I have attempted to install two modules recently. node-red-contrib-sun-position, and node-red-dashboard. Both have failed due to the same error. Here is the output from my log file:
2022-11-18T00:50:37.753Z Install : node-red-dashboard 3.2.0
2022-11-18T00:50:38.072Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-dashboard@3.2.0
2022-11-18T00:50:44.200Z [err] npm
2022-11-18T00:50:44.200Z [err] WARN locking Error: EACCES: permission denied, open '/data/.npm/_locks/staging-accc372ed0ccb0d8.lock'
2022-11-18T00:50:44.200Z [err] npm WARN locking /data/.npm/_locks/staging-accc372ed0ccb0d8.lock failed [Error: EACCES: permission denied, open '/data/.npm/_locks/staging-accc372ed0ccb0d8.lock'] {
2022-11-18T00:50:44.200Z [err] npm WARN locking errno: -13,
2022-11-18T00:50:44.200Z [err] npm WARN locking code: 'EACCES',
2022-11-18T00:50:44.200Z [err] npm WARN locking syscall: 'open',
2022-11-18T00:50:44.200Z [err] npm WARN locking path: '/data/.npm/_locks/staging-accc372ed0ccb0d8.lock'
2022-11-18T00:50:44.200Z [err] npm WARN locking }
2022-11-18T00:50:44.264Z [err] npm ERR! code
2022-11-18T00:50:44.265Z [err] EACCES
2022-11-18T00:50:44.265Z [err] npm ERR! syscall open
2022-11-18T00:50:44.265Z [err] npm ERR! path /data/.npm/_locks/staging-accc372ed0ccb0d8.lock
2022-11-18T00:50:44.265Z [err] npm ERR! errno
2022-11-18T00:50:44.265Z [err] -13
2022-11-18T00:50:44.266Z [err] npm ERR!
2022-11-18T00:50:44.266Z [err] ERR! Your cache folder contains root-owned files, due to a bug in
2022-11-18T00:50:44.266Z [err] npm ERR! previous versions of npm which has since been addressed.
2022-11-18T00:50:44.266Z [err] npm ERR! To permanently fix this problem, please run:
2022-11-18T00:50:44.266Z [err] ERR! sudo chown -R 1000:1000 "/data/.npm"
2022-11-18T00:50:44.279Z [err]
2022-11-18T00:50:44.279Z [err] npm ERR! A complete log of this run can be found in:
2022-11-18T00:50:44.279Z [err] npm ERR! /data/.npm/_logs/2022-11-18T00_50_44_268Z-debug.log
2022-11-18T00:50:44.288Z rc=243
I have attempted to run the sudo chown -R 1000:1000 "/data/.npm" command recommended in the log file with no success. I attempted to run it from the Unraid NodeRed docker console, and got sh: sudo: not found. If I run it without sudo, I get chown: /data/.npm/_locks: Operation not permitted.
I am running Node-RED v2.0.0-beta.1 in a docker container on my Unraid server. I only use it to interface with a Home Assistant instance running in a separate VM. I have previously been able to install modules, but it's been a couple months since I last attempted to do so. Does anyone know how to fix this error?
