Hello!
First of all, I would like to thank the great work done by all the people in this forum!
This is my first time with uibuilder and I've been testing it with some of its features. Now I want to go a little further and try vue-router without a build step but I can't get it to work.
I have tried to make a very simple test with the information that appears in (https://github.com/TotallyInformation/node-red-contrib-uibuilder/wiki/Using-Vue-Router) but I can't make it works. I want to do a simple two "pages" navigation: "home" and "about".
This is my folder structure:
With index.js:
'use strict'
import router from './router.js';
const app1 = new Vue({
el: '#app',
data: {
startMsg: 'Vue has started, waiting for messages',
feVersion: '',
counterBtn: 0,
inputText: null,
inputChkBox: false,
socketConnectedState: false,
serverTimeOffset: '[unknown]',
imgProps: { width: 75, height: 75 },
msgRecvd: '[Nothing]',
msgsReceived: 0,
msgCtrl: '[Nothing]',
msgsControl: 0,
msgSent: '[Nothing]',
msgsSent: 0,
msgCtrlSent: '[Nothing]',
msgsCtrlSent: 0,
}, // --- End of data --- //
computed: {
hLastRcvd: function () {
var msgRecvd = this.msgRecvd
if (typeof msgRecvd === 'string') return 'Last Message Received = ' + msgRecvd
else return 'Last Message Received = ' + this.syntaxHighlight(msgRecvd)
hLastSent: function () {
var msgSent = this.msgSent
if (typeof msgSent === 'string') return 'Last Message Sent = ' + msgSent
else return 'Last Message Sent = ' + this.syntaxHighlight(msgSent)
hLastCtrlRcvd: function () {
var msgCtrl = this.msgCtrl
if (typeof msgCtrl === 'string') return 'Last Control Message Received = ' + msgCtrl
else return 'Last Control Message Received = ' + this.syntaxHighlight(msgCtrl)
hLastCtrlSent: function () {
var msgCtrlSent = this.msgCtrlSent
if (typeof msgCtrlSent === 'string') return 'Last Control Message Sent = ' + msgCtrlSent
//else return 'Last Message Sent = ' + this.callMethod('syntaxHighlight', [msgCtrlSent])
else return 'Last Control Message Sent = ' + this.syntaxHighlight(msgCtrlSent)
}, // --- End of computed --- //
methods: {
increment: function () {
// Increment the count by one
this.counterBtn = this.counterBtn + 1
var topic = this.msgRecvd.topic || 'uibuilder/vue'
uibuilder.send({
'topic': topic,
'payload': {
'type': 'counterBtn',
'btnCount': this.counterBtn,
'message': this.inputText,
'inputChkBox': this.inputChkBox
}, // --- End of increment --- //
// return formatted HTML version of JSON object
syntaxHighlight: function (json) {
json = JSON.stringify(json, undefined, 4)
json = json.replace(/&/g, '&').replace(/</g, '<').replace(/>/g, '>')
json = json.replace(/("(\\u[a-zA-Z0-9]{4}|\\[^u]|[^\\"])*"(\s*:)?|\b(true|false|null)\b|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?)/g, function (match) {
var cls = 'number'
if (/^"/.test(match)) {
if (/:$/.test(match)) {
cls = 'key'
} else {
cls = 'string'
} else if (/true|false/.test(match)) {
cls = 'boolean'
} else if (/null/.test(match)) {
cls = 'null'
return '<span class="' + cls + '">' + match + '</span>'
return json
}, // --- End of syntaxHighlight --- //
}, // --- End of methods --- //
// Available hooks: init,mounted,updated,destroyed
mounted: function () {
//console.debug('[indexjs:Vue.mounted] app mounted - setting up uibuilder watchers')
/** **REQUIRED** Start uibuilder comms with Node-RED @since v2.0.0-dev3
* Pass the namespace and ioPath variables if hosting page is not in the instance root folder
* e.g. If you get continual `uibuilderfe:ioSetup: SOCKET CONNECT ERROR` error messages.
* e.g. uibuilder.start('/nr/uib', '/nr/uibuilder/vendor/socket.io') // change to use your paths/names
uibuilder.start()
var vueApp = this
// Example of retrieving data from uibuilder
vueApp.feVersion = uibuilder.get('version')
/** You can use the following to help trace how messages flow back and forth.
* You can then amend this processing to suite your requirements.
//#region ---- Trace Received Messages ---- //
// If msg changes - msg is updated when a standard msg is received from Node-RED over Socket.IO
// newVal relates to the attribute being listened to.
uibuilder.onChange('msg', function (newVal) {
//console.info('[indexjs:uibuilder.onChange] msg received from Node-RED server:', newVal)
vueApp.msgRecvd = newVal
// As we receive new messages, we get an updated count as well
uibuilder.onChange('msgsReceived', function (newVal) {
//console.info('[indexjs:uibuilder.onChange] Updated count of received msgs:', newVal)
vueApp.msgsReceived = newVal
// If we receive a control message from Node-RED, we can get the new data here - we pass it to a Vue variable
uibuilder.onChange('ctrlMsg', function (newVal) {
//console.info('[indexjs:uibuilder.onChange:ctrlMsg] CONTROL msg received from Node-RED server:', newVal)
vueApp.msgCtrl = newVal
// Updated count of control messages received
uibuilder.onChange('msgsCtrl', function (newVal) {
//console.info('[indexjs:uibuilder.onChange:msgsCtrl] Updated count of received CONTROL msgs:', newVal)
vueApp.msgsControl = newVal
//#endregion ---- End of Trace Received Messages ---- //
//#region ---- Trace Sent Messages ---- //
// You probably only need these to help you understand the order of processing //
// If a message is sent back to Node-RED, we can grab a copy here if we want to
uibuilder.onChange('sentMsg', function (newVal) {
//console.info('[indexjs:uibuilder.onChange:sentMsg] msg sent to Node-RED server:', newVal)
vueApp.msgSent = newVal
// Updated count of sent messages
uibuilder.onChange('msgsSent', function (newVal) {
//console.info('[indexjs:uibuilder.onChange:msgsSent] Updated count of msgs sent:', newVal)
vueApp.msgsSent = newVal
// If we send a control message to Node-RED, we can get a copy of it here
uibuilder.onChange('sentCtrlMsg', function (newVal) {
//console.info('[indexjs:uibuilder.onChange:sentCtrlMsg] Control message sent to Node-RED server:', newVal)
vueApp.msgCtrlSent = newVal
// And we can get an updated count
uibuilder.onChange('msgsSentCtrl', function (newVal) {
//console.info('[indexjs:uibuilder.onChange:msgsSentCtrl] Updated count of CONTROL msgs sent:', newVal)
vueApp.msgsCtrlSent = newVal
//#endregion ---- End of Trace Sent Messages ---- //
// If Socket.IO connects/disconnects, we get true/false here
uibuilder.onChange('ioConnected', function (newVal) {
//console.info('[indexjs:uibuilder.onChange:ioConnected] Socket.IO Connection Status Changed to:', newVal)
vueApp.socketConnectedState = newVal
// If Server Time Offset changes
uibuilder.onChange('serverTimeOffset', function (newVal) {
//console.info('[indexjs:uibuilder.onChange:serverTimeOffset] Offset of time between the browser and the server has changed to:', newVal)
vueApp.serverTimeOffset = newVal
}, // --- End of mounted hook --- //
router: new VueRouter(router),
}) // --- End of app1 --- //
// EOF
index.html:
<!doctype html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, minimum-scale=1, initial-scale=1, user-scalable=yes">
<title>Node-RED UI Builder - VueJS + bootstrap-vue version</title>
<meta name="description" content="Node-RED UI Builder - VueJS + bootstrap-vue version">
<link rel="icon" href="./images/node-blue.ico">
<link type="text/css" rel="stylesheet" href="../uibuilder/vendor/bootstrap/dist/css/bootstrap.min.css" />
<link type="text/css" rel="stylesheet" href="../uibuilder/vendor/bootstrap-vue/dist/bootstrap-vue.css" />
<link rel="stylesheet" href="./index.css" media="all">
</head>
<body>
<div id="app">
<p>Loaded</p>
<div>
<b-nav>
<b-nav-item active>Active</b-nav-item>
<b-nav-item to="/home">Home</b-nav-item>
<b-nav-item to="/about">About</b-nav-item>
</b-nav>
</div>
<b-container fluid>
<router-view></router-view>
</b-container>
</div>
<script src="../uibuilder/vendor/socket.io/socket.io.js"></script>
<script src="../uibuilder/vendor/vue/dist/vue.js"></script> <!-- dev version with component compiler -->
<script src="../uibuilder/vendor/bootstrap-vue/dist/bootstrap-vue.js"></script>
<!-- HTTP Vue Loader -->
<script src="https://unpkg.com/http-vue-loader"></script>
<!-- VueX -->
<script src="../uibuilder/vendor/vuex/dist/vuex.js"></script>
<!-- Vue Router -->
<script src="../uibuilder/vendor/vue-router/dist/vue-router.js"></script>
<script src="./uibuilderfe.min.js"></script> <!-- //prod version -->
<script src="./index.js" type="module"></script>
</body>
</html>
router.js:
const Home = httpVueLoader('./views/home.vue')
const About= httpVueLoader('./views/about.vue')
export default {
routes: [
path: '/',
components: Home,
path: '/',
components: About,
and .vue files are very simple:
<template>
<b-row>
this is about page
</b-row>
</template>
Please, Can someone help me or share some simple example?
Thanks!
