Of course, it's welcomed.
Before I go forward though, I'd like to point out, all elements on this UI use standard node-red elements & classes (label, typedinput etc)
100%
I hate having to use a change node after a node to move the payload to another property.
Definitely won't be removed. There are plenty of nodes do this for that very reason. Also, it leaves the current payload in tact if you set the "return to" to something different to the incoming payload - often I need the original payload down stream.
I don't understand? The data is a standard label. No different to any of the core nodes.
Yeah I struggled picking a reasonable icon for return.
Is that fa-send you refer to?
Also, the controls are node-red typedInputs & I am not certain how to have no icon on the left (I support I could set the typedInput "type" text to a space?)
No, I appreciate feedback Simon.
My 2c...
The labels are hard to choose as the core standard CSS classes form-row defaults label width to 30% if your label is too descriptive, it wraps the text and the UI looks terrible so labels are kept short (but not very descriptive). So while not ideal, I do full help in the side bar for every item in the UI (not that many folk read the help
