Ui-template: javascript to run function when a global var define in script changes
Hi all, I'm writing a script in ui-template and I defined a global var. I would like to add a function which is called when the global var change
    var generic;
    function sendMessage(){
        scope.send({payload: generic});
    function changeVar(){
        generic = "newValue"
    **//if generic change**
        sendMessage()
it is possible?
many thanks
Anything is possible
First, what dashboard are you using? The old V1 node-red-dashboard OR the new Dashboard 2.0 @flowfuse/node-red-dashboard?
for D1, just create an object with getters and setters:
e.g.
class MyClass {
  constructor(scope) {
    this.scope = scope
    this._myProperty = undefined;
  get myProperty() {
    return this._myProperty;
  set myProperty(value) {
    this._myProperty = value;
    this.scope.send({payload: value});
let obj = new MyClass(scope);
obj.myProperty = 42 // will call the setter and trigger scope.send
In dashboard 2.0, this is much easier: you add a watch on the data variable and call this.send (Dashboard 2.0 is vue based so things get a fair bit easier)
EDIT:
I am fairly certain AngularJS has watchers too so someone may come along with a simpler AngularJS way that i dont know.
It does, though Dashboard 1 only gives you limited access. Been a long time since I used D1 in anger but I know that my blog contains an example, the cookbook probably does as well.
Of course, this is very simple in UIBUILDER :wink:
many thanks it works
