELD_HEIGTH = msg.config[1].col2;// 4;\n\n // Width resolution of Images\n\n const RES_WIDTH = msg.config[2].col2;// 100;\n\n // # of heating fields to calculate\n\n const FIELDS_HORIZONTAL = msg.config[3].col2;// 6;\n\n // because of zig-zag recording of camera 1 to generate same layouts.\n\n const FIELDS_VERTICAL = msg.config[4].col2;// 28;\n\n // first field starts half the field amount in length from middle of the image.\n\n // const HEATING_FIELD_START_HORIZONTAL = RES_WIDTH/2 - msg.config[3].col2 *msg.config[0].col2;\n const HEATING_FIELD_START_HORIZONTAL = 0;\n\n // Detect start of Fields// emperic values maybe?\n\n var HEATING_FIELD_START_DETECTION = detectStartHeating(inputArray);\n var HEATING_FIELD_END_DETECTION = detectEndHeating(inputArray);\n // var HEATING_FIELD_START_VERTICAL = (HEATING_FIELD_END_DETECTION - HEATING_FIELD_START_DETECTION )/ 2 + HEATING_FIELD_START_DETECTION - msg.config[4].col2/2 * msg.config[1].col2;\n var HEATING_FIELD_START_VERTICAL =0;\n\n // Creating an empty output Array with the set no fields\n\n var outputArray = new Array (FIELDS_VERTICAL);\n for (var k = 0 ; k< outputArray.length ; k++) {\n outputArray[k] = new Array (FIELDS_HORIZONTAL);\n for ( var l = 0; l< outputArray[k].length; l++) {\n outputArray[k][l] = 0;\n }\n }\n\n var tmp2 = 0;\n\n // loop through the fields\n\n for (var v = 0 ; v < FIELDS_VERTICAL ; v++) {\n for ( var h = 0; h < FIELDS_HORIZONTAL ; h++) {\n \n //calculate median of each field\n var tmp = 0 ;\n for ( var y = HEATING_FIELD_START_VERTICAL + v * FIELD_HEIGTH ; y < HEATING_FIELD_START_VERTICAL + v * FIELD_HEIGTH + FIELD_HEIGTH; y++) {\n for (var x = HEATING_FIELD_START_HORIZONTAL + h *FIELD_WIDTH; x < HEATING_FIELD_START_HORIZONTAL + h * FIELD_WIDTH + FIELD_WIDTH; x++) {\n tmp += parseFloat(inputArray[y][x]);\n }\n }\n \n // round to 2 decimals\n tmp = tmp / (FIELD_WIDTH * FIELD_HEIGTH)\n \n // no of decimal digits\n \n tmp = Math.round(tmp);\n outputArray[v][h] = tmp;\n\t\t}\n }\n \n // Create an empty array to insert the data\n // The desired output has 7 rows\n var newOutput = new Array (7);\n for (var k = 0 ; k< newOutput.length ; k++) {\n // Every row contains as much elements as the total number of fields\n newOutput[k] = new Array ( FIELDS_HORIZONTAL* FIELDS_VERTICAL);\n for ( var l = 0; l< newOutput[k].length; l++) {\n newOutput[k][l] = 0;\n }\n }\n\n // Map the current result to the format desired\n // 7 rows were\n // row0 PixelName\n // row1 Width\n // row2 Height\n // row3 X\n // row4 Y\n // row5 Average\n // row6 Consecutive pixel name\n let firstRowIndex = 0;\n for (let rowIndex = 0; rowIndex < outputArray.length; rowIndex++) {\n const row = outputArray[rowIndex];\n for (let colIndex = 0; colIndex < row.length; colIndex++) {\n const col = row[colIndex];\n // Determine the name\n const pixelName = `${getLettherForRowNumber(rowIndex)}${colIndex}`;\n newOutput[0][firstRowIndex] = pixelName;\n newOutput[1][firstRowIndex] = 100; // Width\n newOutput[2][firstRowIndex] = 100; // Height\n newOutput[3][firstRowIndex] = colIndex * 100; // X\n newOutput[4][firstRowIndex] = rowIndex * 100; // Y\n newOutput[5][firstRowIndex] = col; // Average\n // Determine the name 2\n const pixelName2 = `a${firstRowIndex}`;\n newOutput[6][firstRowIndex] = pixelName2;\n firstRowIndex++;\n }\n }\n\t\n\tmsg.payload = newOutput;\n\t\n return msg;\n\n\t\nfunction detectStartHeating(inputArray) {\n\t \n\t// Haet difference from cool row to first heated row, how much hotter does the first heated row to be ?\n \n const THRESHOLD = 5;\n\n var hotRow = 0 ;\n var currentRowAverage = calcRowAverage(inputArray, hotRow);\n hotRow++;\n \n var nextRowAverage = calcRowAverage(inputArray,hotRow);\n while( currentRowAverage + THRESHOLD > nextRowAverage && currentRowAverage > -1 && nextRowAverage > -1) {\n\n currentRowAverage = nextRowAverage;\n hotRow++;\n nextRowAverage = calcRowAverage(inputArray,hotRow);\n }\n if (nextRowAverage == -1 || currentRowAverage == -1) {\n return 0;\n } else {\n return hotRow;\n }\n }\n\nfunction detectEndHeating(inputArray) {\n // heat difference from cool row to first heated row , how much hotter does the first heated row have to on average?\n \n const THRESHOLD = 40;\n var hotRow = inputArray.length - 1;\n var currentRowAverage = calcRowAverage(inputArray, hotRow);\n hotRow--;\n\n var prevRowAverage = calcRowAverage(inputArray,hotRow);\n\n while ( currentRowAverage + THRESHOLD > prevRowAverage && currentRowAverage > -1 && prevRowAverage > -1 && hotRow>0) {\n currentRowAverage = prevRowAverage;\n hotRow--;\n prevRowAverage = calcRowAverage(inputArray,hotRow);\n \n }\n if( prevRowAverage == -2 || currentRowAverage == -1) {\n return 0 ;\n }\n\n else\n {\n return hotRow;\n }\n }\n \nfunction calcRowAverage(inputArray,row) {\n var res = 0;\n if (inputArray.length < row) {\n return -1;\n }\n\n\n for (var g = 0; g< inputArray[row].length; g++) {\n res += inputArray[row][g];\n }\n return res/inputArray[row].length;\n}\t \n\nfunction getLettherForRowNumber(rowNumber) {\n // ASCII code for 'a' is 97, 122 for 'z'\n if (rowNumber < 26) {\n return String.fromCharCode(97 + rowNumber);\n } else {\n const asciiFirstLetter = Math.round(rowNumber / 25) - 1;\n const mod = rowNumber % 25 - 1;\n const firstLetter = String.fromCharCode(97 + asciiFirstLetter);\n const secondLetter = String.fromCharCode(97 + mod);\n return `${firstLetter}${secondLetter}`;\n }\n}","outputs":1,"noerr":0,"x":290,"y":480,"wires":[["31a3b225.c03346"]]},{"id":"31a3b225.c03346","type":"debug","z":"99a7958.4ae3d68","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":590,"y":480,"wires":[]},{"id":"d4fd98ff.6fd27","type":"csv","z":"99a7958.4ae3d68","name":"ReadCSV","sep":";","hdrin":"","hdrout":"","multi":"mult","ret":"\\n","temp":"","skip":"0","x":760,"y":340,"wires":[["3685a12.f68965e"]]},{"id":"c9bb7218.572258","type":"file in","z":"99a7958.4ae3d68","name":"","filename":"C:\\Users\\Public\\Varun\\config.csv","format":"utf8","chunk":false,"sendError":false,"x":500,"y":100,"wires":[["92838f8d.6e6308"]]},{"id":"a0970e0b.a00a2","type":"change","z":"99a7958.4ae3d68","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"config\t","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":220,"wires":[["a4dc0c6d.b5db38"]]},{"id":"92838f8d.6e6308","type":"csv","z":"99a7958.4ae3d68","name":"ReadCSV","sep":";","hdrin":"","hdrout":"","multi":"mult","ret":"\\n","temp":"","skip":"0","x":120,"y":220,"wires":[["a0970e0b.a00a2"]]}]
