Hello ..
The http-request node has an input that can accept a msg.
The body of the request is sent using msg.payload
( You could use a preceding Inject, Change, Function or any other node to construct a msg.payload
If you select the http-request node and view its Help tab on the side window
you get a detailed explanation of all the properties that you can set for that node.
