im done with all you told me,
No I said...
You got both parts wrong ![]()
oh really
i think i got the instruction wrong
Yes
cd into the .node-red directory
Type npm i
Press enter
You did not follow the instructions in Steve's post a few minutes ago:
Type npm i
Press enter
Also, looking at that screenshot, I would guess you also did not delete the node_modules folder (since it reported up to date)
Please follow all instructions to the letter (i.e. no one said start node-red!)
In the command window run the commands
cd .node-red
npm i
but first delete the node_modules folder.
okay i just did that, bellow is the response
<Microsoft Windows [Version 10.0.19044.2728]
(c) Microsoft Corporation. All rights reserved.
C:\Users\USER>cd.node-red
C:\Users\USER.node-red>
C:\Users\USER.node-red>npm i
up to date, audited 1 package in 112ms
found 0 vulnerabilities
You did not delete the node_modules folder. Please try and do everything asked. If you don't understand then ask. The node_modules folder is the one shown in the screenshot you posted a few minutes ago.
Then run npm i again, from the .node-red folder as before. That will rebuild node_modules.
i deleted it before i run the code sent
don't be tired of me please.
I am not tired with you, just tired. I went to bed.
Can you post the contents of the file package.json from the .node-red folder please?
Then delete the node_modules folder again, then, from the .node-red folder
ls -l node_modules
npm i
ls -l node_modules
The first command should say that node_modules does not exist.
Please don't post screenshots, copy/paste the text from the command window. When posting use the </> button at the top of the forum entry window and paste the text between the lines containing three back ticks. Use that technique for posting package.json too.
"name": "node-red-project",
"description": "A Node-RED Project",
"version": "0.0.1",
"private": true
