Hello.
I have strange and interesting behaviour of function node. Script in Function node is only to form payload. In most cases it gives correct payload, but sometimes gives error "TypeError: Cannot set properties of undefined (setting 'snr')". snr parameter is always present in same format and path. Script is following:
var device_id = msg.payload.end_device_ids.device_id;
var gateway_id=msg.payload.uplink_message.rx_metadata[0].gateway_ids.gateway_id
var snr=msg.payload.uplink_message.rx_metadata[0].snr
var rssi=msg.payload.uplink_message.rx_metadata[0].rssi
var sf=msg.payload.uplink_message.settings.data_rate.lora.spreading_factor
msg.payload.uplink_message.decoded_payload["snr"] = snr
msg.payload.uplink_message.decoded_payload["rssi"] = rssi
msg.payload.uplink_message.decoded_payload["sf"] = sf
msg.payload.uplink_message.decoded_payload["gateway_id"] = gateway_id
fields=msg.payload.uplink_message.decoded_payload
tags = {
// "timestamp" : timestamp,
"device_id" : device_id,
msg.payload=[fields, tags]
This problem relates to snr value only.
Is there any reasonable explanation or solution to this error?
Thank You.
Hi @Roberto69
The error will be coming from the line:
This is the first time you are accessing msg.payload.uplink_message.decoded_payload
- so this suggests that property doesn't exist on the message the function has received.
Hi @knolleary
I guess this is beacuse snr is before other parameters - if rssi would be first, than error will relate to rssi?
How can I avoid this?
@Roberto69 that error is saying msg.payload.uplink_message.decoded_payload
is NOT "something"
You have a few choices:
- check it is empty & throw an error or return
- create it if it is empty
- skip it if empty
1
if (!msg.payload?.uplink_message?.decoded_payload) {
node.error("msg does not contain decoded_payload", msg)
return
2
msg.payload.uplink_message = msg.payload.uplink_message || {}
msg.payload.uplink_message.decoded_payload = {}
3
if (msg.payload?.uplink_message?.decoded_payload) {
msg.payload.uplink_message.decoded_payload.snr = snr
msg.payload.uplink_message.decoded_payload.rssi = rssi
msg.payload.uplink_message.decoded_payload.sf = sf
msg.payload.uplink_message.decoded_payload.gateway_id = gateway_id
That is right.
Do you expect msg.payload.uplink_message.decoded_payload
to already exist on the message or is this a new property you are wanting to create?
If its a new thing, then you can do the following to create that object with the four properties set on it:
snr,
rssi,
sf,
gateway_id
