I have 2 questions but I suspect they are related. Hopefully someone here can explain to me what is happening.
I have Node Red on my Siemens IOT2040 and I want to sent data to my website (mySQL).
I tried the mySQL node but cannot connect: "Error: getaddrinfo ENOTFOUND
In CPanel from my website I added my external IP address to the whitelist..
Next test I did was creating a php script to add the data to the database. The PHP scrip worksswhen I call it with ?parameter1=1234 it will add 1234 to the database.
BUT it only works when I do it in my browser.... I tried to do it with an HTTP REQUEST node and that gives me a timeout error
When I use the HTTP REQIEST node on a different simple html webpage on my webspace it also fails. But it works correctly for other websites...
Could it be that there are certain security settings causing this?
The test setup I used:
[{"id":"10a20985.579406","type":"inject","z":"14744de9.fab022","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":148,"y":268,"wires":[["89c02b6b.74064"]]},{"id":"89c02b6b.74064","type":"function","z":"14744de9.fab022","name":"Set msg.url to my test page","func":"var data = {};\n\ndata.url = \"https://reptile-addict.nl/test.htm\";\nreturn data;","outputs":1,"noerr":0,"x":368,"y":270,"wires":[["9bd983fa.8f96e8"]]},{"id":"9bd983fa.8f96e8","type":"http request","z":"14744de9.fab022","name":"","method":"GET","ret":"txt","url":"","tls":"","x":701.5,"y":265,"wires":[["34594387.438774"]]},{"id":"34594387.438774","type":"debug","z":"14744de9.fab022","name":"","active":true,"console":"false","complete":"true","x":884,"y":315,"wires":[]},{"id":"e38756c6.250458","type":"inject","z":"14744de9.fab022","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":141,"y":362,"wires":[["f317a320.a82d3"]]},{"id":"f317a320.a82d3","type":"function","z":"14744de9.fab022","name":"Set msg.url to https://www.w3schools.com/html/","func":"var data = {};\n\ndata.url = \"https://www.w3schools.com/html\";\nreturn data;","outputs":1,"noerr":0,"x":421,"y":364,"wires":[["7280e08c.0d0b28"]]},{"id":"7280e08c.0d0b28","type":"http request","z":"14744de9.fab022","name":"","method":"GET","ret":"txt","url":"","x":707.5,"y":364,"wires":[["34594387.438774"]]}]
The call to w3schools works but to my own site fails
