Updating nodes from True to False when no movement detected
Newbie here and trying to set up a Vacation mode. The task I'm trying to do is check if people haven't been around for a while, so both of us away --> start video recording. If we're away and motion detected by any of the internal motion sensors, send an alert. Feels like it should be straightforward and I'm using an AND boolean for both away and an OR for motion detected.
The issue I get is while we're not away doesn't matter whether there is motion or not - my flow correctly goes from FALSE to TRUE, once the motion is over (or if none detected for 5 minutes) it should go back to FALSE, but I can't seem to get it to do that. I understand how to get it to push 'TRUE' but not a 'FALSE' when no motion is detected. I've tried using an Inject node or Trigger node, but just not getting it to work.
Thank you for reading this and even more thanks if you can help. I have tried searching for some ideas but Updating just tends to come back with how to update the version of NR.
Colin
        "id": "2ae95c0d6fee596e",
        "type": "tab",
        "label": "Vacation",
        "disabled": false,
        "info": "",
        "env": []
        "id": "d36a80cd2e6745ff",
        "type": "and-gate",
        "z": "2ae95c0d6fee596e",
        "name": "Both Away",
        "rules": [
                "t": "true",
                "propertyType": "msg",
                "property": "payload",
                "topic": "ColinAway"
                "t": "true",
                "topic": "JudeAway"
        "outputTopic": "BothAway",
        "gateType": "and",
        "emitOnlyIfTrue": true,
        "x": 510,
        "y": 80,
                "6b2b14341e990d6f"
        "info": "Check to see if both people are away"
        "id": "68699525d7d6badf",
        "type": "server-state-changed",
        "name": "ColinAway",
        "server": "98511cac7ac8d7d8",
        "version": 4,
        "exposeToHomeAssistant": false,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "person.colin",
        "entityidfiltertype": "exact",
        "outputinitially": false,
        "state_type": "str",
        "haltifstate": "home",
        "halt_if_type": "str",
        "halt_if_compare": "is_not",
        "outputs": 2,
        "output_only_on_state_change": true,
        "for": "30",
        "forType": "num",
        "forUnits": "minutes",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": true,
        "ignoreCurrentStateUnavailable": true,
        "outputProperties": [
                "value": "true",
                "valueType": "bool"
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "ColinAway",
                "valueType": "str"
        "x": 100,
        "y": 80,
                "d36a80cd2e6745ff",
                "56260fa60b4dffa2"
        "id": "59896788424274df",
        "name": "JudeAway",
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "person.jude",
        "outputs": 2,
        "for": "30",
        "forType": "num",
                "value": "true",
                "valueType": "bool"
                "property": "data",
                "value": "",
                "value": "JudeAway",
                "valueType": "str"
        "x": 100,
        "y": 160,
                "d36a80cd2e6745ff",
                "56260fa60b4dffa2"
        "id": "6b2b14341e990d6f",
        "type": "api-call-service",
        "name": "Home Mode Off",
        "version": 5,
        "debugenabled": false,
        "domain": "switch",
        "service": "turn_off",
        "areaId": [],
        "deviceId": [
            "2b7232ab4d62c6c301a51cf27240220a"
        "entityId": [
            "switch.diskstation_surveillance_station_home_mode"
        "data": "",
        "dataType": "jsonata",
        "mergeContext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "last",
        "x": 980,
        "y": 120,
                "ecbafa6d3be7d3ac",
                "04fc0acb91bd4364"
        "id": "56260fa60b4dffa2",
        "type": "and-gate",
        "name": "IndoorsMotionAlert",
        "rules": [
                "t": "true",
                "t": "true",
                "topic": "JudeAway"
                "t": "true",
                "topic": "MotionDetected"
        "outputTopic": "IndoorsMotionAlert",
        "gateType": "and",
        "x": 510,
        "y": 160,
                "573d1fac88a7d594"
        "id": "7e10b6898845615f",
        "type": "or-gate",
        "name": "MotionDetected",
        "rules": [
                "t": "true",
                "topic": "MotionDownstairs"
                "t": "true",
                "topic": "MotionUpstairs"
                "t": "true",
                "topic": "MotionLivingRoom"
        "outputTopic": "MotionDetected",
        "gateType": "or",
        "x": 420,
        "y": 320,
                "56260fa60b4dffa2"
        "id": "f7fd2ff58483ac20",
        "name": "MotionDownstairs",
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "binary_sensor.motion_sensor",
        "haltifstate": "off",
        "halt_if_compare": "is",
        "outputs": 2,
        "output_only_on_state_change": false,
        "for": "5",
        "forType": "num",
                "value": "true",
                "valueType": "bool"
                "property": "data",
                "value": "",
                "value": "MotionDownstairs",
                "valueType": "str"
        "x": 110,
        "y": 240,
                "7e10b6898845615f"
        "id": "24dbd3e698ffcfc8",
        "name": "MotionUpstairs",
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "binary_sensor.sonoff_a480034589",
        "outputs": 2,
        "for": "5",
        "forType": "num",
                "value": "true",
                "valueType": "bool"
                "property": "data",
                "value": "",
                "value": "MotionUpstairs",
                "valueType": "str"
        "x": 120,
        "y": 340,
                "7e10b6898845615f",
                "6dcf71bee94cb062"
        "id": "58ff7a280dcfe6e3",
        "name": "MotionLivingRoom",
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "binary_sensor.sonoff_a480034586",
        "outputs": 2,
        "for": "5",
        "forType": "num",
                "value": "true",
                "valueType": "bool"
                "property": "data",
                "value": "",
                "value": "MotionLivingRoom",
                "valueType": "str"
        "x": 110,
        "y": 420,
                "7e10b6898845615f"
        "id": "6dcf71bee94cb062",
        "type": "debug",
        "name": "debug 4",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 500,
        "y": 420,
        "id": "e67785f831362dba",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 660,
        "y": 320,
                "573d1fac88a7d594"
        "id": "573d1fac88a7d594",
        "name": "Internal motion detected",
        "version": 5,
        "domain": "persistent_notification",
        "service": "create",
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "data": "{\"message\":\" Internal motion detected\",\"title\":\"Vacation mode\"}",
        "dataType": "json",
        "mergeContext": "",
        "queue": "all",
        "x": 950,
        "y": 240,
        "id": "ecbafa6d3be7d3ac",
        "name": "Home Mode Set",
        "version": 5,
        "domain": "notify",
        "service": "mobile_app_ipad_colin",
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "data": "{\"message\":\" Home Mode set - vacation\",\"title\":\"Vacation mode\"}",
        "dataType": "json",
        "mergeContext": "",
        "queue": "all",
        "x": 1260,
        "y": 140,
        "id": "04fc0acb91bd4364",
        "name": "Send message",
        "version": 5,
        "domain": "icloud",
        "service": "display_message",
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "data": "{\"account\”:\”xxx@yyy.com\”,\”device_name\":\"iPhone12-Colin\",\"message\":\"Internal movement detected\"}",
        "dataType": "json",
        "mergeContext": "",
        "queue": "none",
        "x": 1240,
        "y": 260,
        "id": "3bc699c7085bca8a",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 1020,
        "y": 380,
                "04fc0acb91bd4364"
        "id": "98511cac7ac8d7d8",
        "type": "server",
        "name": "Home Assistant",
        "version": 4,
        "addon": false,
        "rejectUnauthorizedCerts": true,
        "ha_boolean": "y|yes|true|on|home|open",
        "connectionDelay": false,
        "cacheJson": false,
        "heartbeat": true,
        "heartbeatInterval": "30",
        "areaSelector": "friendlyName",
        "deviceSelector": "friendlyName",
        "entitySelector": "friendlyName",
        "statusSeparator": ": ",
        "statusYear": "hidden",
        "statusMonth": "short",
        "statusDay": "numeric",
        "statusHourCycle": "default",
        "statusTimeFormat": "h:m"
I'm unable to import your flow into Node-RED.
bad_import
Hi Dave, Thanks for checking - I was trying to remove my iCloud account details, I've deleted that node, as its not important to the logic.
Try this instead:
        "type": "and-gate",
        "rules": [
                "t": "true",
                "t": "true",
                "topic": "JudeAway"
        "gateType": "and",
        "x": 510,
        "y": 80,
                "6b2b14341e990d6f"
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "outputs": 2,
        "for": "30",
        "forType": "num",
                "value": "true",
                "valueType": "bool"
                "property": "data",
                "value": "",
                "valueType": "str"
        "x": 100,
        "y": 80,
                "d36a80cd2e6745ff",
                "56260fa60b4dffa2"
        "name": "JudeAway",
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "outputs": 2,
        "for": "30",
        "forType": "num",
                "value": "true",
                "valueType": "bool"
                "property": "data",
                "value": "",
                "valueType": "str"
        "x": 100,
        "y": 160,
                "d36a80cd2e6745ff",
                "56260fa60b4dffa2"
        "version": 5,
        "domain": "switch",
        "areaId": [],
        "deviceId": [
        "entityId": [
        "data": "",
        "mergeContext": "",
        "queue": "last",
        "x": 980,
        "y": 120,
                "ecbafa6d3be7d3ac"
        "type": "and-gate",
        "rules": [
                "t": "true",
                "t": "true",
                "topic": "JudeAway"
                "t": "true",
        "gateType": "and",
        "x": 510,
        "y": 160,
                "573d1fac88a7d594"
        "type": "or-gate",
        "rules": [
                "t": "true",
                "t": "true",
                "t": "true",
        "gateType": "or",
        "x": 420,
        "y": 320,
                "56260fa60b4dffa2"
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "outputs": 2,
        "for": "5",
        "forType": "num",
                "value": "true",
                "valueType": "bool"
                "property": "data",
                "value": "",
                "valueType": "str"
        "x": 110,
        "y": 240,
                "7e10b6898845615f"
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "outputs": 2,
        "for": "5",
        "forType": "num",
                "value": "true",
                "valueType": "bool"
                "property": "data",
                "value": "",
                "valueType": "str"
        "x": 120,
        "y": 340,
                "7e10b6898845615f",
                "6dcf71bee94cb062"
        "version": 4,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "outputs": 2,
        "for": "5",
        "forType": "num",
                "value": "true",
                "valueType": "bool"
                "property": "data",
                "value": "",
                "valueType": "str"
        "x": 110,
        "y": 420,
                "7e10b6898845615f"
        "type": "debug",
        "name": "debug 4",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 500,
        "y": 420,
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 660,
        "y": 320,
                "573d1fac88a7d594"
        "version": 5,
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "dataType": "json",
        "mergeContext": "",
        "queue": "all",
        "x": 950,
        "y": 240,
        "version": 5,
        "domain": "notify",
        "areaId": [],
        "deviceId": [],
        "entityId": [],
        "dataType": "json",
        "mergeContext": "",
        "queue": "all",
        "x": 1260,
        "y": 140,
        "type": "server",
        "version": 4,
        "addon": false,
        "cacheJson": false,
        "heartbeat": true,
Here is a demo using pure node-red nodes. Not everyone has Home Assistant (and even if we did we dony have access to your server or your components).
When requesting help, it is always useful to make a demo flow replacing NON standard nodes with inject nodes or change nodes (to simulate your data).
The demo...
The flow...
[{"id":"b520f036052aa3bb","type":"comment","z":"9a11d6ef7f86328c","name":"If we're away and motion detected by any of the internal motion sensors, send an alert","info":"If we're away and motion detected by any of the internal motion sensors, send an alert","x":1240,"y":440,"wires":[]},{"id":"97696b241e8f36df","type":"inject","z":"9a11d6ef7f86328c","name":"Mr home","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"mr","payload":"true","payloadType":"bool","x":340,"y":480,"wires":[["b02c86f3f31b9802"]]},{"id":"b3da531d4498e0dd","type":"inject","z":"9a11d6ef7f86328c","name":"Mr away","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"mr","payload":"false","payloadType":"bool","x":340,"y":520,"wires":[["b02c86f3f31b9802"]]},{"id":"0619ddf4438798c3","type":"inject","z":"9a11d6ef7f86328c","name":"Mrs home","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"mrs","payload":"true","payloadType":"bool","x":340,"y":580,"wires":[["b02c86f3f31b9802"]]},{"id":"9dd8993fd684e31d","type":"inject","z":"9a11d6ef7f86328c","name":"Mrs away","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"mrs","payload":"false","payloadType":"bool","x":340,"y":620,"wires":[["b02c86f3f31b9802"]]},{"id":"10a1e06605254e57","type":"inject","z":"9a11d6ef7f86328c","name":"Hall PIR presence","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"hall","payload":"true","payloadType":"bool","x":370,"y":700,"wires":[["1aee07b42011c857"]]},{"id":"ed90c29f02ced463","type":"inject","z":"9a11d6ef7f86328c","name":"Hall PIR clear","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"hall","payload":"false","payloadType":"bool","x":350,"y":740,"wires":[["1aee07b42011c857"]]},{"id":"d1b495657723c94b","type":"inject","z":"9a11d6ef7f86328c","name":"Stairs PIR presence","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"stairs","payload":"true","payloadType":"bool","x":370,"y":800,"wires":[["1aee07b42011c857"]]},{"id":"c0b7e24e64abeb98","type":"inject","z":"9a11d6ef7f86328c","name":"Stairs PIR clear","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"stairs","payload":"false","payloadType":"bool","x":360,"y":840,"wires":[["1aee07b42011c857"]]},{"id":"1aee07b42011c857","type":"change","z":"9a11d6ef7f86328c","name":"","rules":[{"t":"set","p":"pir[msg.topic]","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":620,"y":760,"wires":[["14cd4f1dfbd0d7a5"]]},{"id":"4d13016f8c454395","type":"comment","z":"9a11d6ef7f86328c","name":"store state in flow.pir","info":"","x":610,"y":720,"wires":[]},{"id":"14cd4f1dfbd0d7a5","type":"change","z":"9a11d6ef7f86328c","name":"","rules":[{"t":"set","p":"pirState","pt":"flow","to":"$flowContext(\"pir.stairs\") = true or $flowContext(\"pir.hall\") = true","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"pirState","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":760,"wires":[["279f1edb07315335","b778a57c0104cfaa"]]},{"id":"279f1edb07315335","type":"debug","z":"9a11d6ef7f86328c","name":"pirState","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1060,"y":760,"wires":[]},{"id":"b02c86f3f31b9802","type":"change","z":"9a11d6ef7f86328c","name":"","rules":[{"t":"set","p":"home[msg.topic]","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":630,"y":540,"wires":[["409468ece265f126"]]},{"id":"409468ece265f126","type":"change","z":"9a11d6ef7f86328c","name":"","rules":[{"t":"set","p":"someoneHome","pt":"flow","to":"$flowContext(\"home.mr\") = true or $flowContext(\"home.mrs\") = true","tot":"jsonata"},{"t":"set","p":"payload","pt":"msg","to":"someoneHome","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":860,"y":540,"wires":[["e2b615d0b64aa105","b778a57c0104cfaa"]]},{"id":"e2b615d0b64aa105","type":"debug","z":"9a11d6ef7f86328c","name":"someoneHome","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1080,"y":540,"wires":[]},{"id":"b778a57c0104cfaa","type":"switch","z":"9a11d6ef7f86328c","name":"someoneHome yes/no","property":"someoneHome","propertyType":"flow","rules":[{"t":"true"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":940,"y":640,"wires":[["019635e5439543e1"],["ab9246235961c0d8"]]},{"id":"ab9246235961c0d8","type":"switch","z":"9a11d6ef7f86328c","name":"pir active? yes/no","property":"pirState","propertyType":"flow","rules":[{"t":"true"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1210,"y":660,"wires":[["e9b13f9c871ec45c"],["019635e5439543e1"]]},{"id":"9ae9a94b3d094452","type":"debug","z":"9a11d6ef7f86328c","name":"ALERT!!!","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1500,"y":600,"wires":[]},{"id":"e9b13f9c871ec45c","type":"change","z":"9a11d6ef7f86328c","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"ALERT ALERT","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":600,"wires":[["9ae9a94b3d094452","402cfb08d5f009a6"]]},{"id":"019635e5439543e1","type":"change","z":"9a11d6ef7f86328c","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"No worries, all good","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1280,"y":720,"wires":[["402cfb08d5f009a6"]]},{"id":"402cfb08d5f009a6","type":"debug","z":"9a11d6ef7f86328c","name":"Status","active":true,"tosidebar":false,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":1490,"y":660,"wires":[]},{"id":"539daa09a880da13","type":"comment","z":"9a11d6ef7f86328c","name":"store state in flow.home","info":"","x":620,"y":500,"wires":[]},{"id":"f1bab472e753852f","type":"comment","z":"9a11d6ef7f86328c","name":"Is someone at home?","info":"","x":940,"y":600,"wires":[]},{"id":"125896566924f306","type":"comment","z":"9a11d6ef7f86328c","name":"Simulate HA signals with inject nodes \\n Not everyone has HA and we definitely \\n dont have access to your HA server ;)","info":"","x":350,"y":420,"wires":[]}]
Thanks Steve - will try later. Point noted about replacing non standard nodes, presume that also saves having to ship the wife round to everyone’s house that want to test the automation :slight_smile:
