Unable to write values to the OPC UA server
I am using node-red-contrib-iiot-opcua node. I have created a server in my flow and some variables.
I am receiving a boolean value from PLC, I want to write this value in my OPC UA server in node-red.
I have added a function block in between to send relevant data to the write node. It gives me an error. I am relatively new to node-red. Can somebody help me to tackle this problem? Thank you!
Hello @SK_30 and welcome to the forum.
Use a debug node to show msg.payload as it leaves the function node.
I suspect it will not look exactly as you intend, though I don't see any problem with msg.payload.injectType specifically.
Since msg.payload is a boolean, you cannot start setting sub properties like it is an object.
I would have shown you how but since you posted a picture of the code, I am not about to re-write it
(TIP: Always post code and logs as text - so people helping you out can copy/update/paste a fix for you).
You will need something like
msg.payload = {
   other_properties: 'other values',
   value: msg.payload
return msg
Oh good catch, wish I'd spotted that!
Thank you for your quick response,
I made changes according to your example. It shows me the following error in the 'write' node.
Error: serviceResult = BadNothingToDo (0x800f0000)
Following is my new code in function node.
msg.payload = {
    nodetype: 'inject',
    injectType: 'write',
    addressSpaceValues: 'ns=1;s=ExitStation',
    valuesToWrite: msg.payload
The write node requires the following data as input.
Input:
payload (value to write one or all)
topic
addressSpaceItems or nodesToWrite (Array of Node-Ids)
nodetype (inject)
injectType (write)
valuesToWrite (Array of values or objects to write individual)
If the node needs the above :point_up: format - why are you setting it up differently?
try...
msg.topic = ""
msg.nodetype ="inject"
msg.injectType = "write"
msg.addressSpaceItems = [
    {"name":"","nodeId":"ns=1;s=ExitStation","datatypeName":"Boolean"}
msg.valuesToWrite = [
    msg.payload
Untested: this was formed from info in this post: Issue with opcua and s7 -> OPCServer in node red with many tags
Lastly, have you checked out the built in examples?
ctrl-i → examples
Simple error: there is no value to write. Value must match to valid value DataType in this case true/false.
Status code tells you "Nothing to Do".
