Unable to install all Nodes
Google translation
Bonjour Hello
Je suis débutant sur Node-Red I'm a beginner on Node-Red
Je voudrais faire fonctionner ce programme I would like to run this program
https://github.com/diverjoe/FishNet/wiki
Impossible d’installer tous les Node Unable to install all Nodes
Quelqu’un peut-il m’aider Can anyone help me
Je vous remercie par avance I thank you in advance
Configuration
Raspberry PI4 RAM 8GO
Système exploitation
Raspberry Pi OS (32 bits) avec bureau
Image avec bureau basée sur Debian Buster
Version:Mai 2020
Date de sortie:2020-05-27
Version du noyau:4.19
Taille:1128 Mo
Install node red :
1 - sudo apt install build-essential git
2 - bash <(curl -sL https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update- nodejs-and-nodered)
Would you like to install the Pi-specific nodes ? YES
Stop Node-RED :heavy_check_mark:
Remove old version of Node-RED :heavy_check_mark:
Remove old version of Node.js :heavy_check_mark:
Install Node.js LTS :heavy_check_mark: Node v12.18.2 Npm 6.14.6
Clean npm cache :heavy_check_mark:
Install Node-RED core :heavy_check_mark: 1.1.2
Move global nodes to local -
Install extra Pi nodes -
Npm rebuild existing nodes -
Add shortcut commands :heavy_check_mark:
Update systemd script :heavy_check_mark:
Any errors will be logged to /var/log/nodered-install.log All done.
3- node-red-pi --max-old-space-size=256
Node -v = 12.18.2 npm -v = 6.14.6
-Manage palette install:
node-red-dashboard
A set of dashboard nodes for Node-RED
2.23.0 6 days ago INSTALL OK
node-red-contrib-influxdb
Node-RED nodes to save and query data from an influxdb 1.x time series database
0.4.1 3 weeks ago INSTALL OK
node-red-contrib-os
Node-Red nodes for obtaining cpu system information.
0.1.7 3 years, 10 months ago INSTALL OK
node-red-node-smooth
A Node-RED node that provides several simple smoothing algorithms for incoming data values.
0.1.2 10 months ago
INSTALL OK
node-red-contrib-ds18b20-sensor
Node-red node to connect DS18B20 sensors
1.3.6 1 year, 6 months ago INSTALL OK
A Node-RED node to read a temperature from a DS18B20 sensor
0.0.3 6 years ago INSTALL OK
node-red-contrib-fsm
FSM - A Finite Statemachine Node
0.0.6 3 years, 5 months ago INSTALL OK
node-red-contrib-timerswitch
An easy, intuitive and precise node-red timer that allows you to turn something on/off multiple times a day and supports schedules as low as 1 second.
1.3.0 6 days ago INSTALL OK
node-red-contrib-curve
Node to calculate output by a given mathematical function expression
1.0.1 3 years, 5 months ago INSTALL OK
DEPLOY :
The workspace contains some unknown node types:
PCA9685 out
i2c in
i2c out
kalman-filter
twitter out
  • 2 more
Are you sure you want to deploy? NO
node-red-contrib-pca9685
Control a PCA9685 board with Node-RED
0.1.3 3 years, 9 months ago INSTALL FAIL
DEPLOY :
PCA9685 out
i2c in
i2c out
kalman-filter
twitter out
  • 2 more
node-red-contrib-i2c
A Node-RED node to talk to the Raspiberry PI's I2C port
0.7.2 2 weeks ago INSTALL FAIL
DEPLOY :
PCA9685 out
i2c in
i2c out
kalman-filter
twitter out
  • 2 more
node-red-contrib-kalman
node-red-contrib-kalman ========================
0.0.3 3 years, 10 months ago INSTALL FAIL
DEPLOY :
PCA9685 out
i2c in
i2c out
kalman-filter
twitter out
  • 2 more
node-red-node-twitter
A Node-RED node to talk to Twitter
1.1.6 7 months ago INSTALL FAIL
2020-07-16T19:37:26.526Z Install : node-red-dashboard 2.23.0
2020-07-16T19:37:24.011Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-dashboard@2.23.0
2020-07-16T19:37:34.031Z [err] npm
2020-07-16T19:37:34.032Z [err] notice created a lockfile as package-lock.json. You should commit this file.
2020-07-16T19:37:34.040Z [err] npm
2020-07-16T19:37:34.040Z [err] WARN node-red-project@0.0.1 No repository field.
2020-07-16T19:37:34.047Z [err] npm
2020-07-16T19:37:34.047Z [err] WARN node-red-project@0.0.1 No license field.
2020-07-16T19:37:34.048Z [err]
2020-07-16T19:37:34.051Z [out] + node-red-dashboard@2.23.0
2020-07-16T19:37:34.051Z [out] added 80 packages from 60 contributors in 8.319s
2020-07-16T19:37:34.119Z rc=0
2020-07-16T19:40:30.455Z Install : node-red-contrib-influxdb 0.4.1
2020-07-16T19:40:27.937Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-influxdb@0.4.1
2020-07-16T19:40:33.432Z [err] npm
2020-07-16T19:40:33.432Z [err] WARN node-red-project@0.0.1 No repository field.
2020-07-16T19:40:33.438Z [err] npm
2020-07-16T19:40:33.439Z [err] WARN node-red-project@0.0.1 No license field.
2020-07-16T19:40:33.441Z [out] + node-red-contrib-influxdb@0.4.1
2020-07-16T19:40:33.441Z [out] added 3 packages from 6 contributors in 4.178s
2020-07-16T19:40:33.465Z rc=0
2020-07-16T19:42:43.300Z Install : node-red-contrib-os 0.1.7
2020-07-16T19:42:40.789Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-os@0.1.7
2020-07-16T19:42:46.780Z [err] npm
2020-07-16T19:42:46.781Z [err] WARN node-red-project@0.0.1 No repository field.
2020-07-16T19:42:46.787Z [err] npm
2020-07-16T19:42:46.787Z [err] WARN node-red-project@0.0.1 No license field.
2020-07-16T19:42:46.788Z [err]
2020-07-16T19:42:46.790Z [out] + node-red-contrib-os@0.1.7
2020-07-16T19:42:46.790Z [out] added 3 packages from 3 contributors in 4.677s
2020-07-16T19:42:46.812Z rc=0
2020-07-16T19:51:03.520Z Install : node-red-node-smooth 0.1.2
2020-07-16T19:51:01.021Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-node-smooth@0.1.2
2020-07-16T19:51:05.013Z [err] npm
2020-07-16T19:51:05.014Z [err] WARN node-red-project@0.0.1 No repository field.
2020-07-16T19:51:05.021Z [err] npm
2020-07-16T19:51:05.021Z [err] WARN node-red-project@0.0.1 No license field.
2020-07-16T19:51:05.024Z [out] + node-red-node-smooth@0.1.2
2020-07-16T19:51:05.024Z [out] added 1 package from 2 contributors in 2.692s
2020-07-16T19:51:05.045Z rc=0
2020-07-16T19:53:22.706Z Install : node-red-contrib-ds18b20-sensor 1.3.6
2020-07-16T19:53:20.209Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-ds18b20-sensor@1.3.6
2020-07-16T19:53:24.142Z [err] npm
2020-07-16T19:53:24.143Z [err] WARN node-red-project@0.0.1 No repository field.
2020-07-16T19:53:24.149Z [err] npm
2020-07-16T19:53:24.149Z [err] WARN node-red-project@0.0.1 No license field.
2020-07-16T19:53:24.150Z [err]
2020-07-16T19:53:24.153Z [out] + node-red-contrib-ds18b20-sensor@1.3.6
2020-07-16T19:53:24.153Z [out] added 1 package from 1 contributor in 2.636s
2020-07-16T19:53:24.176Z rc=0
2020-07-16T19:55:20.639Z Install : node-red-contrib-ds18b20 0.0.3
2020-07-16T19:55:18.141Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-ds18b20@0.0.3
2020-07-16T19:55:23.036Z [err] npm
2020-07-16T19:55:23.036Z [err] WARN node-red-project@0.0.1 No repository field.
2020-07-16T19:55:23.043Z [err] npm
2020-07-16T19:55:23.043Z [err] WARN node-red-project@0.0.1 No license field.
2020-07-16T19:55:23.044Z [err]
2020-07-16T19:55:23.046Z [out] + node-red-contrib-ds18b20@0.0.3
2020-07-16T19:55:23.046Z [out] added 2 packages from 2 contributors in 3.579s
2020-07-16T19:55:23.072Z rc=0
2020-07-16T19:58:06.783Z Install : node-red-contrib-fsm 0.0.6
2020-07-16T19:58:04.289Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-fsm@0.0.6
2020-07-16T19:58:08.418Z [err] npm
2020-07-16T19:58:08.418Z [err] WARN node-red-project@0.0.1 No repository field.
2020-07-16T19:58:08.424Z [err] npm
2020-07-16T19:58:08.425Z [err] WARN node-red-project@0.0.1 No license field.
2020-07-16T19:58:08.427Z [out] + node-red-contrib-fsm@0.0.6
2020-07-16T19:58:08.427Z [out] added 1 package in 2.808s
2020-07-16T19:58:08.449Z rc=0
2020-07-16T20:00:04.047Z Install : node-red-contrib-timerswitch 1.3.0
2020-07-16T20:00:01.556Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-timerswitch@1.3.0
2020-07-16T20:00:05.565Z [err] npm
2020-07-16T20:00:05.565Z [err] WARN node-red-project@0.0.1 No repository field.
2020-07-16T20:00:05.571Z [err] npm
2020-07-16T20:00:05.571Z [err] WARN node-red-project@0.0.1 No license field.
2020-07-16T20:00:05.572Z [err]
2020-07-16T20:00:05.574Z [out] + node-red-contrib-timerswitch@1.3.0
2020-07-16T20:00:05.574Z [out] added 1 package from 1 contributor in 2.685s
2020-07-16T20:00:05.596Z rc=0
2020-07-16T20:01:45.922Z Install : node-red-contrib-curve 1.0.1
2020-07-16T20:01:43.433Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-curve@1.0.1
2020-07-16T20:01:51.047Z [err] npm
2020-07-16T20:01:51.048Z [err] WARN deprecated logspace@1.0.1: I wrote this module a very long time ago; you should use something else.
2020-07-16T20:01:51.050Z [err] npm
2020-07-16T20:01:51.051Z [err] WARN deprecated linspace@1.0.0: I wrote this module a very long time ago; you should use something else.
2020-07-16T20:01:57.039Z [err] npm
2020-07-16T20:01:57.039Z [err] WARN node-red-project@0.0.1 No repository field.
2020-07-16T20:01:57.045Z [err] npm
2020-07-16T20:01:57.046Z [err] WARN node-red-project@0.0.1 No license field.
2020-07-16T20:01:57.049Z [out] + node-red-contrib-curve@1.0.1
2020-07-16T20:01:57.049Z [out] added 26 packages from 20 contributors in 12.293s
2020-07-16T20:01:57.073Z rc=0
2020-07-16T20:04:25.765Z Install : node-red-contrib-pca9685 0.1.3
2020-07-16T20:04:23.280Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-pca9685@0.1.3
2020-07-16T20:04:33.645Z [err] npm
2020-07-16T20:04:33.646Z [err] ERR! code EISGIT
2020-07-16T20:04:33.646Z [err] npm ERR! path
2020-07-16T20:04:33.646Z [err] /home/pi/.node-red/node_modules/function-plot
2020-07-16T20:04:33.650Z [err] npm
2020-07-16T20:04:33.650Z [err] ERR! git /home/pi/.node-red/node_modules/function-plot: Appears to be a git repo or submodule.
2020-07-16T20:04:33.650Z [err] npm ERR!
2020-07-16T20:04:33.651Z [err] git /home/pi/.node-red/node_modules/function-plot
2020-07-16T20:04:33.651Z [err] npm
2020-07-16T20:04:33.651Z [err] ERR! git Refusing to remove it. Update manually,
2020-07-16T20:04:33.651Z [err] ERR! git or move it out of the way first.
2020-07-16T20:04:33.663Z [err]
2020-07-16T20:04:33.663Z [err] npm ERR! A complete log of this run can be found in:
2020-07-16T20:04:33.663Z [err] /home/pi/.npm/_logs/2020-07-16T20_04_33_653Z-debug.log
2020-07-16T20:04:33.673Z rc=1
2020-07-16T20:09:13.017Z Install : node-red-contrib-i2c 0.7.2
2020-07-16T20:09:10.539Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-i2c@0.7.2
2020-07-16T20:09:15.444Z [err] npm
2020-07-16T20:09:15.444Z [err] ERR! code EISGIT
2020-07-16T20:09:15.444Z [err] npm ERR! path
2020-07-16T20:09:15.444Z [err] /home/pi/.node-red/node_modules/function-plot
2020-07-16T20:09:15.448Z [err] npm
2020-07-16T20:09:15.448Z [err] ERR! git /home/pi/.node-red/node_modules/function-plot: Appears to be a git repo or submodule.
2020-07-16T20:09:15.450Z [err] ERR! git /home/pi/.node-red/node_modules/function-plot
2020-07-16T20:09:15.450Z [err] npm ERR! git Refusing to remove it. Update manually,
2020-07-16T20:09:15.450Z [err] npm ERR! git or move it out of the way first.
2020-07-16T20:09:15.463Z [err]
2020-07-16T20:09:15.463Z [err] npm ERR! A complete log of this run can be found in:
2020-07-16T20:09:15.463Z [err] npm ERR! /home/pi/.npm/_logs/2020-07-16T20_09_15_451Z-debug.log
2020-07-16T20:09:15.473Z rc=1
2020-07-16T20:12:36.624Z Install : node-red-contrib-kalman 0.0.3
2020-07-16T20:12:34.152Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-kalman@0.0.3
2020-07-16T20:12:39.306Z [err] npm
2020-07-16T20:12:39.306Z [err] WARN notsup Unsupported engine for node-red-contrib-kalman@0.0.3: wanted: {"node":"4.2.x"} (current: {"node":"12.18.2","npm":"6.14.6"})
2020-07-16T20:12:39.306Z [err] npm WARN
2020-07-16T20:12:39.306Z [err] notsup Not compatible with your version of node/npm: node-red-contrib-kalman@0.0.3
2020-07-16T20:12:39.307Z [err]
2020-07-16T20:12:39.330Z [err] npm
2020-07-16T20:12:39.330Z [err] ERR! code EISGIT
2020-07-16T20:12:39.331Z [err] npm ERR!
2020-07-16T20:12:39.331Z [err] path /home/pi/.node-red/node_modules/function-plot
2020-07-16T20:12:39.333Z [err] npm
2020-07-16T20:12:39.333Z [err] ERR! git /home/pi/.node-red/node_modules/function-plot: Appears to be a git repo or submodule.
2020-07-16T20:12:39.334Z [err] ERR! git /home/pi/.node-red/node_modules/function-plot
2020-07-16T20:12:39.334Z [err] npm ERR! git Refusing to remove it. Update manually,
2020-07-16T20:12:39.334Z [err] git or move it out of the way first.
2020-07-16T20:12:39.346Z [err]
2020-07-16T20:12:39.346Z [err] npm ERR! A complete log of this run can be found in:
2020-07-16T20:12:39.346Z [err] ERR! /home/pi/.npm/_logs/2020-07-16T20_12_39_336Z-debug.log
2020-07-16T20:12:39.356Z rc=1
2020-07-16T20:15:28.359Z Install : node-red-contrib-kalman 0.0.3
2020-07-16T20:15:25.889Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-kalman@0.0.3
2020-07-16T20:15:29.039Z [err] npm
2020-07-16T20:15:29.040Z [err]
2020-07-16T20:15:29.040Z [err] WARN notsup Unsupported engine for node-red-contrib-kalman@0.0.3: wanted: {"node":"4.2.x"} (current: {"node":"12.18.2","npm":"6.14.6"})
2020-07-16T20:15:29.040Z [err] npm
2020-07-16T20:15:29.040Z [err] notsup
2020-07-16T20:15:29.040Z [err] Not compatible with your version of node/npm: node-red-contrib-kalman@0.0.3
2020-07-16T20:15:29.041Z [err]
2020-07-16T20:15:29.060Z [err] npm
2020-07-16T20:15:29.060Z [err] ERR! code
2020-07-16T20:15:29.060Z [err] EISGIT
2020-07-16T20:15:29.060Z [err] ERR! path
2020-07-16T20:15:29.060Z [err] /home/pi/.node-red/node_modules/function-plot
2020-07-16T20:15:29.063Z [err] npm
2020-07-16T20:15:29.069Z [err] ERR! git /home/pi/.node-red/node_modules/function-plot: Appears to be a git repo or submodule.
2020-07-16T20:15:29.069Z [err] npm ERR! git /home/pi/.node-red/node_modules/function-plot
2020-07-16T20:15:29.069Z [err] npm ERR! git Refusing to remove it. Update manually,
2020-07-16T20:15:29.069Z [err] npm ERR! git or move it out of the way first.
2020-07-16T20:15:29.077Z [err]
2020-07-16T20:15:29.077Z [err] npm ERR! A complete log of this run can be found in:
2020-07-16T20:15:29.078Z [err] /home/pi/.npm/_logs/2020-07-16T20_15_29_066Z-debug.log
2020-07-16T20:15:29.087Z rc=1
2020-07-16T20:17:35.227Z Install : node-red-node-twitter 1.1.6
2020-07-16T20:17:32.760Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-node-twitter@1.1.6
2020-07-16T20:17:36.204Z [err] npm
2020-07-16T20:17:36.204Z [err] WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
2020-07-16T20:17:40.138Z [err] npm
2020-07-16T20:17:40.138Z [err] ERR! code EISGIT
2020-07-16T20:17:40.138Z [err] npm ERR! path /home/pi/.node-red/node_modules/function-plot
2020-07-16T20:17:40.142Z [err] npm
2020-07-16T20:17:40.143Z [err] ERR! git /home/pi/.node-red/node_modules/function-plot: Appears to be a git repo or submodule.
2020-07-16T20:17:40.143Z [err] npm
2020-07-16T20:17:40.143Z [err] npm ERR!
2020-07-16T20:17:40.143Z [err] git Refusing to remove it. Update manually,
2020-07-16T20:17:40.143Z [err] ERR! git or move it out of the way first.
2020-07-16T20:17:40.164Z [err]
2020-07-16T20:17:40.164Z [err] npm ERR! A complete log of this run can be found in:
2020-07-16T20:17:40.164Z [err] npm ERR! /home/pi/.npm/_logs/2020-07-16T20_17_40_146Z-debug.log
2020-07-16T20:17:40.175Z rc=1
Installation impossible des Node suivant Unable to install the following nodes
PCA9685 out
i2c in
i2c out
kalman-filter
twitter out
  • 2 more
Node listing :
pi@raspberrypi:~ $ apt-mark showmanual
adduser
alacarte
alsa-utils
apt
apt-listchanges
apt-utils
arandr
avahi-daemon
base-files
base-passwd
bash
bash-completion
bsdmainutils
bsdutils
build-essential
ca-certificates
chromium-browser
cifs-utils
console-setup
coreutils
cpio
crda
cron
curl
dash
debconf
debconf-i18n
debconf-utils
debian-reference-en
debianutils
desktop-base
dhcpcd5
diffutils
dillo
dirmngr
dmidecode
dmsetup
dosfstools
dphys-swapfile
dpkg
e2fsprogs
ed
ethtool
fake-hwclock
fbset
fdisk
ffmpeg
findutils
firmware-atheros
firmware-brcm80211
firmware-libertas
firmware-misc-nonfree
firmware-realtek
fonts-droid-fallback
fonts-liberation2
gcc-4.9-base
gcc-5-base
gcc-6-base
gcc-7-base
gcc-8-base
gdb
gdbm-l10n
geany
git
gldriver-test
gnome-icon-theme
gnupg
gnupg-l10n
gnupg-utils
gpg
gpg-agent
gpg-wks-client
gpg-wks-server
gpgconf
gpgsm
gpgv
grep
groff-base
gstreamer1.0-alsa
gstreamer1.0-libav
gstreamer1.0-omx
gstreamer1.0-plugins-bad
gstreamer1.0-plugins-base
gstreamer1.0-plugins-good
gstreamer1.0-x
gtk2-engines
gvfs
gvfs-backends
gvfs-fuse
gzip
hardlink
hostname
htop
hunspell-en-gb
hyphen-en-gb
ifupdown
info
init
init-system-helpers
install-info
iproute2
iptables
iputils-ping
isc-dhcp-client
isc-dhcp-common
keyboard-configuration
kmod
less
libacl1
libapparmor1
libapt-inst2.0
libapt-pkg5.0
libargon2-1
libassuan0
libatomic1
libattr1
libaudit-common
libaudit1
libblkid1
libboost-iostreams1.58.0
libbsd0
libbz2-1.0
libc-bin
libc6
libcap-ng0
libcap2
libcap2-bin
libcom-err2
libcryptsetup12
libdb5.3
libdebconfclient0
libdevmapper1.02.1
libdns-export1104
libelf1
libestr0
libext2fs2
libfastjson4
libfdisk1
libffi6
libfreetype6-dev
libgcc1
libgcrypt20
libgdbm6
libgl1-mesa-dri
libgles1
libgles2-mesa
libgmp10
libgnutls30
libgpg-error0
libhogweed4
libident
libidn11
libidn2-0
libip4tc0
libip6tc0
libiptc0
libisc-export1100
libjson-c3
libkmod2
libksba8
libldap-2.4-2
libldap-common
liblocale-gettext-perl
liblognorm5
liblz4-1
liblzma5
libmnl-dev
libmnl0
libmount1
libmtp-runtime
libncurses6
libncursesw6
libnetfilter-conntrack3
libnettle6
libnfnetlink0
libnftnl11
libnpth0
libp11-kit0
libpam-chksshpwd
libpam-modules
libpam-modules-bin
libpam-runtime
libpam0g
libpcre3
libpipeline1
libpopt0
libprocps7
libraspberrypi-bin
libraspberrypi-dev
libraspberrypi-doc
libraspberrypi0
libreadline6
libreadline7
libsasl2-2
libsasl2-modules-db
libseccomp2
libselinux1
libsemanage-common
libsemanage1
libsepol1
libsigc++-1.2-5c2
libsmartcols1
libsqlite3-0
libss2
libssl1.1
libstdc++6
libsystemd0
libtasn1-6
libtext-charwidth-perl
libtext-iconv-perl
libtext-wrapi18n-perl
libtinfo5
libtinfo6
libuchardet0
libudev0
libudev1
libunistring2
libuuid1
libxtables12
libzstd1
lightdm
locales
login
logrotate
lsb-base
lua5.1
luajit
lxde
lxtask
man-db
manpages-dev
mawk
menu-xdg
mount
mousepad
multiarch-support
nano
ncdu
ncurses-base
ncurses-bin
net-tools
netbase
netcat-openbsd
netcat-traditional
nfs-common
nodejs
ntfs-3g
obconf
omxplayer
parted
passwd
paxctld
pciutils
perl-base
pi-bluetooth
pi-package
piclone
pigpio
pinentry-curses
piwiz
pkg-config
policykit-1
pprompt
procps
psmisc
pypy
python
python-automationhat
python-blinkt
python-buttonshim
python-cap1xxx
python-drumhat
python-envirophat
python-explorerhat
python-flask
python-fourletterphat
python-gpiozero
python-microdotphat
python-mote
python-motephat
python-pantilthat
python-phatbeat
python-pianohat
python-picamera
python-piglow
python-pigpio
python-pip
python-pygame
python-rainbowhat
python-rpi.gpio
python-scrollphat
python-scrollphathd
python-serial
python-skywriter
python-smbus
python-sn3218
python-spidev
python-tk
python-touchphat
python-twython
python-unicornhathd
python3
python3-automationhat
python3-blinkt
python3-buttonshim
python3-cap1xxx
python3-drumhat
python3-envirophat
python3-explorerhat
python3-flask
python3-fourletterphat
python3-gpiozero
python3-microdotphat
python3-mote
python3-motephat
python3-numpy
python3-pantilthat
python3-pgzero
python3-phatbeat
python3-pianohat
python3-picamera
python3-piglow
python3-pigpio
python3-pip
python3-pygame
python3-rainbowhat
python3-rpi.gpio
python3-scrollphat
python3-scrollphathd
python3-serial
python3-skywriter
python3-smbus
python3-sn3218
python3-spidev
python3-tk
python3-touchphat
python3-twython
python3-unicornhathd
qpdfview
raspberrypi-artwork
raspberrypi-bootloader
raspberrypi-kernel
raspberrypi-net-mods
raspberrypi-sys-mods
raspberrypi-ui-mods
raspbian-archive-keyring
raspi-config
raspi-copies-and-fills
raspi-gpio
rc-gui
readline-common
realvnc-vnc-server
rfkill
rng-tools
rp-prefapps
rpi-chromium-mods
rpi-eeprom
rpi-update
rsync
rsyslog
sed
sense-hat
sensible-utils
ssh
ssh-import-id
strace
sudo
systemd
systemd-sysv
sysvinit-utils
tar
tasksel
tasksel-data
thonny
traceroute
tree
tzdata
udev
unzip
usb-modeswitch
usbutils
util-linux
v4l-utils
vim-common
vim-tiny
vl805fw
vlc
wamerican
wbritish
wfrench
wireless-tools
wiringpi
wpasupplicant
xcompmgr
xdg-utils
xinit
xserver-xorg
xserver-xorg-video-fbdev
xserver-xorg-video-fbturbo
xxd
zenity
zlib1g
pi@raspberrypi:~ $
Merci pour votre aide Thanks for your help
Sebastien
Hi Sebastien.
Please understand I too am a learning person, so am not expert.
Yes, it is good you posted all the results of things you did/tried.
But one thing sticks out for me:
Where is this file's contents?
I am only guessing, but something you may need to check:
the raspi-config settings. (sudo raspi-config)
Option 5 - interface
Do you have the SPI, I2C (and others) enabled?
If not, that could be causing problems for you.
That is the cause of at least some of the problems (there wasn't any need to show us all the successful installs). The folder includes a folder called .git
It isn't clear where that came from, I can't see it as being installed in the output you posted. I suggest removing that folder (/home/pi/.node-red/node_modules/function-plot) and trying to install the missing nodes again. If you get failures just concentrate on one of them and post the output from installing that node here.
Bonjour Hello
Colin and Trying_to learn
J’ai à chaque installation de Node supprimer le dossier /home/pi/.node-red/node_modules/function-plot.
I have each time I install Node delete the folder /home/pi/.node-red/node_modules/function-plot.
J’ai réussi à installer presque tous les Nodes sauf un Node-red-contrib-pca9685.
I managed to install almost all of the Nodes except one Node-red-contrib-pca9685.
Configuration du Raspberry PI :
SSH Active Enabled
VNC Active Enabled
SPI Active Enabled
I2C Active Enabled
Serial Port Active Enabled
Serial Console Active Enabled
1-Wire Active Enabled
Remote GPIO Active Enabled
Result install Node-red-contrib-pca9685 :
Install Manage Palette
2020-07-17T20:40:08.741Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.741Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.741Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.741Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.741Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.741Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.741Z [err] In file included from ../src/i2c.cc:99:
2020-07-17T20:40:08.741Z [err] ../src/./readi2cblock.cc:70:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.741Z [err] __u8 cmd = info[1]->Int32Value();
2020-07-17T20:40:08.741Z [err] ../src/./readi2cblock.cc:71:39: error: no matching function for call to ‘v8::Value::Uint32Value()’
2020-07-17T20:40:08.741Z [err] __u32 length = info[2]->Uint32Value();
2020-07-17T20:40:08.742Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.742Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.742Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.742Z [err] V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(
2020-07-17T20:40:08.742Z [err] ^~~~~~~~~~~
2020-07-17T20:40:08.742Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.743Z [err] In file included from ../src/i2c.cc:99:
2020-07-17T20:40:08.743Z [err] ../src/./readi2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReadI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.743Z [err] ../src/./readi2cblock.cc:109:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.743Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.743Z [err] ^
2020-07-17T20:40:08.744Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.744Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.744Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.744Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.744Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.744Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.744Z [err] In file included from ../src/i2c.cc:99:
2020-07-17T20:40:08.744Z [err] ../src/./readi2cblock.cc:110:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.744Z [err] __u8 cmd = info[1]->Int32Value();
2020-07-17T20:40:08.744Z [err] ../src/./readi2cblock.cc:111:39: error: no matching function for call to ‘v8::Value::Uint32Value()’
2020-07-17T20:40:08.744Z [err] __u32 length = info[2]->Uint32Value();
2020-07-17T20:40:08.744Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.744Z [err] V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(
2020-07-17T20:40:08.744Z [err] ^~~~~~~~~~~
2020-07-17T20:40:08.744Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.748Z [err] In file included from ../src/i2c.cc:100:
2020-07-17T20:40:08.748Z [err] ../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.748Z [err] ../src/./receivebyte.cc:48:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.748Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.748Z [err] ^
2020-07-17T20:40:08.750Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.750Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.750Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.750Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.750Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.750Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.751Z [err] In file included from ../src/i2c.cc:100:
2020-07-17T20:40:08.751Z [err] ../src/./receivebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE ReceiveByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.751Z [err] ../src/./receivebyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.751Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.751Z [err] ^
2020-07-17T20:40:08.751Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.751Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.751Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.751Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.751Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.751Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.754Z [err] In file included from ../src/i2c.cc:101:
2020-07-17T20:40:08.754Z [err] ../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.754Z [err] ../src/./sendbyte.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.754Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.754Z [err] ^
2020-07-17T20:40:08.755Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.755Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.755Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.755Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.755Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.755Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.755Z [err] In file included from ../src/i2c.cc:101:
2020-07-17T20:40:08.755Z [err] ../src/./sendbyte.cc:48:35: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.755Z [err] __u8 byte = info[1]->Int32Value();
2020-07-17T20:40:08.756Z [err] In file included from ../src/i2c.cc:101:
2020-07-17T20:40:08.756Z [err] ../src/./sendbyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SendByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.756Z [err] ../src/./sendbyte.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.756Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.756Z [err] ^
2020-07-17T20:40:08.756Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.756Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.756Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.756Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.756Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.756Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.756Z [err] ../src/./sendbyte.cc:61:35: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.756Z [err] __u8 byte = info[1]->Int32Value();
2020-07-17T20:40:08.759Z [err] In file included from ../src/i2c.cc:102:
2020-07-17T20:40:08.759Z [err] ../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrAsync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.759Z [err] ../src/./setaddr.cc:46:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.759Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.759Z [err] ^
2020-07-17T20:40:08.759Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.759Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.759Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.759Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.759Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.759Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.759Z [err] ../src/./setaddr.cc:47:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.759Z [err] int addr = info[1]->Int32Value();
2020-07-17T20:40:08.760Z [err] In file included from ../src/i2c.cc:102:
2020-07-17T20:40:08.760Z [err] ../src/./setaddr.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE SetAddrSync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.760Z [err] ../src/./setaddr.cc:59:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.760Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.760Z [err] ^
2020-07-17T20:40:08.761Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.761Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.761Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.761Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.761Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.761Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.761Z [err] In file included from ../src/i2c.cc:102:
2020-07-17T20:40:08.761Z [err] ../src/./setaddr.cc:60:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.761Z [err] int addr = info[1]->Int32Value();
2020-07-17T20:40:08.764Z [err] In file included from ../src/i2c.cc:103:
2020-07-17T20:40:08.764Z [err] ../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteAsync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.764Z [err] ../src/./writebyte.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.764Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.764Z [err] ^
2020-07-17T20:40:08.764Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.764Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.764Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.764Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.764Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.764Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.764Z [err] ../src/./writebyte.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.764Z [err] __u8 cmd = info[1]->Int32Value();
2020-07-17T20:40:08.764Z [err] ../src/./writebyte.cc:51:35: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.764Z [err] __u8 byte = info[2]->Int32Value();
2020-07-17T20:40:08.765Z [err] In file included from ../src/i2c.cc:103:
2020-07-17T20:40:08.765Z [err] ../src/./writebyte.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteByteSync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.765Z [err] ../src/./writebyte.cc:63:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.765Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.765Z [err] ^
2020-07-17T20:40:08.766Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.766Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.766Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.766Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.766Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.766Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.766Z [err] In file included from ../src/i2c.cc:103:
2020-07-17T20:40:08.766Z [err] ../src/./writebyte.cc:64:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.766Z [err] __u8 cmd = info[1]->Int32Value();
2020-07-17T20:40:08.768Z [err] In file included from ../src/i2c.cc:103:
2020-07-17T20:40:08.768Z [err] ../src/./writebyte.cc:65:35: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.768Z [err] __u8 byte = info[2]->Int32Value();
2020-07-17T20:40:08.768Z [err] ^
2020-07-17T20:40:08.768Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.768Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.768Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.768Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.768Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.768Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.771Z [err] In file included from ../src/i2c.cc:104:
2020-07-17T20:40:08.771Z [err] ../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordAsync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.771Z [err] ../src/./writeword.cc:49:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.771Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.771Z [err] ^
2020-07-17T20:40:08.772Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.772Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.772Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.772Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.772Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.772Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.772Z [err] In file included from ../src/i2c.cc:104:
2020-07-17T20:40:08.772Z [err] ../src/./writeword.cc:50:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.772Z [err] __u8 cmd = info[1]->Int32Value();
2020-07-17T20:40:08.772Z [err] ../src/./writeword.cc:51:36: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.772Z [err] __u16 word = info[2]->Int32Value();
2020-07-17T20:40:08.773Z [err] In file included from ../src/i2c.cc:104:
2020-07-17T20:40:08.773Z [err] ../src/./writeword.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteWordSync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.773Z [err] ../src/./writeword.cc:64:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.773Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.773Z [err] ^
2020-07-17T20:40:08.773Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.773Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.773Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.773Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.773Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.773Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.773Z [err] ../src/./writeword.cc:65:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.773Z [err] __u8 cmd = info[1]->Int32Value();
2020-07-17T20:40:08.773Z [err] ../src/./writeword.cc:66:36: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.773Z [err] __u16 word = info[2]->Int32Value();
2020-07-17T20:40:08.777Z [err] In file included from ../src/i2c.cc:105:
2020-07-17T20:40:08.777Z [err] ../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.777Z [err] ../src/./writeblock.cc:70:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.777Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.777Z [err] ^
2020-07-17T20:40:08.778Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.778Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.778Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.778Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.778Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.778Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.778Z [err] In file included from ../src/i2c.cc:105:
2020-07-17T20:40:08.778Z [err] ../src/./writeblock.cc:71:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.778Z [err] __u8 cmd = info[1]->Int32Value();
2020-07-17T20:40:08.778Z [err] ../src/./writeblock.cc:72:39: error: no matching function for call to ‘v8::Value::Uint32Value()’
2020-07-17T20:40:08.778Z [err] __u32 length = info[2]->Uint32Value();
2020-07-17T20:40:08.778Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.778Z [err] V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(
2020-07-17T20:40:08.778Z [err] ^~~~~~~~~~~
2020-07-17T20:40:08.778Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.780Z [err] In file included from ../src/i2c.cc:105:
2020-07-17T20:40:08.780Z [err] ../src/./writeblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.780Z [err] ../src/./writeblock.cc:110:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.780Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.780Z [err] ^
2020-07-17T20:40:08.780Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.780Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.780Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.780Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.780Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.780Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.780Z [err] ../src/./writeblock.cc:111:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.780Z [err] __u8 cmd = info[1]->Int32Value();
2020-07-17T20:40:08.780Z [err] ../src/./writeblock.cc:112:39: error: no matching function for call to ‘v8::Value::Uint32Value()’
2020-07-17T20:40:08.780Z [err] __u32 length = info[2]->Uint32Value();
2020-07-17T20:40:08.780Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.780Z [err] V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(
2020-07-17T20:40:08.780Z [err] ^~~~~~~~~~~
2020-07-17T20:40:08.780Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.785Z [err] In file included from ../src/i2c.cc:106:
2020-07-17T20:40:08.785Z [err] ../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockAsync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.785Z [err] ../src/./writei2cblock.cc:68:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.785Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.785Z [err] ^
2020-07-17T20:40:08.785Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.785Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.785Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.785Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.785Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.785Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.785Z [err] ../src/./writei2cblock.cc:69:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.785Z [err] __u8 cmd = info[1]->Int32Value();
2020-07-17T20:40:08.785Z [err] ../src/./writei2cblock.cc:70:39: error: no matching function for call to ‘v8::Value::Uint32Value()’
2020-07-17T20:40:08.785Z [err] __u32 length = info[2]->Uint32Value();
2020-07-17T20:40:08.785Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.785Z [err] V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(
2020-07-17T20:40:08.785Z [err] ^~~~~~~~~~~
2020-07-17T20:40:08.785Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.787Z [err] In file included from ../src/i2c.cc:106:
2020-07-17T20:40:08.787Z [err] ../src/./writei2cblock.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteI2cBlockSync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.787Z [err] ../src/./writei2cblock.cc:108:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.787Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.787Z [err] ^
2020-07-17T20:40:08.788Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.788Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.788Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.788Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.788Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.788Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.788Z [err] In file included from ../src/i2c.cc:106:
2020-07-17T20:40:08.788Z [err] ../src/./writei2cblock.cc:109:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.788Z [err] __u8 cmd = info[1]->Int32Value();
2020-07-17T20:40:08.788Z [err] ../src/./writei2cblock.cc:110:39: error: no matching function for call to ‘v8::Value::Uint32Value()’
2020-07-17T20:40:08.788Z [err] __u32 length = info[2]->Uint32Value();
2020-07-17T20:40:08.788Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2707:41: note: candidate: ‘v8::Maybe v8::Value::Uint32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.788Z [err] V8_WARN_UNUSED_RESULT Maybe<uint32_t> Uint32Value(
2020-07-17T20:40:08.788Z [err] ^~~~~~~~~~~
2020-07-17T20:40:08.788Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2707:41: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.797Z [err] In file included from ../src/i2c.cc:107:
2020-07-17T20:40:08.797Z [err] ../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickAsync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.797Z [err] ../src/./writequick.cc:47:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.797Z [err] int fd = info[0]->Int32Value();
2020-07-17T20:40:08.797Z [err] ^
2020-07-17T20:40:08.797Z [err] In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/node.h:67,
2020-07-17T20:40:08.797Z [err] from ../src/i2c.cc:1:
2020-07-17T20:40:08.797Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe v8::Value::Int32Value(v8::Localv8::Context) const’
2020-07-17T20:40:08.797Z [err] V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local context) const;
2020-07-17T20:40:08.797Z [err] ^~~~~~~~~~
2020-07-17T20:40:08.797Z [err] /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2709:40: note: candidate expects 1 argument, 0 provided
2020-07-17T20:40:08.797Z [err] ../src/./writequick.cc:48:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.797Z [err] __u8 bit = info[1]->Int32Value();
2020-07-17T20:40:08.797Z [err] ../src/./writequick.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE WriteQuickSync(Nan::NAN_METHOD_ARGS_TYPE)’:
2020-07-17T20:40:08.797Z [err] ../src/./writequick.cc:60:32: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:08.797Z [err] ../src/./writequick.cc:61:34: error: no matching function for call to ‘v8::Value::Int32Value()’
2020-07-17T20:40:09.040Z [err] make: *** [i2c.target.mk:109: Release/obj.target/i2c/src/i2c.o] Error 1
2020-07-17T20:40:09.040Z [out] make : on quitte le répertoire « /home/pi/.node-red/node_modules/node-red-contrib-pca9685/node_modules/i2c-bus/build »
2020-07-17T20:40:09.043Z [err] gyp
2020-07-17T20:40:09.043Z [err] ERR! build error
2020-07-17T20:40:09.044Z [err] gyp
2020-07-17T20:40:09.045Z [err] ERR! stack
2020-07-17T20:40:09.045Z [err] Error: make failed with exit code: 2
2020-07-17T20:40:09.045Z [err] gyp ERR!
2020-07-17T20:40:09.045Z [err] stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
2020-07-17T20:40:09.045Z [err] at ChildProcess.emit (events.js:315:20)
2020-07-17T20:40:09.045Z [err] stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
2020-07-17T20:40:09.046Z [err] gyp
2020-07-17T20:40:09.046Z [err] ERR! System Linux 4.19.118-v7l+
2020-07-17T20:40:09.046Z [err] gyp ERR!
2020-07-17T20:40:09.046Z [err] command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2020-07-17T20:40:09.046Z [err] gyp ERR! cwd
2020-07-17T20:40:09.046Z [err] /home/pi/.node-red/node_modules/node-red-contrib-pca9685/node_modules/i2c-bus
2020-07-17T20:40:09.046Z [err] node -v v12.18.2
2020-07-17T20:40:09.047Z [err] ERR! node-gyp -v v5.1.0
2020-07-17T20:40:09.047Z [err] gyp ERR! not ok
2020-07-17T20:40:09.268Z [err] npm
2020-07-17T20:40:09.268Z [err] WARN node-red-project@0.0.1 No repository field.
2020-07-17T20:40:09.275Z [err] npm
2020-07-17T20:40:09.275Z [err] WARN node-red-project@0.0.1 No license field.
2020-07-17T20:40:09.314Z [err] npm
2020-07-17T20:40:09.314Z [err] ERR! code ELIFECYCLE
2020-07-17T20:40:09.314Z [err] npm ERR!
2020-07-17T20:40:09.315Z [err] errno 1
2020-07-17T20:40:09.319Z [err] npm ERR! i2c-bus@1.1.2 install: node-gyp rebuild
2020-07-17T20:40:09.319Z [err] npm ERR! Exit status 1
2020-07-17T20:40:09.319Z [err] npm ERR! Failed at the i2c-bus@1.1.2 install script.
2020-07-17T20:40:09.319Z [err] npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
2020-07-17T20:40:09.335Z [err]
2020-07-17T20:40:09.335Z [err] npm ERR! A complete log of this run can be found in:
2020-07-17T20:40:09.335Z [err] /home/pi/.npm/_logs/2020-07-17T20_40_09_322Z-debug.log
2020-07-17T20:40:09.347Z rc=1
Merci encore pour votre aide une parti du probleme est resolue.
Thanks again for your help. Part of the problem is solved.
Sebastien
I suspect that node will not install with current versions of nodejs. However, did you see and act upon this comment in the node's readme?
" It's advisable to install the i2c package first. Refer to The i2c npm page for more informations. This may require manual steps (e.g. enabling kernel modules). Please only proceed with this module once you've managed to properly install the i2c package, to simplify troubleshooting."
Bonjour Hello
Je désespère I despair
Je repars à zéro I go back to zero
1 - Nouvelle installation New installation
Raspberry Pi OS (32 bits) avec bureau et logiciel recommandé
Image avec bureau et logiciel recommandé basé sur Debian Buster
Version:Mai 2020
Taille:2523 Mo
2- Préférences/configuration du Raspberry PI/Interfaces :
SSH enabled
SPI enabled
I2C enabled
Serial port enabled
Serial console enabled
1-Wire enabled
Remote GPIO enabled
Restart
3- Installing and Upgrading Node-RED
https://nodered.org/docs/getting-started/raspberrypi
Are you really sure you want to do this ? [y/N] ? YES
Would you like to install the Pi-specific nodes ? [y/N] ? YES
Remove old version of Node.js -
Leave existing Node.js - Node v10.21.0 Npm 5.8.0
Clean npm cache -
Node v10.21.0 Npm 5.8.0npm WARN npm npm does not support Node.js v10.21.0
npm WARN npm You should probably upgrade to a newer version of node as we
npm WARN npm can't make any promises that npm will work with this version.
npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.dd shortcut commands
npm WARN npm You can find the latest version at https://nodejs.org/
Move global nodes to local :heavy_check_mark:
All done.
You can now start Node-RED with the command node-red-start
or using the icon under Menu / Programming / Node-RED
Then point your browser to localhost:1880 or http://{your_pi_ip-address}:1880
Started samedi 18 juillet 2020, 23:09:03 (UTC+0200) - Finished samedi 18 juillet 2020, 23:11:14 (UTC+0200)
pi@raspberrypi:~ $ Node v10.21.0 Npm 5.8.0
4- Installing I2C
npm install i2c
pi@raspberrypi:~ $ npm install i2c
npm WARN deprecated coffee-script@1.9.1: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
i2c@0.2.3 install /home/pi/node_modules/i2c
node-gyp rebuild
make : on entre dans le répertoire « /home/pi/node_modules/i2c/build »
CXX(target) Release/obj.target/i2c/src/i2c.o
In file included from ../../nan/nan.h:190,
from ../src/i2c.cc:3:
../../nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe Nan::ForceSet(v8::Localv8::Object, v8::Localv8::Value, v8::Localv8::Value, v8::PropertyAttribute)’:
../../nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
return obj->ForceSet(GetCurrentContext(), key, value, attribs);
In file included from ../src/i2c.cc:3:
../../nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value)’:
../../nan/nan.h:817:60: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate
, v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
v8::Isolate::GetCurrent(), target, func, argc, argv);
In file included from ../src/i2c.cc:1:
/usr/include/nodejs/src/node.h:177:50: note: declared here
NODE_EXTERN v8::Localv8::Value MakeCallback(
/usr/include/nodejs/src/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
attribute((deprecated(message))) declarator
../../nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value
../../nan/nan.h:831:62: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate*, v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
v8::Isolate::GetCurrent(), target, symbol, argc, argv);
/usr/include/nodejs/src/node.h:170:50: note: declared here
../../nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, const char
../../nan/nan.h:845:62: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate
, v8::Localv8::Object, const char*, int, v8::Localv8::Value)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
v8::Isolate::GetCurrent(), target, method, argc, argv);
/usr/include/nodejs/src/node.h:163:50: note: declared here
../../nan/nan.h: In member function ‘v8::Localv8::Value Nan::Callback::Call_(v8::Isolate
, v8::Localv8::Object, int, v8::Localv8::Value) const’:
../../nan/nan.h:1463:5: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate
../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker
../../nan/nan.h:1706:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
, reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
../src/i2c.cc: In function ‘void SetAddress(const Nan::FunctionCallbackInfov8::Value&)’:
../src/i2c.cc:38:30: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
addr = info[0]->Int32Value();
In file included from /usr/include/nodejs/deps/v8/include/v8.h:26,
from /usr/include/nodejs/src/node.h:63,
/usr/include/nodejs/deps/v8/include/v8.h:2478:46: note: declared here
V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
/usr/include/nodejs/deps/v8/include/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
declarator attribute((deprecated(message)))
../src/i2c.cc: In function ‘void Open(const Nan::FunctionCallbackInfov8::Value&)’:
../src/i2c.cc:84:35: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
String::Utf8Value device(info[0]);
/usr/include/nodejs/deps/v8/include/v8.h:2892:28: note: declared here
explicit Utf8Value(Localv8::Value obj));
../src/i2c.cc: In function ‘void Read(const Nan::FunctionCallbackInfov8::Value&)’:
../src/i2c.cc:103:33: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
int len = info[0]->Int32Value();
../src/i2c.cc: In function ‘void ReadBlock(const Nan::FunctionCallbackInfov8::Value&)’:
../src/i2c.cc:154:36: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
int8_t cmd = info[0]->Int32Value();
../src/i2c.cc:155:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
int32_t len = info[1]->Int32Value();
../src/i2c.cc:178:43: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
int32_t delay = info[2]->Int32Value();
../src/i2c.cc: In function ‘void Write(const Nan::FunctionCallbackInfov8::Value&)’:
../src/i2c.cc:193:53: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
int len = node::Buffer::Length(buffer->ToObject());
In file included from /usr/include/nodejs/src/node.h:63,
/usr/include/nodejs/deps/v8/include/v8.h:10046:15: note: declared here
Local Value::ToObject() const {
../src/i2c.cc:194:52: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
char* data = node::Buffer::Data(buffer->ToObject());
../src/i2c.cc: In function ‘void WriteByte(const Nan::FunctionCallbackInfov8::Value&)’:
../src/i2c.cc:213:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
int8_t byte = info[0]->Int32Value();
../src/i2c.cc: In function ‘void WriteBlock(const Nan::FunctionCallbackInfov8::Value&)’:
../src/i2c.cc:232:36: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../src/i2c.cc:233:53: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../src/i2c.cc:234:52: warning: ‘v8::Localv8::Object v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../src/i2c.cc: In function ‘void WriteWord(const Nan::FunctionCallbackInfov8::Value&)’:
../src/i2c.cc:253:36: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../src/i2c.cc:254:38: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
int16_t word = info[1]->Int32Value();
../src/i2c.cc: At global scope:
/usr/include/nodejs/src/node.h:573:43: warning: cast between incompatible function types from ‘void ()(v8::Handlev8::Object)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type]
(node::addon_register_func) (regfunc),
/usr/include/nodejs/src/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’
NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
../src/i2c.cc:295:1: note: in expansion of macro ‘NODE_MODULE’
NODE_MODULE(i2c, Init)
/usr/include/nodejs/deps/v8/include/v8.h: In instantiation of ‘void v8::PersistentBase::SetWeak(P*, typename v8::WeakCallbackInfo
::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo
::Callback = void ()(const v8::WeakCallbackInfonode::ObjectWrap&)]’:
/usr/include/nodejs/src/node_object_wrap.h:84:78: required from here
/usr/include/nodejs/deps/v8/include/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfonode::ObjectWrap::Callback’ {aka ‘void (
)(const v8::WeakCallbackInfonode::ObjectWrap&)’} to ‘Callback’ {aka ‘void ()(const v8::WeakCallbackInfo&)’} [-Wcast-function-type]
reinterpret_cast(callback), type);
::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo
::Callback = void ()(const v8::WeakCallbackInfoNan::ObjectWrap&)]’:
../../nan/nan_object_wrap.h:66:61: required from here
/usr/include/nodejs/deps/v8/include/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfoNan::ObjectWrap::Callback’ {aka ‘void (
)(const v8::WeakCallbackInfoNan::ObjectWrap&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo&)’} [-Wcast-function-type]
make: *** [i2c.target.mk:101: Release/obj.target/i2c/src/i2c.o] Error 1
make : on quitte le répertoire « /home/pi/node_modules/i2c/build »
gyp ERR! build error
gyp ERR! stack Error: make failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/share/node-gyp/lib/build.js:262:23)
gyp ERR! stack at ChildProcess.emit (events.js:198:13)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
gyp ERR! System Linux 4.19.118-v7l+
gyp ERR! command "/usr/bin/node" "/usr/bin/node-gyp" "rebuild"
gyp ERR! cwd /home/pi/node_modules/i2c
gyp ERR! node -v v10.21.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
npm WARN pi No description
npm WARN pi No repository field.
npm WARN pi No README data
npm WARN pi No license field.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! i2c@0.2.3 install: node-gyp rebuild
npm ERR!
npm ERR! Failed at the i2c@0.2.3 install script.
npm ERR! /home/pi/.npm/_logs/2020-07-18T21_22_02_935Z-debug.log
pi@raspberrypi:~ $
Problem install I2c
This looks worrying - in case anyone else misses it.
Upgrade Node
1 curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash -
2 sudo apt-get install -y nodejs
3 pi@raspberrypi:~ $ nodejs -v v12.18.2
4 - sudo apt-get install -y npm
5 - sudo npm install -g npm@latest
6 - pi@raspberrypi:~ $ npm -version 6.14.6
7 - Reboot
8 - Installing I2C
npm install i2c
6.14.6
v12.18.2
node-gyp rebuild
In file included from ../../nan/nan_converters.h:59,
from ../../nan/nan.h:195,
../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ToFactoryBasev8::Boolean::return_t Nan::imp::ToFactoryv8::Boolean::convert(v8::Localv8::Value)’:
../../nan/nan_converters_43_inl.h:15:45: warning: ‘v8::MaybeLocalv8::Boolean v8::Value::ToBoolean(v8::Localv8::Context) const’ is deprecated: ToBoolean can never throw. Use Local version. [-Wdeprecated-declarations]
return val->To ## TYPE(GetCurrentContext());
../../nan/nan_converters_43_inl.h:18:1: note: in expansion of macro ‘X’
X(Boolean)
In file included from /home/pi/.cache/node-gyp/12.18.2/include/node/v8-internal.h:14,
from /home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:27,
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2664:59: note: declared here
V8_WARN_UNUSED_RESULT MaybeLocal ToBoolean(
/home/pi/.cache/node-gyp/12.18.2/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
../../nan/nan_converters_43_inl.h: In static member function ‘static Nan::imp::ValueFactoryBase::return_t Nan::imp::ToFactory::convert(v8::Localv8::Value)’:
../../nan/nan_converters_43_inl.h:31:48: warning: ‘v8::Maybe v8::Value::BooleanValue(v8::Localv8::Context) const’ is deprecated: BooleanValue can never throw. Use Isolate version. [-Wdeprecated-declarations]
return val->NAME ## Value(GetCurrentContext());
../../nan/nan_converters_43_inl.h:34:1: note: in expansion of macro ‘X’
X(bool, Boolean)
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2702:51: note: declared here
V8_WARN_UNUSED_RESULT Maybe BooleanValue(
In file included from ../../nan/nan_new.h:189,
from ../../nan/nan.h:196,
../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBasev8::Function::return_t Nan::imp::Factoryv8::Function::New(Nan::FunctionCallback, v8::Localv8::Value)’:
../../nan/nan_implementation_12_inl.h:109:32: error: no matching function for call to ‘v8::Function::New(v8::Isolate*&, void (&)(const v8::FunctionCallbackInfov8::Value&), v8::Localv8::Object&)’
, obj));
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:4275:31: note: candidate: ‘static v8::MaybeLocalv8::Function v8::Function::New(v8::Localv8::Context, v8::FunctionCallback, v8::Localv8::Value, int, v8::ConstructorBehavior, v8::SideEffectType)’
static MaybeLocal New(
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:4275:31: note: no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Localv8::Context’
../../nan/nan_implementation_12_inl.h: In static member function ‘static Nan::imp::FactoryBasev8::StringObject::return_t Nan::imp::Factoryv8::StringObject::New(v8::Localv8::String)’:
../../nan/nan_implementation_12_inl.h:345:37: error: no matching function for call to ‘v8::StringObject::New(v8::Localv8::String&)’
return v8::StringObject::New(value).Asv8::StringObject();
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:5531:23: note: candidate: ‘static v8::Localv8::Value v8::StringObject::New(v8::Isolate*, v8::Localv8::String)’
static Local New(Isolate* isolate, Local value);
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:5531:23: note: candidate expects 2 arguments, 1 provided
../../nan/nan_implementation_12_inl.h:345:58: error: expected primary-expression before ‘>’ token
../../nan/nan_implementation_12_inl.h:345:60: error: expected primary-expression before ‘)’ token
/home/pi/.cache/node-gyp/12.18.2/include/node/node.h:182:50: note: declared here
/home/pi/.cache/node-gyp/12.18.2/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’
/home/pi/.cache/node-gyp/12.18.2/include/node/node.h:175:50: note: declared here
/home/pi/.cache/node-gyp/12.18.2/include/node/node.h:168:50: note: declared here
../../nan/nan.h: In constructor ‘Nan::Utf8String::Utf8String(v8::Localv8::Value)’:
../../nan/nan.h:890:53: error: no matching function for call to ‘v8::Value::ToString()’
v8::Localv8::String string = from->ToString();
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2668:44: note: candidate: ‘v8::MaybeLocalv8::String v8::Value::ToString(v8::Localv8::Context) const’
V8_WARN_UNUSED_RESULT MaybeLocal ToString(
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2668:44: note: candidate expects 1 argument, 0 provided
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2684:31: note: candidate: ‘v8::Localv8::String v8::Value::ToString(v8::Isolate
) const’
Local ToString(Isolate* isolate) const);
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2684:31: note: candidate expects 1 argument, 0 provided
../../nan/nan.h:900:74: error: no matching function for call to ‘v8::String::WriteUtf8(char*&, int, int, const int&)’
length_ = string->WriteUtf8(str_, static_cast(len), 0, flags);
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2878:7: note: no known conversion for argument 1 from ‘char*’ to ‘v8::Isolate*’
../../nan/nan.h: In member function ‘bool Nan::Callback::operator==(const Nan::Callback&) const’:
../../nan/nan.h:1371:61: warning: ‘v8::Localv8::Value v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
v8::Localv8::Value a = New(handle)->Get(kCallbackIndex);
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:3557:51: note: declared here
V8_DEPRECATED("Use maybe version", Local Get(uint32_t index));
../../nan/nan.h:1372:67: warning: ‘v8::Localv8::Value v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
v8::Localv8::Value b = New(other.handle)->Get(kCallbackIndex);
../../nan/nan.h: In member function ‘v8::Localv8::Function Nan::Callback::GetFunction() const’:
../../nan/nan.h:1403:56: warning: ‘v8::Localv8::Value v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
return scope.Escape(New(handle)->Get(kCallbackIndex)
../../nan/nan.h: In member function ‘bool Nan::Callback::IsEmpty() const’:
../../nan/nan.h:1409:43: warning: ‘v8::Localv8::Value v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
return New(handle)->Get(kCallbackIndex)->IsUndefined();
../../nan/nan.h: In member function ‘v8::Localv8::Value Nan::Callback::Call_(v8::Isolate*, v8::Localv8::Object, int, v8::Localv8::Value) const’:
../../nan/nan.h:1447:27: warning: ‘v8::Localv8::Value v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
Get(kCallbackIndex).Asv8::Function();
../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const char
, const v8::Localv8::Value&)’:
../../nan/nan.h:1518:64: warning: ‘bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
New(persistentHandle)->Set(New(key).ToLocalChecked(), value);
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:3499:22: note: declared here
bool Set(Local key, Local value));
../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(const v8::Localv8::String&, const v8::Localv8::Value&)’:
../../nan/nan.h:1524:42: warning: ‘bool v8::Object::Set(v8::Localv8::Value, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
New(persistentHandle)->Set(key, value);
../../nan/nan.h: In member function ‘void Nan::AsyncWorker::SaveToPersistent(uint32_t, const v8::Localv8::Value&)’:
../../nan/nan.h:1530:44: warning: ‘bool v8::Object::Set(uint32_t, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
New(persistentHandle)->Set(index, value);
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:3508:22: note: declared here
bool Set(uint32_t index, Local value));
../../nan/nan.h: In member function ‘v8::Localv8::Value Nan::AsyncWorker::GetFromPersistent(const char*) const’:
../../nan/nan.h:1536:61: warning: ‘v8::Localv8::Value v8::Object::Get(v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
New(persistentHandle)->Get(New(key).ToLocalChecked()));
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:3553:51: note: declared here
V8_DEPRECATED("Use maybe version", Local Get(Local key));
../../nan/nan.h: In member function ‘v8::Localv8::Value Nan::AsyncWorker::GetFromPersistent(const v8::Localv8::String&) const’:
../../nan/nan.h:1542:55: warning: ‘v8::Localv8::Value v8::Object::Get(v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
return scope.Escape(New(persistentHandle)->Get(key));
../../nan/nan.h: In member function ‘v8::Localv8::Value Nan::AsyncWorker::GetFromPersistent(uint32_t) const’:
../../nan/nan.h:1547:57: warning: ‘v8::Localv8::Value v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
return scope.Escape(New(persistentHandle)->Get(index));
../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
In file included from /usr/include/c++/8/cassert:44,
from /home/pi/.cache/node-gyp/12.18.2/include/node/node_object_wrap.h:26,
from ../../nan/nan.h:49,
../../nan/nan_object_wrap.h: In destructor ‘virtual Nan::ObjectWrap::~ObjectWrap()’:
../../nan/nan_object_wrap.h:24:25: error: ‘class Nan::Persistentv8::Object’ has no member named ‘IsNearDeath’
assert(persistent().IsNearDeath());
In file included from ../../nan/nan.h:2192,
../../nan/nan_object_wrap.h: In member function ‘void Nan::ObjectWrap::MakeWeak()’:
../../nan/nan_object_wrap.h:67:34: warning: ‘void v8::PersistentBase::MarkIndependent() [with T = v8::Object]’ is deprecated: Weak objects are always considered independent. Use TracedGlobal when trying to use EmbedderHeapTracer. Use a strong handle when trying to keep an object alive. [-Wdeprecated-declarations]
persistent().MarkIndependent();
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:570:22: note: declared here
V8_INLINE void MarkIndependent());
../../nan/nan_object_wrap.h: In static member function ‘static void Nan::ObjectWrap::WeakCallback(const v8::WeakCallbackInfoNan::ObjectWrap&)’:
../../nan/nan_object_wrap.h:124:26: error: ‘class Nan::Persistentv8::Object’ has no member named ‘IsNearDeath’
assert(wrap->handle_.IsNearDeath());
../src/i2c.cc:38:30: error: no matching function for call to ‘v8::Value::Int32Value()’
../src/i2c.cc: In function ‘void Scan(const Nan::FunctionCallbackInfov8::Value&)’:
../src/i2c.cc:60:43: warning: ‘bool v8::Object::Set(uint32_t, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
results->Set(i, Nan::New(res));
../src/i2c.cc:84:35: error: no matching function for call to ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:3135:5: note: candidate: ‘v8::String::Utf8Value::Utf8Value(v8::Isolate*, v8::Localv8::Value)’
Utf8Value(Isolate* isolate, Localv8::Value obj);
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:3135:5: note: candidate expects 2 arguments, 1 provided
../src/i2c.cc:103:33: error: no matching function for call to ‘v8::Value::Int32Value()’
../src/i2c.cc:114:45: warning: ‘bool v8::Object::Set(uint32_t, v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
data->Set(i, Nan::New(buf[i]));
../src/i2c.cc:154:36: error: no matching function for call to ‘v8::Value::Int32Value()’
../src/i2c.cc:155:37: error: no matching function for call to ‘v8::Value::Int32Value()’
../src/i2c.cc:178:43: error: no matching function for call to ‘v8::Value::Int32Value()’
../src/i2c.cc:193:53: error: no matching function for call to ‘v8::Value::ToObject()’
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2672:44: note: candidate: ‘v8::MaybeLocalv8::Object v8::Value::ToObject(v8::Localv8::Context) const’
V8_WARN_UNUSED_RESULT MaybeLocal ToObject(
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2672:44: note: candidate expects 1 argument, 0 provided
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2686:31: note: candidate: ‘v8::Localv8::Object v8::Value::ToObject(v8::Isolate*) const’
Local ToObject(Isolate* isolate) const);
/home/pi/.cache/node-gyp/12.18.2/include/node/v8.h:2686:31: note: candidate expects 1 argument, 0 provided
../src/i2c.cc:194:52: error: no matching function for call to ‘v8::Value::ToObject()’
../src/i2c.cc:213:37: error: no matching function for call to ‘v8::Value::Int32Value()’
../src/i2c.cc:232:36: error: no matching function for call to ‘v8::Value::Int32Value()’
../src/i2c.cc:233:53: error: no matching function for call to ‘v8::Value::ToObject()’
../src/i2c.cc:234:52: error: no matching function for call to ‘v8::Value::ToObject()’
../src/i2c.cc:253:36: error: no matching function for call to ‘v8::Value::Int32Value()’
../src/i2c.cc:254:38: error: no matching function for call to ‘v8::Value::Int32Value()’
../src/i2c.cc:270:11: error: variable or field ‘Init’ declared void
void Init(Handle exports) {
../src/i2c.cc:270:11: error: ‘Handle’ was not declared in this scope
../src/i2c.cc:270:11: note: suggested alternative: ‘rand_r’
rand_r
../src/i2c.cc:270:24: error: expected primary-expression before ‘>’ token
../src/i2c.cc:270:26: error: ‘exports’ was not declared in this scope
../src/i2c.cc:295:18: error: ‘Init’ was not declared in this scope
/home/pi/.cache/node-gyp/12.18.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
../src/i2c.cc:295:18: note: suggested alternative:
/home/pi/.cache/node-gyp/12.18.2/include/node/node.h:225:18: note: ‘node::Init’
NODE_EXTERN void Init(int* argc,
gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
gyp ERR! stack at ChildProcess.emit (events.js:315:20)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
gyp ERR! node -v v12.18.2
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
npm ERR! errno 1
npm ERR!
npm ERR! /home/pi/.npm/_logs/2020-07-18T21_56_53_849Z-debug.log
pi@raspberrypi:~ $
File npm ERR! /home/pi/.npm/_logs/2020-07-18T22_16_52_665Z-debug.log
0 info it worked if it ends with ok
1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'install', 'i2c' ]
2 info using npm@6.14.6
3 info using node@v12.18.2
4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
5 verbose npm-session afabb872d4f45cae
6 silly install loadCurrentTree
7 silly install readLocalPackageData
8 http fetch GET 304 https://registry.npmjs.org/i2c 297ms (from cache)
9 silly pacote tag manifest for i2c@latest fetched in 327ms
10 timing stage:loadCurrentTree Completed in 371ms
11 silly install loadIdealTree
12 silly install cloneCurrentTreeToIdealTree
13 timing stage:loadIdealTree:cloneCurrentTree Completed in 1ms
14 silly install loadShrinkwrap
15 timing stage:loadIdealTree:loadShrinkwrap Completed in 6ms
16 silly install loadAllDepsIntoIdealTree
17 silly resolveWithNewModule i2c@0.2.3 checking installable status
18 http fetch GET 304 https://registry.npmjs.org/bindings 108ms (from cache)
19 silly pacote version manifest for bindings@1.2.1 fetched in 114ms
20 silly resolveWithNewModule bindings@1.2.1 checking installable status
21 http fetch GET 304 https://registry.npmjs.org/underscore 203ms (from cache)
22 http fetch GET 304 https://registry.npmjs.org/coffee-script 208ms (from cache)
23 silly pacote version manifest for underscore@1.8.2 fetched in 214ms
24 silly resolveWithNewModule underscore@1.8.2 checking installable status
25 http fetch GET 304 https://registry.npmjs.org/repl 211ms (from cache)
26 http fetch GET 304 https://registry.npmjs.org/nan 210ms (from cache)
27 silly pacote version manifest for coffee-script@1.9.1 fetched in 225ms
28 warn deprecated coffee-script@1.9.1: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
29 silly resolveWithNewModule coffee-script@1.9.1 checking installable status
30 silly pacote version manifest for repl@0.1.3 fetched in 227ms
31 silly resolveWithNewModule repl@0.1.3 checking installable status
32 silly pacote range manifest for nan@~2.3.5 fetched in 227ms
33 silly resolveWithNewModule nan@2.3.5 checking installable status
34 timing stage:loadIdealTree:loadAllDepsIntoIdealTree Completed in 264ms
35 timing stage:loadIdealTree Completed in 280ms
36 silly currentTree pi
37 silly idealTree pi
37 silly idealTree ├── bindings@1.2.1
37 silly idealTree ├── coffee-script@1.9.1
37 silly idealTree ├── i2c@0.2.3
37 silly idealTree ├── nan@2.3.5
37 silly idealTree ├── repl@0.1.3
37 silly idealTree └── underscore@1.8.2
38 silly install generateActionsToTake
39 timing stage:generateActionsToTake Completed in 13ms
40 silly diffTrees action count 6
41 silly diffTrees add bindings@1.2.1
42 silly diffTrees add coffee-script@1.9.1
43 silly diffTrees add nan@2.3.5
44 silly diffTrees add repl@0.1.3
45 silly diffTrees add underscore@1.8.2
46 silly diffTrees add i2c@0.2.3
47 silly decomposeActions action count 48
48 silly decomposeActions fetch bindings@1.2.1
49 silly decomposeActions extract bindings@1.2.1
50 silly decomposeActions preinstall bindings@1.2.1
51 silly decomposeActions build bindings@1.2.1
52 silly decomposeActions install bindings@1.2.1
53 silly decomposeActions postinstall bindings@1.2.1
54 silly decomposeActions finalize bindings@1.2.1
55 silly decomposeActions refresh-package-json bindings@1.2.1
56 silly decomposeActions fetch coffee-script@1.9.1
57 silly decomposeActions extract coffee-script@1.9.1
58 silly decomposeActions preinstall coffee-script@1.9.1
59 silly decomposeActions build coffee-script@1.9.1
60 silly decomposeActions install coffee-script@1.9.1
61 silly decomposeActions postinstall coffee-script@1.9.1
62 silly decomposeActions finalize coffee-script@1.9.1
63 silly decomposeActions refresh-package-json coffee-script@1.9.1
64 silly decomposeActions fetch nan@2.3.5
65 silly decomposeActions extract nan@2.3.5
66 silly decomposeActions preinstall nan@2.3.5
67 silly decomposeActions build nan@2.3.5
68 silly decomposeActions install nan@2.3.5
69 silly decomposeActions postinstall nan@2.3.5
70 silly decomposeActions finalize nan@2.3.5
71 silly decomposeActions refresh-package-json nan@2.3.5
72 silly decomposeActions fetch repl@0.1.3
73 silly decomposeActions extract repl@0.1.3
74 silly decomposeActions preinstall repl@0.1.3
75 silly decomposeActions build repl@0.1.3
76 silly decomposeActions install repl@0.1.3
77 silly decomposeActions postinstall repl@0.1.3
78 silly decomposeActions finalize repl@0.1.3
79 silly decomposeActions refresh-package-json repl@0.1.3
80 silly decomposeActions fetch underscore@1.8.2
81 silly decomposeActions extract underscore@1.8.2
82 silly decomposeActions preinstall underscore@1.8.2
83 silly decomposeActions build underscore@1.8.2
84 silly decomposeActions install underscore@1.8.2
85 silly decomposeActions postinstall underscore@1.8.2
86 silly decomposeActions finalize underscore@1.8.2
87 silly decomposeActions refresh-package-json underscore@1.8.2
88 silly decomposeActions fetch i2c@0.2.3
89 silly decomposeActions extract i2c@0.2.3
90 silly decomposeActions preinstall i2c@0.2.3
91 silly decomposeActions build i2c@0.2.3
92 silly decomposeActions install i2c@0.2.3
93 silly decomposeActions postinstall i2c@0.2.3
94 silly decomposeActions finalize i2c@0.2.3
95 silly decomposeActions refresh-package-json i2c@0.2.3
96 silly install executeActions
97 silly doSerial global-install 48
98 verbose correctMkdir /home/pi/.npm/_locks correctMkdir not in flight; initializing
99 verbose lock using /home/pi/.npm/_locks/staging-8a58fe8d264b10c5.lock for /home/pi/node_modules/.staging
100 silly doParallel extract 6
101 silly extract bindings@1.2.1
102 silly extract coffee-script@1.9.1
103 silly extract nan@2.3.5
104 silly extract repl@0.1.3
105 silly extract underscore@1.8.2
106 silly extract i2c@0.2.3
107 silly tarball trying bindings@1.2.1 by hash: sha1-FK1hE4EtLTfXLme0ystLtyZQXxE=
108 silly tarball trying coffee-script@1.9.1 by hash: sha1-xFjQIgD0YNBkp5y2qx7m4snKHDE=
109 silly tarball trying nan@~2.3.5 by hash: sha1-gioNwmYpDOTNOhIoLKPn42Rmigg=
110 silly tarball trying repl@0.1.3 by hash: sha1-LwXUKwyItD0FzL2hDtFK7/Vpm2A=
111 silly tarball trying underscore@1.8.2 by hash: sha1-ZN8utZCJnelQeC83NRkLpC6/MR0=
112 silly tarball trying i2c@latest by hash: sha1-9D9wKBQQJq5IrymQo3RjPR2rPSs=
113 silly extract bindings@1.2.1 extracted to /home/pi/node_modules/.staging/bindings-e015561d (173ms)
114 silly extract repl@0.1.3 extracted to /home/pi/node_modules/.staging/repl-ace48fe3 (178ms)
115 silly extract underscore@1.8.2 extracted to /home/pi/node_modules/.staging/underscore-6c1ca856 (185ms)
116 silly extract i2c@latest extracted to /home/pi/node_modules/.staging/i2c-3a50d040 (200ms)
117 timing audit submit Completed in 229ms
118 http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/audits/quick 230ms
119 timing audit body Completed in 2ms
120 silly extract coffee-script@1.9.1 extracted to /home/pi/node_modules/.staging/coffee-script-cb34d89b (225ms)
121 silly extract nan@~2.3.5 extracted to /home/pi/node_modules/.staging/nan-cbd23b3f (227ms)
122 timing action:extract Completed in 234ms
123 silly doReverseSerial unbuild 48
124 silly doSerial remove 48
125 silly doSerial move 48
126 silly doSerial finalize 48
127 silly finalize /home/pi/node_modules/bindings
128 silly finalize /home/pi/node_modules/coffee-script
129 silly finalize /home/pi/node_modules/nan
130 silly finalize /home/pi/node_modules/repl
131 silly finalize /home/pi/node_modules/underscore
132 silly finalize /home/pi/node_modules/i2c
133 timing action:finalize Completed in 21ms
134 silly doParallel refresh-package-json 6
135 silly refresh-package-json /home/pi/node_modules/bindings
136 silly refresh-package-json /home/pi/node_modules/coffee-script
137 silly refresh-package-json /home/pi/node_modules/nan
138 silly refresh-package-json /home/pi/node_modules/repl
139 silly refresh-package-json /home/pi/node_modules/underscore
140 silly refresh-package-json /home/pi/node_modules/i2c
141 timing action:refresh-package-json Completed in 61ms
142 silly doParallel preinstall 6
143 silly preinstall bindings@1.2.1
144 info lifecycle bindings@1.2.1~preinstall: bindings@1.2.1
145 silly preinstall coffee-script@1.9.1
146 info lifecycle coffee-script@1.9.1~preinstall: coffee-script@1.9.1
147 silly preinstall nan@2.3.5
148 info lifecycle nan@2.3.5~preinstall: nan@2.3.5
149 silly preinstall repl@0.1.3
150 info lifecycle repl@0.1.3~preinstall: repl@0.1.3
151 silly preinstall underscore@1.8.2
152 info lifecycle underscore@1.8.2~preinstall: underscore@1.8.2
153 silly preinstall i2c@0.2.3
154 info lifecycle i2c@0.2.3~preinstall: i2c@0.2.3
155 timing action:preinstall Completed in 5ms
156 silly doSerial build 48
157 silly build bindings@1.2.1
158 info linkStuff bindings@1.2.1
159 silly linkStuff bindings@1.2.1 has /home/pi/node_modules as its parent node_modules
160 silly build coffee-script@1.9.1
161 info linkStuff coffee-script@1.9.1
162 silly linkStuff coffee-script@1.9.1 has /home/pi/node_modules as its parent node_modules
163 verbose linkBins [
163 verbose linkBins { coffee: 'bin/coffee', cake: 'bin/cake' },
163 verbose linkBins '/home/pi/node_modules/.bin',
163 verbose linkBins false
163 verbose linkBins ]
164 silly build nan@2.3.5
165 info linkStuff nan@2.3.5
166 silly linkStuff nan@2.3.5 has /home/pi/node_modules as its parent node_modules
167 silly build repl@0.1.3
168 info linkStuff repl@0.1.3
169 silly linkStuff repl@0.1.3 has /home/pi/node_modules as its parent node_modules
170 silly build underscore@1.8.2
171 info linkStuff underscore@1.8.2
172 silly linkStuff underscore@1.8.2 has /home/pi/node_modules as its parent node_modules
173 silly build i2c@0.2.3
174 info linkStuff i2c@0.2.3
175 silly linkStuff i2c@0.2.3 has /home/pi/node_modules as its parent node_modules
176 timing action:build Completed in 12ms
177 silly doSerial global-link 48
178 silly doParallel update-linked 0
179 silly doSerial install 48
180 silly install bindings@1.2.1
181 info lifecycle bindings@1.2.1~install: bindings@1.2.1
182 silly install coffee-script@1.9.1
183 info lifecycle coffee-script@1.9.1~install: coffee-script@1.9.1
184 silly install nan@2.3.5
185 info lifecycle nan@2.3.5~install: nan@2.3.5
186 silly install repl@0.1.3
187 info lifecycle repl@0.1.3~install: repl@0.1.3
188 silly install underscore@1.8.2
189 info lifecycle underscore@1.8.2~install: underscore@1.8.2
190 silly install i2c@0.2.3
191 info lifecycle i2c@0.2.3~install: i2c@0.2.3
192 verbose lifecycle i2c@0.2.3~install: unsafe-perm in lifecycle true
193 verbose lifecycle i2c@0.2.3~install: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/node_modules/i2c/node_modules/.bin:/home/pi/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
194 verbose lifecycle i2c@0.2.3~install: CWD: /home/pi/node_modules/i2c
195 silly lifecycle i2c@0.2.3~install: Args: [ '-c', 'node-gyp rebuild' ]
196 silly lifecycle i2c@0.2.3~install: Returned: code: 1 signal: null
197 info lifecycle i2c@0.2.3~install: Failed to exec install script
198 timing action:install Completed in 2945ms
199 verbose unlock done using /home/pi/.npm/_locks/staging-8a58fe8d264b10c5.lock for /home/pi/node_modules/.staging
200 timing stage:rollbackFailedOptional Completed in 58ms
201 timing stage:runTopLevelLifecycles Completed in 4057ms
202 silly saveTree pi
202 silly saveTree └─┬ i2c@0.2.3
202 silly saveTree ├── bindings@1.2.1
202 silly saveTree ├── coffee-script@1.9.1
202 silly saveTree ├── nan@2.3.5
202 silly saveTree ├── repl@0.1.3
202 silly saveTree └── underscore@1.8.2
203 warn enoent ENOENT: no such file or directory, open '/home/pi/package.json'
204 verbose enoent This is related to npm not being able to find a file.
205 warn pi No description
206 warn pi No repository field.
207 warn pi No README data
208 warn pi No license field.
209 verbose stack Error: i2c@0.2.3 install: node-gyp rebuild
209 verbose stack Exit status 1
209 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
209 verbose stack at EventEmitter.emit (events.js:315:20)
209 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
209 verbose stack at ChildProcess.emit (events.js:315:20)
209 verbose stack at maybeClose (internal/child_process.js:1021:16)
209 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:286:5)
210 verbose pkgid i2c@0.2.3
211 verbose cwd /home/pi
212 verbose Linux 4.19.118-v7l+
213 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "i2c"
214 verbose node v12.18.2
215 verbose npm v6.14.6
216 error code ELIFECYCLE
217 error errno 1
218 error i2c@0.2.3 install: node-gyp rebuild
218 error Exit status 1
219 error Failed at the i2c@0.2.3 install script.
219 error This is probably not a problem with npm. There is likely additional logging output above.
220 verbose exit [ 1, true ]
As I said previously, the node is probably not compatible with nodejs 12. It has not been released for 4 years so that is not particularly surprising.
I am afraid I don't know what to suggest, I don't use i2c but there has recently been discussion about its support and I suspect there may be alternative ways of accessing your hardware. Have a search of the forum and if you don't have any joy then post a questions specifically asking about i2c.
For future reference it is best to get the install script to install nodejs and npm rather than doing it yourself, unless you know what you are doing. That is not the problem here though. The version of nodejs on nodesource includes npm so it isn't necessary to install it manually.
In your situation I would uninstall nodejs and npm and run the script again. However, as I said that is not the cause of the problem with this node.
Let's rewind... what piece of hardware are you trying to talk to that needs that. That is a raw nodejs i2c piece of code - not a Node-RED node - so may not be what we need.... (or may be).
As far as I could understand the OP wants to install contrib node-red-contrib- pca9685. The OP stated that the documentation instructs to install first the I2C package. As far as I could understand the contrib node pca9685 stopped using the I2C package in favor of I2c-bus package but the documentation has not been updated. Apparently @Sebchauvour is spending a lot of time and effort in something that is not necessary. However...even if he tries to install node-red-contrib-pca9685 there will be an issue. The package.json file for the contrib node lists as dependency: "i2c-bus": "~4.0.9" which is no longer the newest one.
Hello
Downgrade node js V9.11.2
Install node contib pca9685
System OK :wink:
