UI Dropdown - weird phenomena when using numbers as options, can you explain?
hello,
I found a weird behaviour with the ui_dropdown when using it with numbers as options.
Basically when the options are dynamically defined in the flow, each value can only be selected once( weird, right ?). Example: say you have a dropdown with 4 options: 1, 2, 3, 4 . If you select 1, the dropdown payload will be set to 1 as expected. The same happens if afterwards one selects 2. However, if after one attempts to select 1 again the payload will be always empty for whatever option you've selected before. The workaround I found was to send the options again to the dropdown but I think we should not have to.
When using a dropdown with options statically defined, everything works normally. Therefore, you can freely jump between options and have the payload always updated accordingly.
I'm using v2.23.4 of node-red-dashboard.
Find below a flow to quickly see the described behaviour:
thanks for your help, cheers
[{"id":"b1341bfd.e517d8","type":"tab","label":"Debug flow","disabled":false,"info":""},{"id":"deca38e1.e7e458","type":"inject","z":"b1341bfd.e517d8","name":"","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":140,"wires":[["82913aaf.7dd868"]]},{"id":"82913aaf.7dd868","type":"function","z":"b1341bfd.e517d8","name":"generateOptionsNumbers","func":"var newMsg = {};\n\nnewMsg.options=[1,2,3,4];\nreturn newMsg","outputs":1,"noerr":0,"initialize":"","finalize":"","x":410,"y":140,"wires":[["1cc7342f.ae536c"]]},{"id":"1cc7342f.ae536c","type":"ui_dropdown","z":"b1341bfd.e517d8","name":"","label":"dropdown dynamic","tooltip":"","place":"Select option","group":"b07c8076.b2f8c","order":2,"width":0,"height":0,"passthru":true,"multiple":false,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":710,"y":140,"wires":[["7a3f3f73.1eed8"]]},{"id":"424a30.9a6fc5d","type":"ui_dropdown","z":"b1341bfd.e517d8","name":"","label":"dropdown static","tooltip":"","place":"Select option","group":"b07c8076.b2f8c","order":1,"width":0,"height":0,"passthru":true,"multiple":false,"options":[{"label":"","value":1,"type":"num"},{"label":"","value":2,"type":"num"},{"label":"","value":3,"type":"num"},{"label":"","value":4,"type":"num"}],"payload":"","topic":"","x":700,"y":60,"wires":[["7a3f3f73.1eed8"]]},{"id":"7a3f3f73.1eed8","type":"debug","z":"b1341bfd.e517d8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":930,"y":60,"wires":[]},{"id":"b07c8076.b2f8c","type":"ui_group","z":"","name":"Test","tab":"5ec0d4bf.b1de9c","order":1,"disp":true,"width":"6","collapse":false},{"id":"5ec0d4bf.b1de9c","type":"ui_tab","z":"","name":"LAB","icon":"dashboard"}]
Welcome to the forum @diogom8.
I am not seeing that. I suggest upgrading to the latest dashboard (2.26.1).
hello @Colin , thanks for the quick reply.
indeed, upgrading to the latest dashboard solved the issue. thanks for your help!
cheers
