Updating label - ui-text
Trying to set the label of ui-text node dynamically. I finally figured out that I had to use ui_update.label to change the text (and not msg.label), but for some reason, I am seeing the [object Object] next to the label
The sample flow is below. What am I missing?
[{"id":"5676591b608cb257","type":"inject","z":"9fe89ce15b0f9a64","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Backyard Motion","payload":"{\"name\":\"battery\",\"currentValue\":100,\"dataType\":\"NUMBER\",\"value\":100,\"deviceId\":\"675\"}","payloadType":"json","x":254.6580810546875,"y":342.95769519140623,"wires":[["c74c79d966ceccab","32de5b4fae82bd41"]]},{"id":"c74c79d966ceccab","type":"change","z":"9fe89ce15b0f9a64","name":"Set Label","rules":[{"t":"set","p":"ui_update.label","pt":"msg","to":"topic","tot":"msg"},{"t":"delete","p":"payload","pt":"msg"},{"t":"set","p":"topic","pt":"msg","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":490.8345642089844,"y":290.82720947265625,"wires":[["7a6560d662a0b275","979ec43c0698dd3c"]]},{"id":"32de5b4fae82bd41","type":"change","z":"9fe89ce15b0f9a64","name":"Set Label","rules":[{"t":"set","p":"ui_update.label","pt":"msg","to":"payload.currentValue&'%'","tot":"jsonata"},{"t":"delete","p":"payload","pt":"msg"},{"t":"delete","p":"topic","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":489.8345642089844,"y":383.82720947265625,"wires":[["741c131a57fab787","9f384dc6a35c58af"]]},{"id":"7a6560d662a0b275","type":"ui-text","z":"9fe89ce15b0f9a64","group":"7a54ca8d64972f71","order":2,"width":0,"height":0,"name":"Name","label":"Button","format":"{{msg.payload}}","layout":"row-center","style":true,"font":"Arial Narrow,Nimbus Sans L,sans-serif","fontSize":"14","color":"#ffffff","wrapText":false,"className":"","x":638.3639831542969,"y":291.25550842285156,"wires":[]},{"id":"979ec43c0698dd3c","type":"debug","z":"9fe89ce15b0f9a64","name":"Name Debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":643.8346252441406,"y":216.82720947265625,"wires":[]},{"id":"741c131a57fab787","type":"ui-text","z":"9fe89ce15b0f9a64","group":"7a54ca8d64972f71","order":3,"width":0,"height":0,"name":"Value","label":"Override?","format":"{{msg.payload}}","layout":"row-center","style":true,"font":"Arial Narrow,Nimbus Sans L,sans-serif","fontSize":"14","color":"#ffffff","wrapText":false,"className":"","x":637.3639831542969,"y":384.25550842285156,"wires":[]},{"id":"9f384dc6a35c58af","type":"debug","z":"9fe89ce15b0f9a64","name":"Value Debug","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":649.8346862792969,"y":447.82720947265625,"wires":[]},{"id":"7a54ca8d64972f71","type":"ui-group","name":"Table","page":"602ea8fba38b32ae","width":"24","height":"16","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"602ea8fba38b32ae","type":"ui-page","name":"Test ui-table","ui":"de5759a313e7ad79","path":"/page6","icon":"home","layout":"grid","theme":"682b37bffc90cac5","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":7,"className":"","visible":"true","disabled":"false"},{"id":"de5759a313e7ad79","type":"ui-base","name":"My Dashboard","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"fixed","titleBarStyle":"default","showReconnectNotification":true,"notificationDisplayTime":5,"showDisconnectNotification":true,"allowInstall":true},{"id":"682b37bffc90cac5","type":"ui-theme","name":"Table Dark","colors":{"surface":"#000000","primary":"#ffffff","bgPage":"#000000","groupBg":"#000000","groupOutline":"#669c35"},"sizes":{"density":"default","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
It works for me.
label_update
Thanks for checking this out. I will keep digging into what may be going on.
The data is in the inject node. All I'm doing is changing the label to msg.topic in one text node and in the other case changing it to payload.currentValue (and appending a "%") sign. The change node also deletes msg.payload and msg.topic so no extraneous data is passed into the ui-text node.
I didn't realise till after I posted that the picture of your flow was actually the code, copyable. So my reply was irrelevant and I deleted it.
No worries - I think that's the "new" way of posting the flows.
sometimes, just refreshing the browser works
What browser/version are you using? Are you able to try a different browser?
