I'm trying to set-up access (for my IoT students) to a remote MySQL database that has been recording readings from our weather station.
I've written the NR flow and got everything working from my home using node-red-node-mysql.
Everything works fine - database updates and I can access it fine.
Also my friend in the USA can access the database just fine as well.
The problem comes when I try to do this via the school's network.
I can ping the MySQL server from the IT Room, so this sort of indicates there is a route to the server.
I've entered the various IP addresses into the Remote MySQL settings with my ISP to grant remote access.
I'm sure this is a networking problem with the school's network, but as I'm not familar with the intricacies of corporate networking I'm at a bit of a loss as to what to try next.
The error message I get in a debug node (at school) is "Error: Pool is closed" and "Database is not connected".
Any suggestions as to what I could check or try, would be appreciated.
I try to config mysql node to connect my database which located at remote host ,but it doesn't connect. may i have your project flow ,for checking my nodes configurations ?
You have replied to a very old thread. A lot has changed since then. Please start a new thread and give us a lot more information about your problem. What versions of node red and nodejs are you using? What OS? What error are you seeing? Also, can you access the database from the machine running node red using something like the mysql command line client?
