Unable to delete the telegram inline keyboard
hay guys im in need of your help again i made this flow for a schedule that both sends a message to telegram bot and my alexa but i made it to confusing for my zelf and am now lost
the flow works amazingly except one function node and im unable to figure it out, i hope you guys can set me on the right track or know of a way to simplefy my flow, the problem node i have is named "Check Fallback & Delete Stages" it should delete the inline keyboard but it dossent, here is my full flow
        "id": "1f443c27123414a2",
        "type": "function",
        "z": "35ec89c426fd1652",
        "g": "b3a04bf2ba8dda81",
        "name": "Send Stage2 Message",
        "func": "var awake = flow.get(\"awake\") || false;\nif (awake) return null;\n\nvar chatId = xxxxxxxxxx;\nvar now = new Date();\nvar timeString = now.toLocaleTimeString([], { hour: '2-digit', minute: '2-digit' }); // Format as HH:MM\n\nvar inlineKeyboard = {\n    inline_keyboard: [\n        [\n            { \"text\": \"I'm Up\", \"callback_data\": \"stage2_yes\" },\n            { \"text\": \"Later\", \"callback_data\": \"stage2_no\" }\n        ]\n    ]\n};\n\nmsg.payload = {\n    chatId: chatId,\n    type: \"message\"
,\n    content: `It's ${timeString}, You Need To Wake Up!`,\n    options: { reply_markup: JSON.stringify(inlineKeyboard) }\n};\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 360,
        "y": 4060,
                "6862b5047772ee42"
        "id": "6862b5047772ee42",
        "type": "telegram sender",
        "name": "Wake up",
        "bot": "",
        "haserroroutput": false,
        "outputs": 1,
        "x": 540,
        "y": 4060,
                "475bf6a4e1951f1c"
        "id": "475bf6a4e1951f1c",
        "type": "function",
        "name": "Store Stage MessageId",
        "func": "if (msg.payload && msg.payload.sentMessageId) {\n    flow.set(\"stage1MessageId\", msg.payload.sentMessageId);\n} \nelse if (!flow.get(\"stage2MessageId\")) {\n    flow.set(\"stage2MessageId\", new Date().getTime());\n}\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 730,
        "y": 4060,
                "a46ec1914e81e040"
        "id": "a46ec1914e81e040",
        "type": "delay",
        "pauseType": "delay",
        "timeout": "15",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 320,
        "y": 4120,
                "e63f054526e795c4"
        "id": "e63f054526e795c4",
        "type": "function",
        "name": "Check Fallback & Delete Stages",
        "func": "var awake = flow.get(\"awake\") || false;\n\nif (!awake) {\n    var stage1MsgId = flow.get(\"stage2MessageId\");\n\n    if (stage1MsgId) {\n        // Delete stage2 message\n        msg.payload = {\n            chatId: xxxxxxxxxx,\n            type: \"deleteMessage\",\n            content: stage1MsgId\n        };\n        return [msg, null];\n    } else {\n        msg.payload = {\n            chatId: xxxxxxxxxx,\n            type: \"deleteMessage\",\n            content: stage1MsgId\n        };\n        return [null, msg];\n    }\n}\n\n// If awake is true, return null\nreturn null;\n",
        "outputs": 2,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 530,
        "y": 4120,
                "9e4880dc45827b73"
                "0359043f261b7cec",
                "9e4880dc45827b73"
        "id": "9e4880dc45827b73",
        "name": "Send Fallback Alert / Delete",
        "bot": "",
        "outputs": 1,
        "x": 800,
        "y": 4120,
        "id": "54f8ccd4acfd74ed",
        "type": "cronplus",
        "name": "time keeper",
        "outputField": "payload",
        "timeZone": "",
        "storeName": "",
        "commandResponseMsgOutput": "output1",
        "defaultLocation": "",
        "defaultLocationType": "default",
        "outputs": 1,
        "options": [
                "name": "reset",
                "topic": "topic2",
                "payloadType": "default",
                "payload": "",
                "expressionType": "cron",
                "expression": "0 0 7 ? * MON,TUE,WED,THU,FRI,SAT,SUN *",
                "location": "",
                "offset": "0",
                "solarType": "all",
                "solarEvents": "sunrise,sunset"
        "x": 210,
        "y": 3940,
                "1f443c27123414a2",
                "fdb4e06535e3bd88"
        "id": "fdb4e06535e3bd88",
        "type": "function",
        "name": "Retrieve States",
        "func": "// Get the current time\nvar now = new Date();\nvar timeString = now.toLocaleTimeString([], { hour: '2-digit', minute: '2-digit' }); // Format HH:MM\n\n// Construct the wake-up message\nvar message = `You need to get up! It's ${timeString}.`;\n\n// Pass the message to the next node\nmsg.payload = message;\nreturn msg;\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 340,
        "y": 4000,
                "7be45b81ea36811d"
        "id": "a802a78fd3eb825c",
        "type": "telegram event",
        "name": "Callback Query Event",
        "bot": "",
        "event": "callback_query",
        "autoanswer": true,
        "x": 220,
        "y": 4200,
                "53b93cdb2ccd9886"
        "id": "6da30a83cfeea442",
        "name": "Send Confirmation",
        "bot": "",
        "outputs": 1,
        "x": 830,
        "y": 4200,
                "691ad392789c6c24"
        "id": "f4d791086afc5de1",
        "type": "function",
        "name": "done clicked",
        "func": "var awake = flow.get(\"awake\") || false;\nif (awake) return null;\n\nmsg.payload = {\n    chatId: xxxxxxxxxx,\n    type: \"message\",\n    content: \"Good Morning \",\n};\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 650,
        "y": 4200,
                "6da30a83cfeea442",
                "152c67cb8eba06b9"
        "id": "91623ac492d60da4",
        "type": "function",
        "name": "later clicked",
        "func": "var awake = flow.get(\"awake\") || false;\nif (awake) return null;\nmsg.payload = {\n    chatId: xxxxxxxxxx,\n    type: \"message\",\n    content: \"ill remind you again in 5 minutes\",\n};\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 650,
        "y": 4260,
                "6da30a83cfeea442",
                "4f8119002d6205cc",
                "e82141bd60368ec9"
        "id": "691ad392789c6c24",
        "type": "function",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 890,
        "y": 4260,
                "e3283cc9eef514da"
        "id": "e3283cc9eef514da",
        "type": "delay",
        "timeout": "10",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 1080,
        "y": 4260,
                "55563e0d4068caab"
        "id": "55563e0d4068caab",
        "type": "function",
        "name": "Check Fallback & Delete Trash",
        "func": "var awake = flow.get(\"awake\") || false;\nif (!awake) {\n    // Retrieve message id variables\n    var stage1MsgId = flow.get(\"stage1MessageId\");\n    if (stage1MsgId) {\n        // Delete stage1 message\n        msg.payload = {\n            chatId: xxxxxxxxxx,\n            type: \"deleteMessage\",\n            content: stage1MsgId\n        };\n        return [msg, null]; // Send to output 1\n    }\n}\nreturn null;\n",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 690,
        "y": 4320,
                "ab91bc36be1e7551"
        "id": "ab91bc36be1e7551",
        "bot": "",
        "outputs": 1,
        "x": 930,
        "y": 4320,
        "id": "4f8119002d6205cc",
        "type": "delay",
        "timeout": "5",
        "timeoutUnits": "minutes",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 180,
        "y": 4120,
                "1f443c27123414a2",
                "fdb4e06535e3bd88"
        "id": "7be45b81ea36811d",
        "type": "link out",
        "name": "Passthrough to office",
        "mode": "link",
        "links": [
            "29ad8057789a6185"
        "x": 540,
        "y": 4000,
        "wires": [],
        "l": true
        "id": "53b93cdb2ccd9886",
        "type": "function",
        "name": "Process Callback Query ",
        "func": "var data = msg.payload.content;\nvar stage1MsgId = flow.get(\"stage1MessageId\"); // Ensure this variable is set in your flow\n\nif (data.indexOf(\"stage2_yes\") > -1) { \n    // Stage 2 button \"Yes\"\n    flow.set(\"awake\", false);\n    node.status({ fill: \"green\", shape: \"dot\", text: \"User is awake2\" });\n    msg.payload = {\n        chatId: xxxxxxxxxx,\n        type: \"deleteMessage\",\n        content: stage1MsgId\n    };\n    return [msg, null];\n\n} else if (data.indexOf(\"stage2_no\") > -1) { \n    // Stage 2 button \"No\"\n    flow.set(\"awake\", false);\n    node.status({ fill: \"yellow\", shape: \"dot\", text: \"User snoozed2\" });\n    msg.payload = {\n        chatId: xxxxxxxxxx,\n        type: \"deleteMessage\",\n        content: stage1MsgId\n    };\n    return [null, msg];\n}\n\n// If no condition is met, do nothing\nreturn null;\n",
        "outputs": 2,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 450,
        "y": 4200,
                "f4d791086afc5de1"
                "91623ac492d60da4"
        "id": "152c67cb8eba06b9",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "Good Morning",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 200,
        "y": 4260,
                "7be45b81ea36811d"
        "id": "e82141bd60368ec9",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "ill remind you again in 5 minutes",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 200,
        "y": 4320,
                "7be45b81ea36811d"
        "id": "0359043f261b7cec",
        "type": "delay",
        "timeout": "15",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": false,
        "allowrate": false,
        "outputs": 1,
        "x": 720,
        "y": 4000,
                "fdb4e06535e3bd88",
                "1f443c27123414a2"
Add debug after callback node, see what values are there I believe there is a message id of some sort, if memory serves me correctly.
P.s you have posted chatid's directly in this flow example I would suggest you delete them for security.
thank you i forgot debug nodes where a thing and yes adding the debug showed me the problem and its not fixed i forgot to add the var msg1id, and also i dident thing you could do much with just the chat id but just incase i removed it from the code
I always wanted to ask this, once you post something in the forum, and delete/ edit a part of the post later, it is still possible to view the old post by clicking the pencil button, is there a way to permanently delete the post / part of the post ?
If you edit then it is possible to still see the data using the pencil icon. It would be best to delete the post if the data is of vital security. It is best to save data like keys and chatid's in a credential environmental var, this way when you add the env var to the flow the secret is not exported with the flow.
[edit] If you edit the post to hide the security keys you can ask a moderator to hide the previous edits.
good idea never thought of that im still quite new so thanks
i dont see a way of deleting this topic? how would i do that
