Yes, at home. The ESP connects via WiFi and the Pi via Ethernet.
Have you used the same mysql server IP in the controllers as in node-red?
Yes.
This' what I see in the console:
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.0.220:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-start to start Node-RED again
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
17 Oct 22:26:44 - [error] [mysql:mysql] Database not connected
17 Oct 22:26:46 - [error] [mysql:mysql] Database not connected
@Colin I was able to reproduce the problem with a different app from my PC. So, the issue is ISP server related.
Thanks for helping.
