I got my first object "SHM":
const myDevices = ['SHM'];
myDevices.forEach(dev => {
uibuilder.onTopic(dev, (msg) => {
uibuilder.set(dev, msg.payload);
if (dev === 'SHM' && msg.payload) {
if (msg.payload.P !== undefined) {
uibuilder.set('SHM_P_class', msg.payload.P < 0 ? 'green' : '');
if (msg.payload.P0 !== undefined) {
uibuilder.set('SHM_P0_class', msg.payload.P0 < 0 ? 'green' : '');
the value is shown, but I don´t get it green:
<div uib-attr-class="SHM_P_class" class="default-style">
Leistung: <span uib-var="SHM.P">--</span> Watt
</div>
<div uib-bind:class="SHM_P_class" class="default-style">
Leistung P: <span uib-var="SHM.P">--</span> Watt
</div>
<div :class="SHM_P_class" class="default-style">
</div>
do you have an idea?
You are over-thinking things.
The uib-var attribute and the <uib-var> component are short-cuts to updating things in the DOM. When working with web pages, remember that CSS is separate to the HTML (DOM).
So if you want to update the colour of a visible element based on data from Node-RED, you don't need to set a variable, you can update the CSS or Style directly.
Typically for something like this, you'd probably just add or remove a style from the appropriate element, something like this:
// NOTE: In your HTML, set the div to have
// an id matching the device name, e.g. <div id="SHM">
// Grab a ref to the appropriate div
const el = $(`#${dev}`)
// Set the style on the element
el.style.color = msg?.payload?.P < 0 ? 'green' : ''
Okay, I solved it with:
const myDevices = ['SHM', 'SDM630', ... , ... ];
myDevices.forEach(dev => uibuilder.set(dev, {}));
if (!msg.payload) return;
Object.keys(msg.payload).forEach(key => {
const val = msg.payload[key];
const el = document.querySelector(`[uib-var="${dev}.${key}"]`);
if (el) {
if (val !== undefined && val !== null) {
el.innerText = val;
if (dev === 'SHM' && (key === 'P' || key === 'P0')) {
el.classList.toggle('green', val < 0);
if (dev === 'SDM630' && key === 'P') {
el.classList.toggle('red', val > 0);
Advantage: 0 (number) is displayed now
