Ui-media node and ui-control
Hi I need your help.
I have a video, on the pc and I wanted to put it on the dashboard to run automatically.
I'm using , node ui-media for the video and I'm also using ui-control to automatically switch between tabs (I have two tabs one with graphics and the other video)
What I intended is that when I opened the video tab it would start automatically, or in the last case it would be running permanently. (but it only starts when I press play)
I already put the options "run on start" does not work
I already injected with the message according to the node.
Can anyone tell me, what am I doing wrong?????
Check with the Ui_control if the user switch to the dashboard tab with the media video. (in this example MyTab)
Then send the play command to the media player to start playing.
Something like this, not tested.
[{"id":"f541cbd5620db72e","type":"ui_media","z":"92b7e6e4944123df","group":"77e5165.15420e8","name":"","width":0,"height":0,"order":9,"category":"","file":"","layout":"adjust","showcontrols":true,"loop":true,"onstart":true,"scope":"local","tooltip":"","x":810,"y":280,"wires":[[]]},{"id":"d06752b974f2c0f3","type":"ui_ui_control","z":"92b7e6e4944123df","name":"","events":"all","x":260,"y":280,"wires":[["798570dc1d6fc934","14d529575f6744c9"]]},{"id":"302f14e41d5399ac","type":"debug","z":"92b7e6e4944123df","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":830,"y":200,"wires":[]},{"id":"798570dc1d6fc934","type":"switch","z":"92b7e6e4944123df","name":"","property":"name","propertyType":"msg","rules":[{"t":"eq","v":"MyTab","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":430,"y":280,"wires":[["ee08782890b07a9e"],[]]},{"id":"ee08782890b07a9e","type":"change","z":"92b7e6e4944123df","name":"","rules":[{"t":"set","p":"play","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":280,"wires":[["302f14e41d5399ac","f541cbd5620db72e"]]},{"id":"14d529575f6744c9","type":"debug","z":"92b7e6e4944123df","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":430,"y":200,"wires":[]},{"id":"77e5165.15420e8","type":"ui_group","name":"Default","tab":"492f408.019aa4","order":1,"disp":true,"width":"14","collapse":false},{"id":"492f408.019aa4","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Thanks edje11.
I tried, and also checked if I put the video always running, when the UI-Control switch to the dashboard tab the video starts again automatically.
Thanks for your help
