Thanks for your comments, i'm trying to digest them.
I have tried not to modify the default scripts to much as i'm learning as i go. changing one thing at a time and making sure it works.
I'm loading from house.html, this is the bottom for the file:
<!-- REQUIRED: Sets up Socket listeners and the msg object -->
<script src="./uibuilderfe.min.js"></script>
<script src="../uibuilder/vendor/vue-enhanced-check/dist/vue-enhanced-check.js"></script>
<!-- OPTIONAL: You probably want this. Put your custom code here -->
<script src="./house.js"></script>
and the house.js :
import { EnhancedCheck, EnhancedCheckGroup, EnhancedCheckRadio, EnhancedToggle } from 'vue-enhanced-check'
'use strict'
/** @see https://github.com/TotallyInformation/node-red-contrib-uibuilder/wiki/Front-End-Library---available-properties-and-methods */
export default {
components: { EnhancedCheck, EnhancedCheckGroup, EnhancedCheckRadio, EnhancedToggle },
// eslint-disable-next-line no-unused-vars
var house = new Vue({
el: '#app',
data: {
startMsg: 'Vue has started, waiting for messages',
feVersion: '',
centerLight: false,
the reset is the same as the default index.js
kind regards daniel
ps. i did look briefly @ the chart tools. but got a bit lost. I have been trying for a few days and don't like bothering you busy folk.
