Uibrouter.iife.min.js Unable to load Grafana Graph (same IP, different Port)
I am trying to display a couple of Grafana graphs in a UIBUILDER webpage. I can load the graphs into a Browser if I put the link into the address bar, but they won't load in the webpage. The error in the browser shows:
Framing '``http://<IP>:3001/``' violates the following Content Security Policy directive: "frame-src 'self' https:". The request has been blocked.
I think I get that as the link points to a different port, the file indicated as causing the error is uibrouter.iife.min.js, but I can't find frame-source in that file, although I can see the word strict.
I reference the uibrouter.iife.min.js file in my index.html header
<script defer src="../uibuilder/uibuilder.iife.min.js"></script>
<script defer src="../uibuilder/utils/uibrouter.iife.min.js"></script>
<script defer src="./js/index.js">
It seems that in my SPA website, I also need this available for my index.js
// ----- Start of Routing ----- //
const router = new UibRouter(routerConfig)
// ---------- Setup: Centralised Message Handling for SPA ---------- //
uibuilder.onChange("msg", handleUibMsg);
The SPA Message Handling is a script @Paul-Reed kindly allowed me to use.
Commenting either of these out does not help! Nothing appears to load except the Navigation Menu text.
I have looked at the Documents and the only references I can find are to Navigation Menus, or at least, that is all I can get from reading them. They do show examples of 'external template', but I don't understand. The drugs don't help!
I think that is all of the information, so the question is... How do I get a 'remote' (same IP, different Port) link/image to appear in a UIBUILDER webpage?
As usual, I am probably missing something very basic, but I don't know how to proceed!
TIA,
Colin J
OK, doing some more research using AI and referencing the Docs along with a post, it seems I need to define the contentSecurityPolicy in settings.js. Indeed, an enhancement was made to enable this in V7.6.1 of UIBUILDER.
I now need to find out how to add the contentSecurityPolicysetting for UIBUILDER in settings.js
I can't believe this, after working on this all day, I have now managed to get it working! I have achieved more in the last hour or so than the previous seven!
Assembling data from AI, the referenced post, UIBUILDER V7 Docs, and trying a couple of times of editing settings.js, I can now see a couple of Graphs in my webpages.
So, the UIBUILDER 'script' goes into settings.js, just before the last curly bracket. If you put it after, Node-Red won't start!
// nodeDefaults: {
//     "debug": {
//         "complete": true // set the debug node to show complete msg by default
uibuilder: {
contentSecurityPolicy: {
"default-src": "'self' 'unsafe-inline' data: blob: https:;",
"connect-src": "'self';",
"img-src": "'self' data: blob: https:;",
"font-src": "'self' data: https:;",
"style-src": "'self' 'unsafe-inline' data: blob: https:;",
"script-src": "'self' 'unsafe-inline' 'unsafe-eval' blob: https:;",
"frame-src": "'self' https: http://<MyIP>:3001;"
@TotallyInformation can you check this to make sure it is OK. It was suggested by my mate Claude.
Thank you to all who read this!
You will know if it’s wrong because something won’t work. :grin: those security settings for browsers are quite sensitive.
I feel that we have been here before, but with the drugs I am on, my short term memory is shot. I suppose it could be the advancing years, but who knows!!
