I have created a node which has 3 properties. My HTML looks like following
RED.nodes.registerType('person-data',{
category: 'function',
color: '#a6bbcf',
defaults: {
age: {value:"45"}
inputs:1,
outputs:1,
icon: "file.png",
label: function() {
return this.name||"person-data";
</script>
<script type="text/x-red" data-template-name="person-data">
<div class="form-row">
<label for="node-input-name"><i class="icon-tag"></i> name</label>
<input type="text" id="node-input-name" placeholder="name"><br/>
</div>
<label for="node-input-age"><i class="icon-tag"></i>age</label>
<input type="text" id="node-input-age" placeholder="age"><br/>
</div>
</script>
I can drag and drop the node from the palet. When I double click on it, I can see my 2 properties name and age. Then I give values and click ‘Done’ button. When I double click on the node again, I cannot see the given values for properties.
I tried removing and re-installing my node and also removing .config.json file but anything didn’t work. This problem is not there for the node which are already there. ex: twitter.
What is the reason for this issue?
