Hi all.
I noticed a day or so ago, I have stopped getting some values. The error is "TypeError: Cannot read property 'toString' of undefined"
and it comes from my 32bit Modbus converters, I have pasted the 32 bit code and complete flow, byt I cant understand why it would just start to do this?
Any recomendations please?
Thank You
[{"id":"66778f6e.e6ec1","type":"function","z":"6d01e3e4.6003b4","name":"Flow 1 32bit register coversion /100","func":"var low = msg.payload[0];\nvar high = msg.payload[1];\n\nvar lowhex = low.toString(16);\nvar highhex = high.toString(16);\n\nvar total = ((high << 16) + low) / 100;\n\nmsg.payload = total;\nmsg.measurement = \"W\";\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1340,"y":220,"wires":[["a9b4a1bf.e78"]]}]
[{"id":"6d01e3e4.6003b4","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"54ad2798.4a3dc8","type":"function","z":"6d01e3e4.6003b4","name":"FC 4 Add_3100 (18)","func":"msg.payload = { \n 'fc': 4, \n 'unitid': 2, \n 'address': 0x3100, \n 'quantity': 18\n}\n\nmsg.topic = \"livestats\";\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":180,"y":100,"wires":[["2fd5cbe9.42df14"]]},{"id":"5b319361.03f7c4","type":"inject","z":"6d01e3e4.6003b4","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":true,"onceDelay":"10","topic":"","payload":"1","payloadType":"str","x":90,"y":40,"wires":[["54ad2798.4a3dc8","371ad8d2.5eb44"]]},{"id":"2fd5cbe9.42df14","type":"modbus-flex-getter","z":"6d01e3e4.6003b4","name":"","showStatusActivities":false,"showErrors":false,"logIOActivities":false,"server":"f659adbe.b499a8","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":320,"y":160,"wires":[["6f2e521b.edc75c","12e028f6.20238f"],[]]},{"id":"6f2e521b.edc75c","type":"split","z":"6d01e3e4.6003b4","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":530,"y":120,"wires":[["5ced9593.c888dc"]]},{"id":"5ced9593.c888dc","type":"switch","z":"6d01e3e4.6003b4","name":"","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"2","vt":"str"},{"t":"eq","v":"3","vt":"str"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"5","vt":"str"},{"t":"eq","v":"6","vt":"str"},{"t":"eq","v":"7","vt":"str"},{"t":"eq","v":"8","vt":"str"},{"t":"eq","v":"9","vt":"str"},{"t":"eq","v":"E","vt":"str"},{"t":"eq","v":"F","vt":"str"},{"t":"eq","v":"12","vt":"str"},{"t":"eq","v":"13","vt":"str"},{"t":"eq","v":"14","vt":"str"},{"t":"eq","v":"15","vt":"str"},{"t":"eq","v":"16","vt":"str"},{"t":"eq","v":"17","vt":"str"},{"t":"eq","v":"","vt":"str"}],"checkall":"false","repair":false,"outputs":19,"x":690,"y":200,"wires":[["9286c5ac.8ecef"],["74fc517a.019128"],["f1d30f65.9c5a9"],["f1d30f65.9c5a9"],["35e35209.66106e"],["2400e4f3.6337a4"],["5acffb8.e1a6684"],["5acffb8.e1a6684"],["23d4d5eb.1426c2"],["f144bf25.c8005"],["6c7f8e0.3a3eef4"],["6c7f8e0.3a3eef4"],[],[],[],[],["d4d0aaa5.cc087"],["939ae148.f384c"],[]]},{"id":"9286c5ac.8ecef","type":"change","z":"6d01e3e4.6003b4","name":"SolarVoltage","rules":[{"t":"set","p":"topic","pt":"msg","to":"SolarVoltage","tot":"str"},{"t":"set","p":"SolarVoltage","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":40,"wires":[["1b866af4.cff2b5"]]},{"id":"74fc517a.019128","type":"change","z":"6d01e3e4.6003b4","name":"SolarCurrant","rules":[{"t":"set","p":"topic","pt":"msg","to":"SolarCurrant","tot":"str"},{"t":"set","p":"SolarCurrant","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":80,"wires":[["783feece.2885b"]]},{"id":"1b866af4.cff2b5","type":"range","z":"6d01e3e4.6003b4","minin":"1","maxin":"10000","minout":"1","maxout":"100","action":"scale","round":true,"property":"payload","name":"SV/100","x":1080,"y":20,"wires":[["678d22fc.6eaaac","54431f19.42f86"]]},{"id":"783feece.2885b","type":"range","z":"6d01e3e4.6003b4","minin":"1","maxin":"10000","minout":"1","maxout":"100","action":"scale","round":true,"property":"payload","name":"SC/100","x":1080,"y":60,"wires":[["fe7c8d55.107198","c97502.f0c513"]]},{"id":"678d22fc.6eaaac","type":"ui_text","z":"6d01e3e4.6003b4","group":"3bf43a81.2b807e","order":2,"width":0,"height":0,"name":"SolarVoltage","label":"Solar Voltage (V)","format":"{{msg.payload}}","layout":"col-center","x":1270,"y":20,"wires":[]},{"id":"fe7c8d55.107198","type":"ui_text","z":"6d01e3e4.6003b4","group":"3bf43a81.2b807e","order":1,"width":0,"height":0,"name":"SolarCurrant","label":"Solar Currant (A)","format":"{{msg.payload}}","layout":"col-center","x":1270,"y":60,"wires":[]},{"id":"f1d30f65.9c5a9","type":"join","z":"6d01e3e4.6003b4","name":"SolarPower","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"1","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":890,"y":120,"wires":[["946f29ac.37a58"]]},{"id":"946f29ac.37a58","type":"change","z":"6d01e3e4.6003b4","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"SolarPower","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1050,"y":120,"wires":[["66778f6e.e6ec1"]]},{"id":"66778f6e.e6ec1","type":"function","z":"6d01e3e4.6003b4","name":"Flow 1 32bit register coversion /100","func":"var low = msg.payload[0];\nvar high = msg.payload[1];\n\nvar lowhex = low.toString(16);\nvar highhex = high.toString(16);\n\nvar total = ((high << 16) + low) / 100;\n\nmsg.payload = total;\nmsg.measurement = \"W\";\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1340,"y":220,"wires":[["a9b4a1bf.e78"]]},{"id":"a9b4a1bf.e78","type":"switch","z":"6d01e3e4.6003b4","name":"","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"SolarPower","vt":"str"},{"t":"eq","v":"BatteryPower","vt":"str"},{"t":"eq","v":"LoadPower","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":1570,"y":220,"wires":[["350c1dd9.3d7e8a"],["ca329322.eb2c38"],["5528f5b1.036f94"]]},{"id":"350c1dd9.3d7e8a","type":"ui_text","z":"6d01e3e4.6003b4","group":"3bf43a81.2b807e","order":3,"width":0,"height":0,"name":"SolarPower","label":"Solar Power (W)","format":"{{msg.payload}}","layout":"col-center","x":1790,"y":160,"wires":[]},{"id":"35e35209.66106e","type":"change","z":"6d01e3e4.6003b4","name":"BatteryVoltage","rules":[{"t":"set","p":"topic","pt":"msg","to":"BatteryVoltage","tot":"str"},{"t":"set","p":"BatteryVoltage","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":900,"y":180,"wires":[["d87c92a8.750778"]]},{"id":"d87c92a8.750778","type":"range","z":"6d01e3e4.6003b4","minin":"1","maxin":"10000","minout":"1","maxout":"100","action":"scale","round":false,"property":"payload","name":"BV/100","x":1080,"y":200,"wires":[["6ad2d3e3.faa86c","a9c0b836.75f0e"]]},{"id":"6ad2d3e3.faa86c","type":"ui_text","z":"6d01e3e4.6003b4","group":"92374fdb.9d242","order":2,"width":5,"height":1,"name":"BatteryVoltage","label":"Battery Voltage (V)","format":"{{msg.payload}}","layout":"col-center","x":1200,"y":260,"wires":[]},{"id":"2400e4f3.6337a4","type":"change","z":"6d01e3e4.6003b4","name":"BatteryCurrant","rules":[{"t":"set","p":"topic","pt":"msg","to":"BatteryCurrant","tot":"str"},{"t":"set","p":"BatteryCurrant","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":220,"wires":[["83f3494.3223e38"]]},{"id":"83f3494.3223e38","type":"range","z":"6d01e3e4.6003b4","minin":"1","maxin":"10000","minout":"1","maxout":"100","action":"scale","round":true,"property":"payload","name":"BC/100","x":1060,"y":300,"wires":[["dcc280d9.d2cbb"]]},{"id":"dcc280d9.d2cbb","type":"ui_text","z":"6d01e3e4.6003b4","group":"92374fdb.9d242","order":1,"width":5,"height":1,"name":"BatteryCurrant","label":"Battery Currant (A)","format":"{{msg.payload}}","layout":"col-center","x":1300,"y":340,"wires":[]},{"id":"5acffb8.e1a6684","type":"join","z":"6d01e3e4.6003b4","name":"BatteryPower","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"1","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":920,"y":340,"wires":[["e7031e7d.34ee18"]]},{"id":"e7031e7d.34ee18","type":"change","z":"6d01e3e4.6003b4","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"BatteryPower","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1110,"y":380,"wires":[["66778f6e.e6ec1"]]},{"id":"ca329322.eb2c38","type":"ui_text","z":"6d01e3e4.6003b4","group":"92374fdb.9d242","order":5,"width":5,"height":1,"name":"BatteryPower","label":"Battery Power (W)","format":"{{msg.payload}}","layout":"col-center","x":1760,"y":220,"wires":[]},{"id":"23d4d5eb.1426c2","type":"change","z":"6d01e3e4.6003b4","name":"LoadVoltage","rules":[{"t":"set","p":"topic","pt":"msg","to":"LoadVoltage","tot":"str"},{"t":"set","p":"LoadVoltage","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":500,"wires":[["aa9a45bd.2b69a8"]]},{"id":"aa9a45bd.2b69a8","type":"range","z":"6d01e3e4.6003b4","minin":"1","maxin":"10000","minout":"1","maxout":"100","action":"scale","round":true,"property":"payload","name":"LV/100","x":1070,"y":480,"wires":[["7fd887d8.0baf9"]]},{"id":"7fd887d8.0baf9","type":"ui_text","z":"6d01e3e4.6003b4","group":"d0e60a67.4d8d6","order":2,"width":5,"height":1,"name":"LoadVoltage","label":"Load Voltage (V)","format":"{{msg.payload}}","layout":"col-center","x":1270,"y":480,"wires":[]},{"id":"f144bf25.c8005","type":"change","z":"6d01e3e4.6003b4","name":"LoadCurrant","rules":[{"t":"set","p":"topic","pt":"msg","to":"LoadCurrant","tot":"str"},{"t":"set","p":"LoadCurrant","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":890,"y":580,"wires":[["e19bc326.872e28"]]},{"id":"e19bc326.872e28","type":"range","z":"6d01e3e4.6003b4","minin":"1","maxin":"10000","minout":"1","maxout":"100","action":"scale","round":true,"property":"payload","name":"LC/100","x":1080,"y":560,"wires":[["83e20cc7.c538e8"]]},{"id":"83e20cc7.c538e8","type":"ui_text","z":"6d01e3e4.6003b4","group":"d0e60a67.4d8d6","order":1,"width":5,"height":1,"name":"LoadCurrant","label":"Load Currant (A)","format":"{{msg.payload}}","layout":"col-center","x":1270,"y":560,"wires":[]},{"id":"6c7f8e0.3a3eef4","type":"join","z":"6d01e3e4.6003b4","name":"LoadPower","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"1","count":"","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":830,"y":660,"wires":[["797cb612.7f17d8"]]},{"id":"797cb612.7f17d8","type":"change","z":"6d01e3e4.6003b4","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"LoadPower","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1090,"y":700,"wires":[["66778f6e.e6ec1"]]},{"id":"5528f5b1.036f94","type":"ui_text","z":"6d01e3e4.6003b4","group":"d0e60a67.4d8d6","order":3,"width":5,"height":1,"name":"LoadPower","label":"Load Power (W)","format":"{{msg.payload}}","layout":"col-center","x":1770,"y":300,"wires":[]},{"id":"9c402cb3.84a3c8","type":"ui_text","z":"6d01e3e4.6003b4","group":"92374fdb.9d242","order":6,"width":5,"height":1,"name":"BatteryTemperature","label":"Battery Temp. (°C)","format":"{{msg.payload}}","layout":"col-center","x":1090,"y":780,"wires":[]},{"id":"d4d0aaa5.cc087","type":"change","z":"6d01e3e4.6003b4","name":"BatteryTemperature","rules":[{"t":"set","p":"topic","pt":"msg","to":"BatteryTemperature","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":760,"y":740,"wires":[["33678140.b256be"]]},{"id":"33678140.b256be","type":"range","z":"6d01e3e4.6003b4","minin":"0","maxin":"10000","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"BT/100","x":840,"y":760,"wires":[["9c402cb3.84a3c8"]]},{"id":"fdfe2815.147488","type":"ui_text","z":"6d01e3e4.6003b4","group":"9d0d030a.31d","order":1,"width":5,"height":1,"name":"CaseTemperature","label":"Device Temp. (°C)","format":"{{msg.payload}}","layout":"col-center","x":1070,"y":820,"wires":[]},{"id":"939ae148.f384c","type":"change","z":"6d01e3e4.6003b4","name":"CaseTemperature","rules":[{"t":"set","p":"topic","pt":"msg","to":"CaseTemperature","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":700,"y":780,"wires":[["2d74da1b.726566"]]},{"id":"2d74da1b.726566","type":"range","z":"6d01e3e4.6003b4","minin":"0","maxin":"10000","minout":"0","maxout":"100","action":"scale","round":true,"property":"payload","name":"CT/100","x":840,"y":840,"wires":[["fdfe2815.147488"]]},{"id":"371ad8d2.5eb44","type":"link out","z":"6d01e3e4.6003b4","name":"","links":["2424ebbe.20330c","1a8e330.633f3cd","eed8fc15.cd5658"],"x":280,"y":40,"wires":[]},{"id":"54431f19.42f86","type":"influxdb out","z":"6d01e3e4.6003b4","influxdb":"94401065.fe856","name":"","measurement":"SolarVoltage","precision":"","retentionPolicy":"","x":1540,"y":20,"wires":[]},{"id":"c97502.f0c513","type":"influxdb out","z":"6d01e3e4.6003b4","influxdb":"94401065.fe856","name":"","measurement":"SolarCurrant","precision":"","retentionPolicy":"","x":1540,"y":60,"wires":[]},{"id":"a9c0b836.75f0e","type":"influxdb out","z":"6d01e3e4.6003b4","influxdb":"94401065.fe856","name":"","measurement":"BatteryVoltage","precision":"","retentionPolicy":"","x":1570,"y":400,"wires":[]},{"id":"12e028f6.20238f","type":"modbus-response","z":"6d01e3e4.6003b4","name":"3100 Response","registerShowMax":20,"x":490,"y":340,"wires":[]},{"id":"f659adbe.b499a8","type":"modbus-client","name":"TracerA12","clienttype":"serial","bufferCommands":true,"stateLogEnabled":true,"queueLogEnabled":false,"tcpHost":"192.168.4.25","tcpPort":"23","tcpType":"TELNET","serialPort":"/dev/ttyUSB0","serialType":"RTU-BUFFERD","serialBaudrate":"115200","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"2","commandDelay":"100","clientTimeout":"2000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":false},{"id":"3bf43a81.2b807e","type":"ui_group","name":"Solar Information","tab":"28c10730.74ad38","order":1,"disp":true,"width":5,"collapse":true},{"id":"92374fdb.9d242","type":"ui_group","name":"Battery Information","tab":"28c10730.74ad38","order":2,"disp":true,"width":5,"collapse":false},{"id":"d0e60a67.4d8d6","type":"ui_group","name":"DC Load Information","tab":"28c10730.74ad38","order":3,"disp":true,"width":5,"collapse":false},{"id":"9d0d030a.31d","type":"ui_group","name":"Controller Information","tab":"28c10730.74ad38","order":4,"disp":true,"width":5,"collapse":false},{"id":"94401065.fe856","type":"influxdb","hostname":"127.0.0.1","port":"8086","protocol":"http","database":"Solar","name":"Grafana","usetls":false,"tls":"","influxdbVersion":"1.x"},{"id":"28c10730.74ad38","type":"ui_tab","name":"Solar PV Equipment","icon":"dashboard","disabled":false,"hidden":false}]
