UI_template button - not refreshing dashboard
Hi and welcome.
Have you tried unchecking all but refresh on reload at bottom of config.
If this does not fix issue can you export a minimal example of this flow. How to import/export a flow
   code goes here
You can edit and correct your post by clicking the pencil :pencil2: icon.
