hi:) i wanna ask something. i have problem when i try to insert my value sensor or input to database mysql. some error show on this picture.
how can i fix it? can help me please?? what should i do? thank you
Hi @madihatunn
that suggests there is some configuration issue with the database node you are using.
What node module are you using for the database node?
How have you configured it?
Have you checked the mysql database you are using is running and accepting connections in general?
Is mysql running on the same machine as node-red? If so then try localhost rather than ip address.
Can you access the server from the node red machine using another sql client such as the msql command line?
Also you have not said which mysql node you are using. Possibly node-red-contrib-something.
Have you configured mysql server to allow remote connections - these days it defaults to not allowing outside connections for security.
