The current msg.payload is a string (actually is a JSON string - see the "{"batV":.. etc...} your picture) so when you attempt to set msg.payload.content you get an error - because a string is not an object.
try...
msg.payload = {}; //set payload up as a new empty {object}
msg.payload.content = {}; //set payload.content up as a new empty {object}
msg.payload.content.whatever = whatever_i_want; //now you can add properties to the object
few things...
- please always surround code or JSON with triple backticks
like this
``` - is there any reason you
setflow context thengetit straight back out of context? (Also, note there is a typo in line 5 - to avoid typos, use the copy path button in the debug side-bar (it appears when you hover over a debug value) - your payload already has the lat/lon but in JSON - where is this payload coming from? If it is from MQTT node, you can have the MQTT node turn the JSON into an object (set MQTT In node to auto parse JSON)
