Can anyone think of a way I can deal with this? Every 5 seconds, i am taking an integer from KepserverEX using OPCUA. This value comes from a machine in a factory but when any one machine is turned off the whole thing fails. Nothing is sent through the JOIN node.
I think a way of dealing with this would be to set a time delay and read the values from the OPCUA node. Then have a function node that somehow looks at the values and inserts a 0 if nothing is received from that particular machine. I have no idea how do do that though.
"id": "ef0ed424a004a410",
"type": "inject",
"z": "ea7010c55ceba8e3",
"name": "1 Min Timer",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "5",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "1",
"payload": "",
"payloadType": "date",
"x": 310,
"y": 260,
"ebc495b1ad475a53",
"e96f3624fd9b39c7",
"37137f37348b62b1"
"id": "882e1eb4745b401f",
"type": "OpcUa-Client",
"endpoint": "7290d8b0.f713d8",
"action": "read",
"deadbandvalue": "",
"time": "10",
"timeUnit": "s",
"localfile": "",
"localkeyfile": "",
"folderName4PKI": "",
"maxChunkCount": "",
"maxMessageSize": "",
"receiveBufferSize": "",
"sendBufferSize": "",
"name": "Test server (subscribe items)",
"x": 860,
"y": 200,
"e45a38d6fe39b386"
"id": "e45a38d6fe39b386",
"type": "join",
"name": "Join",
"mode": "custom",
"build": "object",
"property": "payload",
"propertyType": "msg",
"key": "topic",
"joiner": "\\n",
"joinerType": "str",
"accumulate": false,
"timeout": "",
"count": "3",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "",
"reduceFixup": "",
"x": 1090,
"y": 200,
"50e9e02ebe503bde"
"id": "50e9e02ebe503bde",
"type": "function",
"name": "Rename Keys",
"func": "msg.payload = {\n BoardCount1: msg.payload[\"ns=2;s=BAR-GAL-AND1.PLC.BoardCount\"],\n BoardCount2: msg.payload[\"ns=2;s=BAR-GAL-AND2.PLC.BoardCount\"],\n BoardCount3: msg.payload[\"ns=2;s=BAR-GAL-AND3.PLC.BoardCount\"],\n \n};\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1260,
"y": 200,
"84b35168f1946a50"
"id": "ebc495b1ad475a53",
"type": "OpcUa-Item",
"item": "ns=2;s=BAR-GAL-AND1.PLC.BoardCount",
"datatype": "Int32",
"value": "",
"name": "Anderson 1 Board Count",
"x": 550,
"y": 200,
"882e1eb4745b401f"
"id": "37137f37348b62b1",
"item": "ns=2;s=BAR-GAL-AND2.PLC.BoardCount",
"value": "",
"name": "Anderson 2 Board Count",
"x": 550,
"y": 260,
"882e1eb4745b401f"
"id": "e96f3624fd9b39c7",
"item": "ns=2;s=BAR-GAL-AND3.PLC.BoardCount",
"value": "",
"name": "Anderson 3 Board Count",
"x": 550,
"y": 320,
"882e1eb4745b401f"
"id": "84b35168f1946a50",
"type": "debug",
"name": "debug 251",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 1430,
"y": 340,
"id": "7290d8b0.f713d8",
"type": "OpcUa-Endpoint",
"endpoint": "opc.tcp://10.50.66.175:49320",
"secpol": "None",
"secmode": "None",
"none": false,
"login": false,
"usercert": false,
"usercertificate": "",
"userprivatekey": ""
