"TypeError: Cannot read property 'decoded_payload' of undefined"
When I inject code:
    "received_at": "2022-02-27T23:45:18.013631675Z",
    "uplink_message": {
        "session_key_id": "AX88sOZsNTkoN5rZ+Rzx/Q==",
        "f_port": 1,
        "f_cnt": 80,
        "frm_payload": "SGVsbG8sIHdvcmxkIQ==",
        "decoded_payload": {
            "degreesC": 20.20263671875,
            "humidity": 38.1103515625
into function node:
var thing = [{
    degreesC: msg.payload.uplink_message.decoded_payload.degreesC,
    humidity: msg.payload.uplink_message.decoded_payload.humidity,
msg.payload = thing;
I get
2/27/2022, 7:06:04 PMnode: a99be1c0d3d3695d
msg.payload : array[1]
array[1]
0: object
degreesC: 20.20263671875
humidity: 38.1103515625
So everything works fine. But when I feed the following (basically the same) MQTT payload into the same function:
    "end_device_ids": {
        "device_id": "eui-70b3d57ed004d388",
        "application_ids": {
            "application_id": "mqtt-rpi3b"
        "dev_eui": "70B3D57ED004D388",
        "join_eui": "0000000000000000",
        "dev_addr": "260C0875"
    "correlation_ids": [
        "as:up:01FWYS5ZNTV0C25QZG3CZYW2WY",
        "gs:conn:01FWY7ADE93XZZ8A72N1EHDH2S",
        "gs:up:host:01FWY7ADJXWZWYHXHR5852CGS8",
        "gs:uplink:01FWYS5ZF1JRJDHCP9SDDMN718",
        "ns:uplink:01FWYS5ZF4TDHF5473B8CBK29V",
        "rpc:/ttn.lorawan.v3.GsNs/HandleUplink:01FWYS5ZF4744HNW8ZJ25RDB26",
        "rpc:/ttn.lorawan.v3.NsAs/HandleUplink:01FWYS5ZNS2ZXRQ5WT1B7GV9VX"
    "uplink_message": {
        "f_port": 1,
        "f_cnt": 80,
I get:
2/27/2022, 7:05:34 PMnode: Test
function : (error)
I'm just learning this stuff, so be kind.
From what you have shown us, it seems your code and data are fine but obviously something else is going on. Lets add some debug messages to your function...
if(!msg.payload.uplink_message) {
  node.warn(["this msg does not have '.payload.uplink_message' - look closely at its content", msg]);
var thing = [{
I needed to "Always convert to JavaScript Object' by adding a JSON node before the function.
Thanks!
