Ui-table supports ui_control
Hi,
reading the docs it seams like the loader is working together with population ui-table with AJAX:
ajaxLoaderLoading string html (see below) html for loader element
ajaxLoaderError string html (see below) html for the loader element in the event of an error
If you are using AJAX loading mechanism than you should be able to pass the HTML simply by sending it with msg.ui_control.tabulator or use the default HTML.
Filling the table by passing an array will never show up a loading screen as the table is created together with the data. When using commands tabulator starts with an empty table and then shows data as it arrives.
