Ui-radio-group - Dynamic Properties
Hello all!
I'm trying to create dynamic content for a ui-radio-group in DB2.
I think I've followed the documentation properly and also reviewed this other post but I can't still get the radio group to populate.
I'm sending msg.ui_update.options as an array with value, label objects.
Is there some other configuration to be performed?
Thanks in advance.
This function node works for me to set the radio group label and options. I can't immediately see how it differs from your debug example. No payload maybe?
msg = {
    "ui_update": {
        "label": "Livestock",
        "options": [
            {"value":"sheep", "label": "Ewes"},
            {"value":"goats", "label": "Nannies"}
Thanks!
you're payload and mine look identical, and neither of both is working for me.
Here's my sample flow
        "id": "2d0c429dc57e5397",
        "type": "tab",
        "label": "radios",
        "disabled": false,
        "info": "",
        "env": []
        "id": "5a48e9deef115886",
        "type": "function",
        "z": "2d0c429dc57e5397",
        "name": "function 5",
        "func": "msg = {\n    \"ui_update\": {\n        \"label\": \"Livestock\",\n        \"options\": [\n            {\"value\":\"sheep\", \"label\": \"Ewes\"}, \n            {\"value\":\"goats\", \"label\": \"Nannies\"}\n        ]\n    }\n}\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 525,
        "y": 180,
                "743d697d732e2d76",
                "ccdaf331c03c6ac2"
        "l": false
        "id": "dab4bc3e32e6a077",
        "type": "inject",
        "name": "Test1",
        "props": [
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Test 1",
        "x": 410,
        "y": 180,
                "5a48e9deef115886"
        "id": "743d697d732e2d76",
        "type": "ui-radio-group",
        "group": "82cd48b1245f94e0",
        "label": "Select Option:",
        "order": 2,
        "width": 0,
        "height": 0,
        "columns": 1,
        "passthru": false,
        "options": [],
        "payload": "",
        "topic": "topic",
        "topicType": "msg",
        "className": "",
        "x": 625,
        "y": 220,
        "l": false
        "id": "750937df1713f138",
        "type": "function",
        "name": "function 6",
        "func": "msg = {\n    \"ui_update\":{\n        \"label\" : \"Test label\",\n        \"options\":[\n            {\"value\":\"10\",\"label\":\"Kids\"},\n            {\"value\":\"11\",\"label\":\"Playroom\"},\n            {\"value\":\"12\",\"label\":\"Kitchen\"}\n        ]\n    }\n}\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 525,
        "y": 220,
                "743d697d732e2d76",
                "ccdaf331c03c6ac2"
        "l": false
        "id": "984d3c31ed733170",
        "type": "inject",
        "name": "Test 2",
        "props": [
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "Test2",
        "x": 410,
        "y": 220,
                "750937df1713f138"
        "id": "ccdaf331c03c6ac2",
        "type": "debug",
        "name": "debug 996",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 625,
        "y": 180,
        "wires": [],
        "l": false
        "id": "82cd48b1245f94e0",
        "type": "ui-group",
        "name": "Radio-button-test",
        "page": "f2fcbbc30322192c",
        "width": "6",
        "height": "1",
        "order": -1,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "f2fcbbc30322192c",
        "type": "ui-page",
        "name": "radio-button-test",
        "ui": "cb79bc4520925e32",
        "path": "/rbt",
        "icon": "home",
        "layout": "grid",
        "theme": "2220d11175c576f3",
        "order": -1,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "cb79bc4520925e32",
        "type": "ui-base",
        "name": "My UI",
        "path": "/dashboard",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control",
            "ui-text"
        "showPathInSidebar": false,
        "showPageTitle": true,
        "titleBarStyle": "default"
        "id": "2220d11175c576f3",
        "type": "ui-theme",
        "name": "Theme DB2",
        "colors": {
            "surface": "#ffffff",
            "primary": "#0094ce",
            "bgPage": "#eeeeee",
            "groupBg": "#ffffff",
            "groupOutline": "#cccccc"
        "sizes": {
            "pagePadding": "12px",
            "groupGap": "12px",
            "groupBorderRadius": "4px",
            "widgetGap": "12px",
            "density": "default"
Your ui_update works for me.
Check the version of your @flowfuse/node-red-dashboard.
I have 1.15.0 and Node-red 4.0.2
Thanks for your help jbudd.
I'm using exactly the same versions.
Also tried @flowfuse/node-red-dashboard v1.14.0 with same result.
Tried 3 different node-red instances (all v.4.0.2), tried different clients and different browsers all without luck...
Did you try importing the flow? It doesn't work for me either.
Good question.
I imported the flow
Then I took just this function and put it in my flow
msg = {
    "ui_update":{
        "label" : "Test label",
        "options":[
            {"value":"10","label":"Kids"},
            {"value":"11","label":"Playroom"},
            {"value":"12","label":"Kitchen"}
I deployed and hit the inject button and this is what I see.
I assume you hit deploy. Does it make a difference if you clear the browser cache? Restart Node-red? (I did not do find either of those necessary but there is something possibly cache related going on because I can't get back to my original, not dynamic, radio group options)
Does the full flow work for you?
Isn't that a button group, not a radio group?
Hello jbudd
you're screenshot seem to be based on ui-button-group (see demo) but my flow contains ui-radio-group (see demo)
I suggest you open an issue at Issues · FlowFuse/node-red-dashboard · GitHub.
Include your flow in the description. Post a link back here.
Doh! Forget I spoke. :face_with_open_eyes_and_hand_over_mouth:
Actually, I am not sure that 1.15 includes dynamic updates. I think the docs may be ahead of the code. Hang on until the next release, which is due within a day or two I think.
Thanks Colin!
issue 1260 created.
@juanbal , @colin was correct in that the docs are a step ahead of the release.
this will be addressed soon.
Dynamic prop support for radio group has been merged but there is an outstanding release imminent.
node-red-dashboard (node) - Node-RED v1.16.0 now released.
It can take up to 30 mins for it to appear in Node-RED catalog under Manage Palette.
You can of course hurry this along with a manual install npm i @flowfuse/node-red-dashboard@latest
