Ui_numeric does not show label if passed on in a msg
I just installed v1.3.2 of Node-RED
So far it was possible to use e.g. msg.topic to set the label in ui_numeric. Strange enough, it looks like this does not function anymore....
The label remains empty on the dashboard.
ui_button works well!
Try {{topic}} instead of {{msg.topic}}
I am sorry @hotNipi but this does look like the solution. Unfortunately.
Are you using the latest version of node-red-dashboard (2.28.2)?
This is working for me with
14 Apr 07:13:25 - [info] Node-RED version: v1.3.2
14 Apr 07:13:25 - [info] Node.js version: v14.16.0
14 Apr 07:13:25 - [info] Darwin 18.7.0 x64 LE
14 Apr 07:13:25 - [info] Loading palette nodes
14 Apr 07:13:30 - [info] Worldmap version 2.13.0
14 Apr 07:13:31 - [info] Dashboard version 2.28.2 started at /ui
Yes, I use v2.28.2
I have node v12.21.0, might this cause the problem?
what platform are you running NR on?
and what OS/version?
The platform is Pi-4, Raspbian version:
Linux Domotica 5.10.11-v7l+ #1399 SMP Thu Jan 28 12:09:48 GMT 2021 armv7l GNU/Linux
