Unable to deploy changes on node red
Hello Team!
I am facing difficulties deploying changes made to my project on node-red.
Anytime I try to deploy the changes made, the following error message appears in the cmd prompt and blocks the deploy from occurring.
PayloadTooLargeError: request entity too large at readStream (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\raw-body\index.js:163:17) at getRawBody (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\raw-body\index.js:116:12) at read (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\body-parser\lib\read.js:79:3) at jsonParser (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\body-parser\lib\types\json.js:138:5) at Layer.handle [as handle_request] (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\layer.js:95:5) at trim_prefix (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\index.js:328:13) at C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\index.js:286:9 at Function.process_params (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\index.js:346:12) at next (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\index.js:280:10) at cors (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\cors\lib\index.js:188:7) at C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\cors\lib\index.js:224:17 at originCallback (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\cors\lib\index.js:214:15) at C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\cors\lib\index.js:219:13 at optionsCallback (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\cors\lib\index.js:199:9) at corsMiddleware (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\cors\lib\index.js:204:7) at Layer.handle [as handle_request] (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\layer.js:95:5) at trim_prefix (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\index.js:328:13) at C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\index.js:286:9 at Function.process_params (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\index.js:346:12) at next (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\index.js:280:10) at expressInit (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\middleware\init.js:40:5) at Layer.handle [as handle_request] (C:\Users\desmond\AppData\Roaming\npm\node_modules\node-red\node_modules\express\lib\router\layer.js:95:5)
I don't know if it has to do with the size of my project which is about 6mb.
Any help on this will be highly appreciated.
Your flows are too large. You should probably start considering to scale out with additional node-red instances. However, if you must, you can bypass the limit.
Thank you Steve!
I’m good to go
